Question about Crafts & Hobbies
How do I get smoke to come out of my smoky mountain ho locomotive
    New Friend:
You have to take the screw out of the top of the smoke stack closest to the cab and put in about three drops of 3-in-1 oil. Put the screw back in and try it. If that doesn't do it replace battery/s. If that doesn't work either, the engine switch may have been left on without any smoke liquid in it and may have burned smoke unit out.
Posted on Dec 13, 2017
2 Suggested Answers
  • 174 Answers
SOURCE: fleischmann 4145 HO locomotive
most problems motor used, or failed
Posted on Apr 17, 2012
HOW DO i CONVERT A CHARCOAL SMOKER TO A LP sMOKER
My advice would be: go to Landsman Smokey Mountain/search parts lists for their propane smoker/order the proper burner, mounts, regulator and hose. Assemble according to the Parts diagram. install a wood chip box. Happy Smoking.
Dec 15, 2014 | Landmann Smoky Mountain Two Drawer Easy...
Replace rubber tires
remove screw that attaches the side rod to the drive wheel, place traction tire in groove in drive wheel, replace side rod & screw.
Feb 03, 2014 | Bachmann Ho Usra 0 6 0 Steam Locomotive...
Locomotive no longer smokes
If the smoke unit was working, and no longer does, it may be burned out. Did you turn the unit off after running it out of fluid? If not, it will need to be replaced. The switch is behind the smokke box door on the front of the boiler. I'm not sure if the smoke unit is a warranty replacement part, but a check with Bachmann Parts & Services & they will give you an answer.
http://www.bachmanntrains.com/home-usa/prod_serv.php
Your Locomotive is commonly called the Bumble Bee.
Jan 14, 2012 | Bachmann G-gauge Big Hauler - Ebt Boxcar...
My son has an Iron King Train that the locomotive just stopped. It was stop/go for a while and now it doesn't run at all. Any ideas on what to look for?
First: clean your trackSecond: clean your wheelsif that fails, call 1-800-356-3910& speak with Bachmann Parts & Services to find out if your
locomotive need to be sent in for repair.
Mar 13, 2011 | Bachmann Ho Iron King Train Set
I recently purchased a Dash 9-44 CW Diesel locomotive. It has on the label of the box "Command Equipped" - "Towercom TM" - "Crewtalk TM" - "Railsounds TM". My...
I'm not familiar with the Dash 9-44 CW but it may be that the sound and smoke switches are turned off. You will probably find these under a removable cover on top of the locomotive or under it, usually near the cab. Check your instructions or go to Lionel.com and click on support. Instructions and manuals can be found here.
Apr 29, 2017 | Lionel Toys
I need instructions for brinkman smoker grill how to smoke
I have a Weber Smoky Mountain which is similar to the Brinkman. I learned how to smoke by going to the VIRTUAL BULLET website. www.vertualwebberbullet.com. Also, going to the many forums on smoking helps.
Don't get upset if things don't work out the first time....keep on trying!
Hank
Jul 01, 2009 | Brinkmann Smoke 'n Grill Double-Grill...
Need motor brushes for Penn Line and Tyco HO
If you go to :
www.hoseeker.net
they have old catalogs and part numbers for Penn Line trains. Then try:
www.yardbirdtrains.com
for parts or a replacement motor or they may be able to point you to someone who may have the parts. Good luck.
Bob D.
Apr 25, 2009 | Electric Vintage Tyco Ho Scale Trains...
Crafts & Hobbies Logo
100 people viewed this question
Top Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Craft and Hobby Expert? Answer questions, earn points and help others
