Question about Samsung Televison & Video
Have a samsung has double image - Samsung Televison & Video
Double image in samsung lcd tv
IF it is still under warranty, take it in to be replaced.
Aug 28, 2014 | Samsung Televison & Video
Samsung tv displays doubling images
You have a faulty LCD panel, common with older Samsung and Sony sets!
Apr 06, 2014 | Samsung Televison & Video
Samsung vertical shadow screen
Does the screen have a double image? or is one side of the screen darker and has a delay? If so, your LCD panel is failing, common problem with older Samsung LCD's. I have the same model in my dining room that had a double image, fixed it by taking the panel apart and applying thermal pads on top of the panel tabs. The set works like a champ to this day!!!
Oct 27, 2013 | Samsung LN-T4665F 46 in. LCD Television
Double picture
what is this double image or ringing picture??? if double image you have to check the orientation of your antenna, if it is ringing picture you have to adjust your frequency control by putting it to 15,750khz something don't forget to use your oscilloscope and your frequency counter..
Sep 10, 2013 | Samsung UN55B7100 TV
Samsung 52" lines and double images until tv warms up
It is a Samsung which means power supply issues.
Jan 30, 2018 | Samsung Televison & Video
There is double imaging on my samsung tv, i replaced the tcon board and it still has the double image.
does it go away when the set warms up? or if you tap the set? Sounds like a possible defective LCD panel tab. Samsungs and Sony's are known for this.
Dec 04, 2012 | Samsung LN40A650A LCD TV
The text and images appear as "double vision"
i had the same problem with my Dell computer and Samsung 931a monitor....after being on the phone with Dell for overe two hours and setting up a technician visit, i googled "computer monitor double image".....i went to Fixya and read several tips, but the one most often repeated worked immediately!....check and tighten your blue plug from your monitor to your computer!!
Jan 15, 2010 | Samsung SyncMaster 740N 17" LCD Monitor
Double images
you will need to have the tv re converged to make the picture right call a repairman
Feb 16, 2009 | Samsung HCM4215W 42" Rear Projection...
Projection TV
You will need to repair the convergence circuit to fix the double image. The second issue of the "perfect focus" stopping at 37% will be fixed at the same time. It is halting because the sensors detect no movement of the blue image. here is a link to the part number and how to purchase the board. http://www.partstore.com/Part/Samsung/Samsung/BP9500142E/New.aspx
Jun 03, 2007 | Samsung PCN5425R 54" Rear Projection...
Convergence: concave picture with double image
An easy replacement on the Samsubgs is to replace the convergence board. If you are doing this yourself it is just a plug in board. Here is a link for the part number and how to purchase it. http://www.partstore.com/Part/Samsung/Samsung/PCN5425/Samsung/Samsung/BP9400383A/New.aspx
Apr 09, 2007 | Samsung PCN5425R 54" Rear Projection...
Televison & Video Logo
Jerry Greenberg
Jerry Greenberg
