Question about Maytag Washing Machines
Maytag Bravos quiet series 300. Hate it. Prior owners of house didn't leave manual. Once unbalanced can't get it started.
    Master:
  • 691 Answers
This is not a well rated washing machine (Maytag, right?). Anyway, I have provided a link where you can download the manual (you will need the exact part number). This link shows you what to look for on their machines. Customer support phone numbers are also listed and they will be able to help you better than I can. Have you tried rebalancing your load? Sorry, had to ask.
https://www.maytag.com/services/contact-us/find-your-model---serial-number.html
Posted on Dec 07, 2017
SOURCE: Maytag Quiet Series 300 owners manual
my dishwasher does not want to work anymore it has a big L flashing
Posted on Sep 28, 2010
kel1guy2002
  • 3740 Answers
SOURCE: My Maytag Bravos quiet series
Hi and welcome to FixYa, I am Kelly.
My response is very long and will be in 2 parts this is PART 1
Here is what the service manual says about Ld:
"Ld" (Washer is taking too long to drain
water from the wash tub)
Check the following:
Is the drain hose kinked or clogged?
Is the drain hose installed properly? See
"Connect the Drain Hose," page 2-5. Press
PAUSE/CANCEL to clear display
Also:
Is the drain hose clogged, or the end of
the drain hose more than 96? (244 cm)
above the floor?
See "Drain System," page 2-3.
6. To remove the drain pump: (there are 2 pumps... the drain pump is on the left)
a) Loosen the clamps and pull the inlet
and outlet drain hoses off the pump.
Note that there is a tab on the outlet
connector that fits into a slot in the
hose.
b) Remove the three 5/16? hex-head
screws from the drain pump and remove
the pump from the tub.
Check the pump inlet and the tub outlet for obstructions.
Pump electrical winding resistance test:
-Disconnect the wire connector from the
drain pump terminals.
- Set the ohmmeter to the R x 1 scale.
- Touch the ohmmeter test leads to each
of the drain pump terminals. The meter
should indicate between 10.5 and 14 ?.
----Due to the design of the machine the 2 wires going to the drain pump have be notorous for backing out of the plastic connector. Check the connector of the pump for loose terminal connections. --
From the Ld troubleshooting steps / procedure:
Long Drain
Ld flashes when the water level does not change after the drain pump is on.
• Is the drain hose or the drain pump clogged?
• Is the drain hose height greater than 96? ?
• Is the pressure hose connection from the tub to the machine/motor control pinched or plugged?
• Is the pump running? If not, see TEST #7.
TEST 7
TEST #7 Drain/Recirculation
Perform the following checks if washer fails to drain or recirculate.
1. See Activation of Manual Diagnostic Test
Mode, and perform the Manual: Pumps
test.
2. Remove the console to access the machine/
motor control assembly. See Accessing
& Removing the Electronic Assemblies.
3. Visually check that the P4 connector is
inserted all the way into the machine/motor
control.
If visual check passes, go to step 4.
If visual check fails, reconnect P4 and
repeat step 1.
4. Remove connector P4 from the machine/ motor control and check resistance values of pump motor windings. Resistance values should match those shown in wiring diagram, page 7-1.
If resistance values are good, go to step 7.
If winding measurements are much higher (tens of ohms to infinity) than shown in wiring diagram, a problem
exists in the motor winding or in the connection between the machine/motor
control and the motor. Go to step 5.
5. Tilt machine forward to access the bottom
of the machine and the pumps. See
Figure 1, page 6-13.
6. Check the resistance at the pump motor. Remove the connector at the motor and
take measurements across pump terminals. Measurements should be as shown in the wiring diagram.
If winding measurements are much higher (tens of ohms to infinity) than shown in wiring diagram, replace the
pump motor.
If the resistance at the pump motor is correct, there is an open circuit in the wiring between the motor and the machine/
motor control. Repair or replace the lower wiring harness.
If the pump motor windings and machine/ motor control check OK, repair or replace the pump. Be sure to check
the pump and tub sump for foreign objects before replacing pump.
7. See Activation of Manual Diagnostic Test Mode, and perform the Manual: Pumps test.
8. If the Manual: Pumps test failed, then the machine/motor control has failed:
Unplug the washer or disconnect power.Replace the machine/motor control assembly.
Perform the Manual: Pump test.
Posted on Nov 21, 2010
SOURCE: my maytag bravos quiet series 300 washing machine
i lost the manual , what does "5d" mean when it is
Posted on Jul 04, 2011
TheMobilian
  • 8220 Answers
SOURCE: MAytag Bravos Quiet Series 300 washing machine
F-51 RPS senses rotation when basket ought to be stopped.
It is probably loose or worn out.
Video How To
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Oct 22, 2011
TheMobilian
  • 8220 Answers
SOURCE: 2 year old Maytag Bravos quiet series 300 is not blowing air out of the exhaust port.
Oh brother. These dryers have 2 belts. The small belt that drives the pulley is probably off the motor. The pulley tends to come loose and fall off. The manufacturer recommends lock-tite on the nut that holds that pulley. REPAIR PHOTO
Posted on Sep 06, 2012
I have a maytag bravos quiet series 300 dryer with the error message f73. What does that mean?
Maytag Bravos 7.0 Cu. Ft. Electric Dryer F73 - Questions ...
www.fixya.com/search/p688923-maytag_bravos_7_0_cu_ft.../f73
have a bravo dryer , wont start shows error code f73 ? lights come on but dryer ... I think there was an F73 or F93 error message but we did not write it down.
Sep 22, 2015 | Maytag Dryers
Maytag bravos quiet series 300 ran a long time got hot. Now the control panel lights up power button lights up press start button and clicks but dryer will not start
Most likely your thermo-fuse is bad. The fuse is normally located on the blower housing(usually white with 2 wires) You would need a continuity tester to confirm that it has continuity. It sometimes fails do to over load of clothing, vent clog, bad cycle thermostat, or failure to clean lint screen. If this is a computer controlled model the heater relay could also be bad. and caused the fuse to fail.
Dec 27, 2014 | Maytag Dryers
MAytag Bravos Quiet Series 300 washing machine starts to fill, stops and shows code F51
Video How To
Oct 22, 2011 | Maytag Bravos 3.8 Cu. Ft. Washer
Jun 14, 2009 | Dishwashers
Washing Machines Logo
100 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
