Question about Tivoli Audio Players & Recorders
How to install new antenna in Tivoli iPAL - Tivoli Audio Players & Recorders
2 Suggested Answers
SOURCE: I have a Tivoli Ipal
Bought a replacement antenna for my iPal for about $5 plus a couple of dollars shipping. Installed it in 5 minutes without taking the back off of the radio. No big deal. Simple, cheap, fast.
Posted on Aug 18, 2012
Why has my Tivoli iPal AM/FM Radio stopped working?
Try removing the battery and power on. If it does not on, replace the unit, a new unit would cost you less that a repair of this unit
May 18, 2014 | Audio Players & Recorders
Bought a used iPal and it only came with a european compatible plug. I bought a US converter. Plugged it in and can't make sense of it. The radio doesn't work. When off, there's no green light....
If the radio has a European-style plug, it's probably expecting 220-volt power since that's their standard. If you got a plug adapter but not a voltage converter, the radio won't work because the line voltage is too low.
Check the radio for a ratings label which will tell you for sure what the radio expects. There may be a selector switch on the back which will let the radio work on our line voltage. Otherwise you'll need to purchase a voltage converter to use the radio.
Jun 20, 2011 | Tivoli (PAL) AM/FM Radio
Hello, I purchased a Tivoli Model One few months ago and I noticed that after tuning a radio station (strong signal, amber light on), the signal will fade out in ten minutes or so and I need to tune it...
hi,
it looks like its got a hookup for an external antenna on the back, hook a wire to it or better yet hook it up to a pair of rabbit ears, look at the back and make sure your hooking it up to the right connector am/fm
rabbit ears at walmart
..jm
Tivoli Audio Frequently Asked Questions Tivoli Audio
8260f424-51e7-404b-8aad-55d32a5ee6ab_1.c6ade34e7d92de1dbfde961d78f8c87b-2mys2t2nr3la4vnxyourkcko-2-0.jpeg
Jul 13, 2017 | Tivoli Kloss Model One AM/FM Radio
I have a Tivoli Ipal and I have a broken antenna. I have a new replacement antenna but need to install it. help.
Jan 20, 2011 | Tivoli iPAL AM/FM Radio
Can't seem to tune many stations at all. Also once a station is tunned it "slips".
The antenna works with the power cord. Try extending the length of its power cord with an extension cord.
Position of the radio in the room, the furniture in the room and your position in relation to the radio all affect its reception.
If there is a place to connect an external antenna, this will be helpful. Check with Radio shack and best buy for a FM loop antenna. Usually the wire is flat.
An inexpensive antenna for FM only is also a cheap alternative
Jan 03, 2011 | Tivoli Model Three Clock Radio
The battery is fully charged. It works while connected to the mains, but if i turn it off and remove the power cord (so it works on the batteries) it won't turn on. However, it will turn on while connected...
Change the battery in it. It can be found online. It is easily accessed on the back of the radio, by unscrewing 2 philips screws. I had the same problem with mine, with an old battery. Once turned on, I could unplug it and it would play for 12-14 hours. Apparently the iPal needs a higher voltage when it turns on, so your old battery is not able to deliver that.
Nov 19, 2010 | Tivoli iPAL AM/FM Radio
Antenna on radio broke
Radio Shack can get you an antenna, or a long wire (or wire coat hanger actually works too)
Jan 06, 2009 | Tivoli (PAL) AM/FM Radio
Tivoli iPal
send it back! I have had 2 fail this way.
Nov 13, 2007 | Tivoli (PAL) AM/FM Radio
Battery won't charge
this is what you should do: charge it.. then when it's still connected to the power switch it on.. then you can remove the power plug and enjoy it for hours...
I know it's weird...
Nov 12, 2006 | Tivoli iPAL AM/FM Radio
Open Questions:
49 people viewed this question
Top Tivoli Audio Players & Recorders Experts
Frank Russell
Frank Russell
Are you a Tivoli Audio Player and Recorder Expert? Answer questions, earn points and help others
