Question about Kenmore 78812 / 78814 / 78819 Gas Kitchen Range
Oven gas in intermitit. broiler works but oven gas in not flowing properly
  • 5,911 Answers
This problem is commonly attributed to a bad igniter on the bake manifold. Each oven manifold (one for bake, one for broil) has its own igniter. They are both fed from the same gas source, though. So, if the broiler works, more than likely you simply need to replace the bake igniter. The following link explains:
http://www.fixya.com/support/r401858-replacing_oven_igniter_gas_range
The bake igniter tends to wear out faster, due to the frequency of use.
You can purchase replacements on line at searspartsdirect.com, appliancepartspros.com, pcappliancerepair.com, or repairclinic.com. Just use you model number as your search criteria.
This is a simple repair that anyone can do on their without the need of a service call. Just follow the steps provided. If you have any questions, please let me know. I hope this helps you.
Posted on Jul 30, 2009
Maytag oven gas flow cuts in and out
probably a weak ignitor,even though they look like they are orange in color they may be weak and not passing enough current to keep the gas valve fully open to supply enough gas to properly heat the unit to temps,replace this part,a good test is to try the broiler,if this works ok then its for sure the bake ignitor
May 05, 2012 | Maytag Ovens
Gas oven/broiler won't light
HI,
If neither the bake nor the broiler heating elements heat, but the range burners still work, the clock may be set for a timed or self-cleaning cycle. Check to be sure the clock buttons and knobs are set properly. If your clock has a knob that says "push for man(ual)", push the knob in and try the baking and broiling elements again. If it still does not operate properly, you probably have a defect in the thermostat, selector switch, or common wiring.
If the oven does not have a separate bake/broil/etc. selector switch, the problem may be with the thermostat. But it's not easy to check the selector switch or thermostat for proper operation. If you suspect a problem in this area, call a qualified appliance repair technician.
Jul 04, 2008 | Dynasty DGRSC 30 Gas Kitchen Range
Bottom oven not working when you turn oven on no gas seems to be going in rest off cooker fine
This problem is commonly attributed to a bad igniter on the bake manifold in the bottom of the oven. As the igniters age from repeated use, they can become weak and no longer function properly. Just because they glow, does not mean they are good. If you are experiencing ignition problems, the following link explains a little theory about how these igniters work and how to replace one:
http://www.fixya.com/support/r3575727-replacing_an_oven_igniter_on_a_gas_range
The burner manifolds in most ovens each use a glow bar or electrode type igniter with a gas safety valve to ignite. Both oven manifolds are controlled by the Electronic Oven Control (EOC) board, which is your clock/timer on the control panel. If the surface burners work, but the oven does not, the problem is usually not a gas related issue. If a single igniter is still working (i.e., the broiler still works), its more than likely not a control board issue, either.
NOTE: You cannot light the oven with a match because the manifold uses a safety valve that requires a certain current potential flowing through the igniter to open and allow gas flow. This is a designed safety feature that prevents free flowing gas from entering the oven cavity without ignition. Such a condition could potentially create an explosion hazard.
Replacement parts (if required) can be purchased at any of the following websites:
repairclinic.com
Prices vary between these sites, so shop and compare. The first three sites listed also offer helpful exploded view diagrams to help you locate and properly identify the parts you need.
NOTE: It is common for the BAKE igniter to require replacement more often than the broiler, due to the frequency of use.
If you have any questions please post back with your MODEL NUMBER and let me know. I hope this helps you.
May 01, 2011 | Kitchen Ranges
GE profile JGSP44 Oven stopped working
Ignitor needs to be working for the gas valve to open. If the ignitor does not reach the proper amp draw the gas valve will not open. There is a video at www.appliancehelponline.com/servicemanual.html this will walk you thru performing an amp draw test on the ignitor.
Mar 28, 2010 | GE Profile JGSP44 Dual Fuel (Electric and...
Kenmore gas oven; range&broiler work, not bake cycle-bad ignitor?
Well there are other parts that control the igniter,but if you can remove the igniter and look for any cracks.Most are hard to find so you may need a magnifying glass.Any crack no matter how small will keep it from glowing.The gas will not flow until the photo senser has detected the igniter glowing for several seconds.You can get a parts breakdown at SearsPartsDirect.com.Well hope this helps.
Feb 02, 2010 | Kenmore 30464 / 30465 / 30469 Gas Single...
Broiler works but oven wont.
There is a valve on the rear to contorl the flow of gas to the oven that can be turned off or can go bad. Check it to make sure it hasn't gotten switched off and if its still not working (with swith flipped in the opposite direction) you probably have a bad valve
May 07, 2009 | GE Profile Spectra JGBP79 Gas Kitchen...
Oven not working. Top, broiler, and warmer are working.
Have you checked for proper gas flow into the over or broiler? This is a gas valve back there that will sometimes go bad. Also there is a sensor near your knobs, it is a timer that will go bad, the valve is about 85 dollars and the timer is about 65 dollars
Feb 08, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Amana broiler problem
Each burner manifold in the oven has its own igniter. If the igniter is defective, the burner assembly will not light. The igniter has to be functioning properly in order for the gas safety valve to open. This is a designed safety feature that prevents free flowing gas from entering the oven cavity without ignition. This reduces the risk of explosions.
There should be a flame spreader metal plate covering the access over the broiler. You will need to access the broiler so you can view the broiler manifold and igniter. Turn the oven setting to broil and make sure the igniter begins to glow. If the igniter fails to glow, replace it. If the igniter does glow, but you still do not have ignition after 90 seconds, the igniter may be weak and still require replacement. The following link explains oven igniter types, their current potential, and how to replace them:
If you have questions, or require additional assistance, please let me know before you rate the solution. I hope this helps you.
Jan 29, 2009 | Amana RanARG7302 Gas Kitchen Range
GE Profile Spectra JGBP85
Yes, it could very well be an igniter. The igniter can still glow and not work. The reason being that the igniter (depending on type) needs to produce .25 to .37 amps in order for the gas valve to open. If this potential is never reached, the igniter will glow, but gas will never flow. Or, gas will eventually flow for a weak (slow) igniter and will take forever to ignite. Which could be the reason for your low bake temperature. The burner does not stay lit all the time during the bake cycle. It will cycle on and off as needed to maintain the oven temperature. If the igniter is taking a long time to relight the burner, it could take a long time to heat. The broiler has a separate igniter and probably doesn't get used as often as the bake igniter. You can test the theory by swapping the igniter between the bake and broil burners and see if the problem moves to the broiler. Make sure you secure power to the range BEFORE attempting to remove the igniter, however. You should not have to turn off the gas to do this. Everything should be accessible through the oven door and broiler. I tell you this, because a new igniter (depending on the type you have) can run as much as $100. It will probably be worth the effort just to be sure. I hope this helps you.
Jul 15, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Kenmore 78812 / 78814 / 78819 Gas Kitchen Range Logo
424 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
