Question about Speed Queen Washing Machines
I have a New Speed Queen washing machine 12 days old with a stainless steel tub. After the 6th the tub started to discolor, kind of a faded gray around bottom and splotches on sides
  • Jim Ruge
    Jim Ruge Dec 07, 2017
    Mr.Snell, Do you have any suggestions on how I could remove or restore the stainless steel luster to this 12-day old
    speed Queen?
    Top Expert:
  • Speed Queen Master
  • 26,089 Answers
That will be the washing detergent and wear from the washing items I expect.
Posted on Dec 07, 2017
Testimonial: "Thank you Sir"
projdoc
  • 2237 Answers
SOURCE: discoloration around burners
the discoloration is from the heat. you can buy a stainless steel cleaner or use simple green for the grease.
Posted on Jul 20, 2009
SOURCE: discolorations/stains on stainless steel refrigerator surface
Tried lots of suggestions to no avail. Tried a USED, dried out Scotch Brite Cook Top pad on the scrubber handle with Heavy Duty Fantastick sprayed on the pad. Scrubbed the drip marks at the bottom and wiped away to see if it was "scratching" or marri8ng the finish. Nope, but IT WAS taking the water marks off. So I did a bit more and checked again. Working great with no problems for the finish. Cleaned the whole watermark area. Rinsed of with wet cloth. Let it dry and then used my usual stainless cleaner, buffed to shine and walked away to post this. :> My refrig is an Aman too but I read other problem sites and it is common with stainless steel refrigs
Posted on Aug 08, 2009
  • 142 Answers
SOURCE: SPEED QUEEN WASHING MACHINE LEAKS WATER WHEN IT STARTS WITH WASHU
check hoses and pump area.
Posted on Sep 14, 2009
SOURCE: freezer defrosting at will; refrigerator side uneven temperatures
Sound like it's going into showroom mode that the same problem we had, by unplugging it for awhile and then plugging it back in usually works if not this what we were told.
Sounds like you have bad thermistors ( # 4 and/or # 5 ) .To access these parts , you will have to remove the inside rear wall of the freezer . The # 4 thermistor , tells the main control board , the temp of the coils , if they need defrosted , when they are thru defrosting . This thermistor is the 1 " long , torpedo looking piece , clipped on the top left of the coils , with 2 white wires going to it . Part number WR55X10025 . It would be advisable to also replace the # 5 thermistor , located at the bottom of the freezer , slightly in front of the drain , also with 2 white wires going to it , slid into a housing . This thermistor , is the freezer thermistor , which tells the control board , the freezer temp , when to cycle off , associated with the fan speed also
Posted on Dec 16, 2009
  • 84 Answers
SOURCE: My speed queen top loader is leaking water during
It is probably the pump. Run the washer with the front off of it. The pump is on the bottom of the motor.
Easy repair.
Posted on Jan 12, 2010
Good day, can you please help, I want to know what can be the problem. Our speed queen heavy duty washing machine leaks water when spining. The water leak is at the top of the outer tub where the clips...
The basics would be make sure it's clean, the outer and inter ring of this area holds and builds up dirt and debris over time, causing a bad seal, also has to spin and be balanced properly or it will leak a little. ...
Feb 26, 2015 | Speed Queen Washing Machines
Does water fill with lid open or does it fill only wit the lid closed?
no
and the lid has to be closed for the machine to start and continue operations
stick with GE
Jul 21, 2017 | Speed Queen AWN432 Washer
How do I winterize a speed queen AWN432S top load washer?
you can,t winterize your washer in the first place any way okay
Nov 16, 2012 | Speed Queen AWN432S Top Load Washer With...
When the spin cycle begins the washer vibirates and moves on the floor. After the spin cycle reaches the maxium speed it stops. The springs are fine, but what else could be wrong?
The machine is probably not leveled properly. To level the machine, partly fill it with water. Make sure that the drum is standing in the middle of the machine and then adjust the machine until the water is at the same level all around at the nearest set of holes to the water. Check that the drum is still in the center of the outer drum. Make sure that the adjusting feet are all firmly on the floor and that you cannot rock the machine at all by hand. A top loader must be 100% level or it will shake.
Jul 25, 2011 | Speed Queen AWS44NW Top Load Washer
I have a Speed Queen Heavy Duty Large capacity wash machine model:AWM 351-3062 I need to find out ifit has a steel drum
Yes, all Speed Queens have a stainless steel tub, some are coated, but underneath is stainless steel
Jun 12, 2010 | Washing Machines
At start of spin cycle water splashes over top and runs down.
Hi, just fixed the daughters speed queen, same problem. The three brake shoes were worn allowing the tub to spin with the agitator.
replaced the shoes, washer fine. At first I thought it was the top ring. spent 30 dollars for nothing.
good luck
Mar 21, 2009 | Speed Queen AWS52NW Top Load Washer
Amana lw8203w leaking
Your LW8203W is at least 12 years old. It is leaking from the tub seal, Your machine needs to be rebuilt or replaced.
If you have it rebuilt I would also put in a new belt, pump, brake pads, upper tub bearing and the tub seal it needs.
Call and authorized Speed Queen or Amana dealership and ask for a price quote over the phone. Then price out a new machine.
Your choice.
Jul 05, 2008 | Washing Machines
Black Stains on my whites
At the end of the cycle, the wash plate nutates for
approximately 30 seconds to fluff the clothing after the
final spin. The action of fluffing causes the outer wash
plate seal to rub against the stainless steel basket while
they are both relatively dry. This condition causes the gray
discoloration.
RESOLUTION:
An updated machine control, part number 8542693, is
now available. The updated control reduces the fluff time
from 30 seconds to 8 seconds, allowing the clothing to be
fluffed, without causing discoloration.
Gray marks or smudges can be washed out of clothing
after wiping down the basket. The consumer should use
the recommended amount of HE detergent and the hottest
water safe for the fabric or hand wash the garment under
running water. In either case, the fabric must be cleaned
prior to running through the dryer
Feb 13, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Washing Machines Logo
27 people viewed this question
Top Speed Queen Washing Machines Experts
Terry Schneider
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you a Speed Queen Washing Machine Expert? Answer questions, earn points and help others
