Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
Cannot adjust red multi point
I cannot adjust red multipoint horizontal positioning. I have no problems getting both horizontal/vertical on Blue. No problem adjusting vertical red. But I cannot get the RED "+" to align in the horizontal position.
  • 167 Answers
Symptom:
Unit appears to have poor convergence due to:
1. cross hatch appears tilted
2. one color (or more) being larger than the others.
Cause:
The yoke or yokes may have:
(1) rotated slightly or
(2) slipped down during transport.
Resolution:
Loosen a yoke and lower to inspect the tape. If black tape is present remove it from under all yokes (white tape or no tape is OK). Slide yoke or yokes up tight against the CRT and tighten to prevent slipping or rotation. Precede with
alignments and or convergence as necessary.
Posted on Jul 30, 2009
    Problem Solver:
  • 8 Answers
Your TV has a convergence problem. You can get the parts, instructions, and repair support from www.TvRepairKits.com
Posted on Jul 31, 2009
Is there a code number that needs to be entered to bring the convergence pattern or menu on screen.
From a user standpoint you would follow these steps to bring up your Convergence menu:
1) Press your MENU button.
2) Press the Right Cursor Button to enter the Picture menu.
3) Press the Down Cursor Button until you highlight the MANUAL CONVERGENCE choice on the menu.
4) You will then see the following choices on the right hand side of the menu: Convergence Red, Convergence Blue, Multipoint Red, Multi Blue, Save Multipoint.
5) Once you choose either the Red or Blue choices you will get a crosshair in the middle of your screen. You will then use either your Up, Down, Left, or Right Cursor buttons to get the two images to line up correctly. If you still have multi images on your screen in either Red or Blue you would then have to adjust the Multipoint choice for that color.
May 14, 2011 | Philips 51PP9100D 51 in. Television
Multipoint blue convergence cannot be adjusted
Sound like you need to replace the STK's and any blown pico's on convergence board.
Jan 20, 2008 | Philips 60PP9202 60" Rear Projection...
Need code to enter on remote to engage multipoint convergence adjustments.Need save proceedure after adjustments are made & exit proceedure for RCA Projection TV Model # HD52W59, ITC 222A
To get the code to enter on your remote to engage multipoint convergence adjustments, you need to contact the rca customer care for that, you get them your model number and they will get your code for you.
To process and save the adjustment made, follow the steps below;
  1. Look through your manual. Your manual will always give you the most specific directions for your particular model. Look for an "adjusting convergence" or "set manual convergence" section.
  2. Enter the menu on your TV. Use the remote control and bring up the menu.
  3. Choose "Convergence." This may be under "Picture Settings," "Function" or "Advanced Options."
  4. Select a color. You will have red, green and blue to choose from. Do each one, starting with red.
  5. Press "Enter." A crosshair pattern will appear on your screen.
  6. Adjust vertically. If there is a horizontal red line visible, press the up or down arrow keys (or channel up or down) to adjust the convergence until the line is superimposed on the horizontal-center line of the white crosshair.
  7. Adjust horizontally. If there is a vertical red line visible, press left or right (or volume up or down) to adjust horizontally. Do this until the line is superimposed on the vertical line of the white crosshair.
  8. Save settings. It is important to save your settings when you are done, instead of simply exiting the menu.
  9. Repeat these steps for all colors.
Take care
Jul 06, 2010 | Televison & Video
How can i line the lights up in my sony kp-61hs10.
I'm going to assume that the "lights" are images on the screen that seem to have a multi colored shadow. Within the menu there's a choice for convergence, when selected this gives a white cross centered in the screen. Using the arrow keys on the remote (left-right for vertical movement and up/down for horizontal) you will adjust the color that is "shadowing" or get all the colors aligned so the white cross has no trailing red or blue either horizontally or vertically. If you can't get it to adjust or there is no effect then repair is probably the only option.
Aug 22, 2009 | Sony KP-61HS10 61" Rear Projection...
Convergence problem Mitsubishi 6043
DOES IT AUTOMATIC CONVERGENCE,,TRY THAT,,IN THE MENU,,TRY NEW JACKS
Mar 27, 2009 | Samsung HC-P4752W 47" Rear Projection...
Screen hazzy and issue with blue convergence
bad convergence would cause show to look as if it was supposed to be a 3-d movie, if a bulb was going out then people would look purple blue -green,or some other off color, so likely the green bulb is going out from the color of the people you described.
Feb 06, 2009 | Philips 60PP9202 60" Rear Projection...
Remote will not adjust red convergence/multi-point horizontally
check resistors around convergence i.c.(red) philips may use 2 resistors in parallell. should be about 1.8 ohms. assuming you already changed the i.c.
Jan 17, 2009 | Philips 55PP9352 55" Projection Television
Blue Multipoint converge failure Philips 55PP9753
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 12, 2008 | Philips 55PP9753 55" Rear Projection...
Philips Magnavox 51MP392H Rear Projection TV
A sign that amps are going bad, right now you can check resistors in convergence board alongside the amps, check resistance to see if right.
Oct 08, 2007 | Philips Magnavox 51MP392H Rear Projection...
Phillips 60PP920217F Convergence Problems
replace ic chips pt# stk392-120 or stk392- 150 and there are 12 resistors located near ic clips pt# 6r8 ( color code blue - gray - gold - gold ) board location no#s 3149 thu 3160 if you look close you may find two resistors discolored as i found on my convergence circut board , also use heat sink compound on new ic chips , take your time to mark all wire connectors going to board from tv , also use .022 dia gage rosin -core solder and a 15- 25 watt soldering iron you may have to adjust the red - blue convergence afterwards my tv set is 3 yrs old also ( thanks holbert )
May 03, 2007 | Philips 60PP9202 60" Rear Projection...
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
330 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
