Question about Cameras
Camera won't take a picture when the button is pushed. The only thing that happens is the light goes on.
  • Cameras Master
  • 5,417 Answers
Please tell us the make and model of the camera in question, the settings in use at the time, and any kind of knocks etc it may have suffered
Posted on Dec 07, 2017
SOURCE: camera will not do any thing
You have to hold the mode button for two seconds for the camera to activate. Then it will tell you how many photos can be taken. In your case, you can take 20. Your camera is now ready to take pictures and as soon as you take one, it should go down to 19..18.. etc. Then you connect the camera to your P.C and the pictures should be on there.
Posted on Apr 02, 2009
SOURCE: 05 katana new bat new starter new relay still
check these things: is the engine run/stop switch pressed? is the bike in gear? is your safety switch always depressed?
Posted on Apr 21, 2009
ladywinn
  • 5138 Answers
SOURCE: Push power button, lcd light comes on for a couple
Please Post the Model# that is printed on back of TV?
Posted on Oct 27, 2010
  • 3289 Answers
SOURCE: it won't take pictures sometimes. push the
The Nikon D40 in Auto Focus mode will only allow the shutter to operate when the image is in focus. When looking through the viewfinder, the bottom edge provides information relative to what you are looking at. See the image below:
Item 2 is the focus indicator. It must be illuminated to allow the shutter to release. If it is not illuminated, the lens has not been able to determine the correct focus. This can happen when attempting to take a picture in low light conditions. Make sure that the front facing "focus assist lamp" on the camera (between the shutter release and lens) has not been blocked or disabled (Settings Menu # 09) and try again. Many times, you will see and or hear the lens "hunt" for proper focus - the lens will travel from one end of its focus range to the other trying to find focus. When it can't, it stops and prevents the shutter from releasing. You can get around this "unable to focus" issue by changing the position of the switch on the lens to "Manual Focus" mode, detailed below:
If a lens has an "A - M" switch, move it to "M" to manually focus. If the switch says "M/A - M " then leave on M/A (unless you're going to be taking several or more in manual mode), as these lenses may be focused manually at any time in either position. As soon as you tap the shutter button in M/A you return to autofocus.
More advanced lenses, like the 18-200mm, 70-300mm VR and 18-135mm, and any lens with an M/A position, may be focused manually at any time without moving any switches. Leave them in their A or A/M positions.
I hope this helps and good luck!
Posted on Jun 13, 2011
elix0411
  • 3530 Answers
SOURCE: When I press the power
Welcome to Fixya
This means that the flash is recharging or the camera is in storage mode. You may move the camera in this mode. Do not attempt to open the battery door or turn the power off while the Camera Ready LED is steady or blinking; otherwise, the images or video clips in the camera may be damaged.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Posted on Jul 08, 2011
Canyon eos auto mode= won't take a pictuRE
Push your shutter 1/2 way down. See whats the readings in view finder.
Jul 04, 2013 | Cannon EOS 50D Digital Camera
Won't take a picture and keep the time in the memory
You have a button that is stuck or the battery has an issue.
Feb 01, 2013 | Wildgame Innovations IR 2.0 Digital Game...
Canon 40d will not take pictures
1) CF card in camera? Won't shoot without one
2) Does mirror go up?
3) Canon had a run of bad motors for this model - if mirror does not go up, then it is the mirror motor. If mirror goes up, shutter will not fire, press release again then the mirror goes down, the shutter motor is bad (same model motor). If mirror goes up, shutter fires, both blades travel together/no exposure, probably the shutter is bad.
May 07, 2012 | Canon EOS Digital Rebel XS / 1000D IS...
Camera powers on and everything seems to be in working order except it will not take a picture. could it be full?
That is one possibility. Try using a different memory card, or clear out the one you're using.
Dec 15, 2011 | Sony Alpha Dslr-a290 A390 Camera
How does this thing work?
Install the software on your computer. Put a battery in the camera. Push and hold the button to turn it on (display shows 00) Take some pictures - the camera makes a tiny beep, the led on the front flashes, and the count goes up by one. Push and hold delete to remove the last picture (count goes down) hold longer to delete them all (goes to 00). When you've collected some pictures, rush to your computer to download them with the USB cable before the battery runs out; when that happens the pictures are all gone (there's no flash memory in this). Holds about 40 pictures depending on the amount of detail in them.
Feb 03, 2011 | Disney Pix Click Digital Camera
My camera's monitor/screen is black with no picture
My AIPTEK 1080p was powering on but the screen was turning off within one second of turning the unit on. I verified that the camera was still working and just the output onto the screen failed. I was able to resolve this by hooking the camcorder up to the TV and viewing the menus on the TV and then turning the camcorder off with the power button. I think this problem happened because I didn't do a "clean" shutdown the last time I had my aiptek hooked up to the TV. It is now working perfectly!
Jul 27, 2009 | Aiptek Video Cameras
Won't keep focus on pictures.
I know what you mean and I had the same thing. its just that you need to not press down the button for so long and make sure your auto focus lock setting is on- i hope this helped (:
Jan 23, 2009 | LG Dare VX9700 Cell Phone
Polaroid Problems
If your having problems with your camera, for about 20.00 you can buy the same camera on Ebay.
Mar 05, 2008 | Polaroid OneStep AutoFocus Instant Camera
Cameras Logo
41 people viewed this question
Top Cameras Experts
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
