Have you checked fluid levels? Is there a flow control valve inline, or an inline filter that may be clogged?
Recommend contacting your local authorized service center directly or online here:
http://www.masseyferguson.us/about-us/contact-us.html
SOURCE: massey ferguson 3655
sounds like the seals are gone on the 4wd shaft, it takes oil pressure to keep the 4wd off, but if the seals are worn the all passes through and the 4wd will not dissingage, you will need a experianced michanic
SOURCE: Operator's manual for a Massey Ferguson 65 tractor
Go to google search engine and type in your tractor most of the time it will give you lots of web sites to look at.
SOURCE: i Have a massey furgeson 135 and the back arms
below are just a few of the tractor forum sites i use. these guys are really helpful and someone will have the answer for you. all i can say is to make sure all your levers are in the right position and check the quadrant lever position on your right. http://forums.yesterdaystractors.com/viewforum.php?f=19&sid=419bda8adfabe7c0757a89cd5e57d483 http://www.ssbtractor.com/wwwboard/Massey_Ferguson_tractors.html
SOURCE: I have a 1950 ferguson
i have a 130 massey the 3 point will left untill the draft at center link it stops. tryed all kinds of. any idies
I don't have your answer but if you google torque specs for your engine I'm sure you will find your answer. When I'm not sure I will call a dealer and they will most likely help out with the info
