Question about Dyson Vacuums
My dyson was cycling and i cleaned the head witch stoped it and went to vacuum and just stoped. The green lights are flashing.
chrispurs1
  • 372 Answers
SOURCE: Vacuum head is not staying flat
Hi.
Try changing the short transparant hose under the machine.
Or try removing the hose & reffiting it acts like a spring pivoting the head pushing it flat to the floor.
http://dysonmanuals.llc.nu/index.htm
Posted on May 18, 2008
  • 1462 Answers
SOURCE: Which is better Miele vacuums
i prefer dyson myself
Posted on Jun 26, 2008
SOURCE: How do I remove the washable filter to clean it on my Dyson bagless vacuum?
As you are looking down at the base of the machine (viewing from the front) you will notice a yellow button on the right side just inside of the the wheel area. push up the button to release the casing that holds the hepa filter and the spongy filter. You can see a diagram on your machine which shows this process. After you take the casing from the machine, the round housing which houses the 2 filters will come out of this casing as you pull it off. You can grab the spongy filter and pull it our of the casing. Rinse both filters as shown in diagrams on the side of the casing. Do not use soapy water, just warm water and squeeze out the spongy filter after each new soaking. Let the filters dry for 12 hours and then replace in your unit and enjoy the refurbished air movement. It does suggest that you clean these filters every 6 months.
Posted on Aug 09, 2008
DysonInfo
  • 107 Answers
SOURCE: Does my Dyson Animal vacuum have a hepa filter?
The HEPA filter is not a cleanable item. The pre-motor filter is the washable one.
Posted on Nov 30, 2010
jowen75
  • 5 Answers
SOURCE: I received a NEW dyson
This may sound silly, but it sounds like that you a have static electricity problem. If the dust is collecting on top (outside of the brush head that is probably the static attracting it. This is common during the colder months. You know how during these months when you walk across carpet and then just someone or a metal objest, you get a shock.
You might try lightly spraying a little "static guard" on the top of the brush head before using it, or using a carpet dusting product that smells good, and may reduce the static.
Posted on Jan 03, 2011
GREEN LIGHT FLASHING ON THE CHARGER for dyson vacuum
Hello, this is Ava with Think Crucial.
If the flashing green light is fast, it indicates that the battery is operating outside of its optimum temperature range and you need to store the machine at room temperature. However, if it's a slow flashing green light, it is advised not to use your vacuum and contact Dyson right away for further instructions. Dyson number is 1-844-679-1646.
You can purchase a wide variety of high quality Dyson replacement parts for your Dyson vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=dyson
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Nov 12, 2016 | Dyson Vacuums
Dc31 flashes green
Hi there, it's Jack at Dyson.
Usually if the indicator light flashes green when the trigger is pulled, this means the machine needs to be charged. If you have had your machine connected to the charger assembly for over 3.5 hours and continue to see the flashing green light, this could mean the machine isn't recharging correctly.
In order for us to diagnose which part is at fault we'd need to take you through some simple diagnostic checks when you have your machine to hand. You can reach our experts directly on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
We'll look forward to speaking with you.
Aug 03, 2014 | Dyson DC31 Bagless Handheld Vacuum
Shutting off green light flashes
It means that the vacuum is too hot or too cold
Feb 02, 2014 | Dyson DC44 Animal Cordless Vacuum
Hello, what is the significance of the lights when charging? The red and the two green lights are flashing when charging. After the time charge (1 night), the Dyson DC 16 does not function, the battery...
yes the reason the green and red light were flashing the way they are is because its a warning to you that the battery is either no longer good or there is problems with your wireing. Also those vaccumes were designed to not charge when there to cold or to hot as a saftey issue.
Aug 06, 2011 | Dyson DC16 Root 6 Bagless Handheld...
Dyson DC28 brush will not spin, red light flashing
I cleaned the rollers and washed the rollers. I even cleaned the filters but light is still flashing on all floor levels
Jan 18, 2011 | Dyson DC28 Animal Bagless Upright Vacuum
Red light flashing constantly on dc16 when on charge, used to just stay permantly red without flashing until it went green when charged up.
I had a similar problem when I bought an after market 2Ah battery. Would stay solid red for a few seconds then flash red. I believe my problem was that the battery had gone into "sleep mode" I.e. it was discharged to the point that it "sleeps" in order to protect itself. So......I simply attached a domestic DC multi adapter to the terminals on the battery that are marked + and - (the 2 outside terminals on a DC16 Dyson battery). Switched on the DC adapter for around 10mins and this was enough to "wake" the battery. It now charges as normal attached to the DC16 in the Dyson charge mount.
For a pretty in depth article on lithium battery sleep have a look at this:
http://batteryuniversity.com/learn/article/low_voltage_cut_off
Oct 29, 2010 | Dyson DC16 Root 6 Bagless Handheld...
Light on moterhead
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=34218&thid=498154
Light on moterhead
Posted by Arnold2 on Apr 08, 2008
The normal green light on the moterhead goes red and we appear to lose suction within the motor head
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
I checked with some of my contacts in the vacuum business and they told me that it may not be a United States vacuum and it might be a Canadian or European vacuum and may not be customer friendly to service, if you have a contact with a MAC or Snap On dealer or a metric auto store – as far as the green light on the powerhead the green light is supposed to let you know if the carpet is clean and the red light is supposed to be that the carpet is dirty, and laos it could be that your belt is loose and needs changing – a suggested belt change is every 4 to 6 months --- show them the screw and they might have something to fit or release the screw head, as per the removing of the wheel and replacing the electric cable, check with your local vac dealer or you may want to check with the Dyson dealer website and or phone # listed below:
http://www.dyson.com/homepage.asp
Contact Us
1-866-MY-DYSON
(1-866-693-9766)
Dyson Customer Care is available 7 days a week.
· Mon - Fri: 7am - 8pm, CST
· Saturday: 8am - 6pm, CST
· Sunday: 9am - 6pm, CST
questions@dyson.com
Don – The Vac Man
Go Ahead. Use Us.
Apr 08, 2008 | Dyson DC05 Cylinder Bagless Canister...
Vacuums Logo
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
