No paper error on 9970cdw, can't find any issues, restarted, etc. prints when it wants to
3 Suggested Answers
jonb3838
  • 237 Answers
SOURCE: Says paper jam no paper jam will not print. Have tried restarting etc..
it is possible that a sensor is stuck or that the rollers cannot pick up paper and would need to be replaced
Posted on Apr 29, 2009
  • 685 Answers
SOURCE: hp photosmart all-in-one "load paper"
Try this...
Posted on Aug 18, 2009
WHAT IS 007-243 code error
This fault code isn't specific to one location/function on your machine, however, I believe it is directly related to your paper trays. Other fault codes begining with 007-??? state a tray sensor error, misfed media in a tray etc...
If you're trying to print to a specific tray and it won't print giving this error, you may want to try printing using a different tray. It is entirely possible you have some jammed up paper in the paper path and this will stop all trays from printing.
Potential solution:
Ensure you don't have any paper jams related to your paper path and trays, herre is a link that provides you all iinstructions to clear any paper jam on your device http://www.support.xerox.com/support/workcentre-7328-7335-7345-7346/support/enus.html?associatedProduct=workcentre-7328-35-45-46-built-in-controller
NOTE: The above link is a support knowledgebase and you can search on any problem you may have with your product by typing the natural language query in the search field, paper jam, can't print, scan fails transferiing etc...
Once you have determined there isn't a paper jam or if so gently remove any misfed paper.Reboot the device PO/PO power off/power on.
If the print jobs fail again, check your job status and see if there is any info listed for your print job, could be a media mismatch.
Try printing to another paper tray, if your job is calling for paper from tray 3 try using tray 4 or tray 5 etc..
I have provided a generic response to this question and kind of throwing ideas out there, if you could provide additional information I may be able to give a better solution.
Check the details of your job in the job status list?
A lot of times the machine will provide good direction on potential issues with a print job.
Are you trying to print on a custom paper size?
If you tell the print driver to print to tray 3 and you have 8.5X11 loaded in tray 3 and your print job from ypour PC is actually 8.5X14 then the job will not print simply put the media has to match the job.
I hope this helps.
Mar 10, 2015 | Xerox Workcentre 7345 Printer, Copier,...
PRINT UNABLE EC
Your machine ventilation fan is not working, usually due to a foreign material being stuck at the fan or the fan is faulty or the PCB is faulty.
Mar 28, 2014 | Brother International - MFC-9970CDW -...
Brother 9970cdw toner
The Brother printers have a counter which will shut the printer down when the preset number of copies has been reached. You can reset the counter and it should print again. I did this 4 months ago. It bought me a little time, but my printer has begun to print a solid line down the left side of each page. I have cleaned everything that I can access to rule out smudged glass, etc. Perhaps it is just best to replace the drum or buy a new printer(much to Brother's delight and design).
Jul 10, 2012 | Brother MFC 7420 All-In-One Laser Printer
We keep getting a out of paper error and the tray has paper, we have restarted, cleaned the rollers and have replaced the paper, we have restarted both the computer adn the printer and canceled all jobs...
Follow this steps..
We need to focus on the printer itself and make sure that it will work before connecting to your computer.
Reset the all-in-one printer
  1. Take out all the papers on the printer.
  2. Completely shutdown the computer.
  3. Without turning off the printer, unplug the power cable at the back of the printer
  4. Unplug the USB cable at the back of the printer.
  5. While the printer is off and unplug, on the printer press the # and 3 at the same time.
  6. Wait for 1min.
  7. Keep on pressing the # and 3, then plug the power cable back in.
  8. The printer should be on automatically, if not turn on the printer using the on/off button while pressing the # and 3 and you should have a message that says "NVM" reset.
  9. It will do some initialization, then if the printer is asking to load the paper.
  10. Re-arrange the paper, then load it to the printer.
  11. Try making some test w/ the printer (try to make a copy on the printer)
  12. If you can now make a copy, It means the printer is now working.
  13. Plug the USB cable back in to the printer and computer.
  14. If you are having issues printing from the computer, download the HP's print diagnostic utility.
  15. Click here.
It should be okay by then. If your still having issues w/ the printer. Contact HP 1-800-474-6836
Good Luck :)
Feb 06, 2011 | HP Photosmart C6180 All-In-One InkJet...
The arrow light wont stop flashing
this is common issue when paper jam or errors in printing queue,, check for any paper stuck inside (open up the back bay) delete the printing queue, power off printer restart the computer ! you should get solid green light
Dec 15, 2010 | HP Deskjet D4260 Printer
Error 241.1 Paper Jam. I have reseated the tray
Brand New T652n lexmark printer get a paper jam every time! just opened and haven't been able to print one paper. Doesn't matter if you print from tray one or tray two. It gets stuck right after the rollers pick it up and try to send it to the toner. Any suggestions? I've tried to reseat the toner, plain paper, sized the paper correctly, I've tried just about everything I can think of! I can feed paper manually through the top tray, and it will print. But, just using the manual tray defeats the purpose of the other two trays. Anyone else having this issue?
May 26, 2010 | Dell 5310n Laser Printer
HP 1000 Laser Jet Printer - error printing
Turn the printer off and then back on. Does it go to the ready state? or does it come up and error? If the error only comes up when asking the printer to print then the printer probably has a worn paper pickup roller. You can take the old roller out and rotate the rubber tyre a little.
Mar 26, 2009 | HP LaserJet 1000 Printer
False Paper Jam
My name is Vikram Kumar Thumu, from India-Hyderabad. I have seen your message on the issue related to Paper Jam error messages even though there is no paper jam in printer . I would like to provide my suggestions on the issue. I hope that this should work for you and will resolve the issue.
This issue could happen if there is an issue with any small paper jam in the Printer, or due to the communicational issue .
To isolate the issue, I recommend you to perform below steps.
Steps are:
1. Power OFF printer and then please Disconnect the Printer from Computer and then disconnect the Power cable of Printer from wall outlet.
2. Check thoroughly in Printer that there is no small piece of paper in the Printer.
3. Let the Printer be disconnected and idle for 5 minutes.
Meanwhile please perform further steps on Computer.
  Note: The below steps are applicable if you are using WINDOWS 2000/XP/VIsta Operating system in  your PC
  Steps are:
 Perform the below steps to restart the print spooler :
1. Click Start>Run
2. Type services.msc
3. Click OK
4. A Window will pop up with so many services listed.
5. Scroll down to locate "print spooler" in the list, right click on it and click "Restart"
6. Restart the Computer.
Once if you are done with steps, please connect the Printer and then Power ON Printer and check the issue.
This should resolve the issue for you.
 If you need any further assistance on the issue, you can mail me at thumuvikram@rediffmail.com . I'll be glad to help you.
Bye.
Oct 15, 2007 | Canon PIXMA MP530 All-In-One InkJet...
24 people viewed this question
k24674
jasbo
jasbo
