Question about Sony KV-32S45 32" TV
My Sony TV KV32s45 32" Shows no picture but has sound. After a few houres of unpuging the TV the screen is good but then the picture gose up and all i see i a black screen but the sound is good. THE stanby light is on.WHAT SHOULD I DO TO FIX THE PROBLEM?
  • 1 more comment
  • 007BRANDON Dec 22, 2007
  • tracer0000 Dec 22, 2007
    I have the exact same problem. I would like to have more clear step by step instructions with detail part names. Ideally if someone can offer a solution with some sort of manuel (with pictures) that would be really fantastic.
    I would greatly appreciate any help, anyway!!!!
  • lmillller Nov 09, 2008
    Shortly after switching on my Sony KV32s45, the picture distorts to the top of the screening then disappears. This TV is nearly ten years old and the problems started about six months ago. I quickly learned that if, with the back of the set removed, I can switch the TV off then on again while giggling the main circuit board the picture returns to normal. I usually have to do this giggling procedure twice immediately after switching the TV on. After that it performs perfectly. It is definitely seems to be a start-up problem. I suspect it is a bad solder connection. I have removed the main circuit board and inspected every connection, but found no visible defects. Except for the very annoying start-up problem, this Sony performs flawlessly.
After reading comments by Yxif, I examined the 7 pin IC (TDA8172) and discovered a bad solder connection on one of the pins. The bad connection was not visually obvious. I used a toothpick to apply a little pressure to discover the connection was loose. I reordered the pin connection and my annoying start-up problem was solved.
Thanks Yxif and all who contributed to this solution.
Posted on Nov 09, 2008
  • 244 Answers
Picture int disappears leaving snow on screen
Resolder the Xtal in the tuner
No picture - screen is empty. Sound is ok
Check IC101 (BA7630F), if video signal comes to input (pin 1) but not present at output (pin 14) then replace this IC
Intermittent video or snow
Resolder points A, B, C, D in tuner PCB, check cold solder on tuner shield 2-106-349-21
Posted on Nov 24, 2007
Green tint on screen especially with dvds. picture also cuts out for a few minutes every hour or so on our sony kds-50a2020
Usually in this set if screen gradually changes to something other than black and white the optical light engine is the problem---major part.
Google the model number with "problems" or "light engine" to learn more.
Aug 28, 2012 | Sony KDS-50A2020 Television
Alba lcd32880hdf tv after a few seconds the pitcher gose off
Ive got a albe Lcd32880HDF And the picture goes off 14 months old sound only?
Jan 07, 2011 | Televison & Video
Sony bravia 46" no picture no sound. Green light turns on but screen remains black. When i press input or menu still nothing.
Jun 25, 2010 | Televison & Video
My Sony KP-53S35 turns on, shows a blue screen, turns off
It sounds like the blue CRT (picture tube) is failing. The part number for this is 8-733-575-25 but you will need a technician to replace it for you as there is mechanical and electrical alignment to with with it. At that point it probably isn't cost effective to repair the TV. Please take a few moments to rate my answer. Thank you.
Nov 18, 2009 | Sony KP-53S35 53" Rear Projection...
No picture, sound works on Sony TV KV-27V22.
try to adjust the screen. it is located behind the CRT board.(CRT board is the board that attached to the picture tube) you will find a black knob which label screen adjust it by turning the knob.
Jul 04, 2009 | Sony KV-27V22 TV
Picture and sound first turn on before disappearing over and over again.
Symptom shows its weak Lamp problem in TV and you need to replace lamp. Replacement procedure is easy and written in instruction manual of TV.
Always buy Sony Original Lamp from Sony Accessories for longer life of TV.
Apr 25, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony Wega 27in Randomly Has Block Box Appear On Screen
this means the TV having picture upper part of the screen. problem may be -15 V to vertical deflection ic suddenly gose off and system control gose to stand-by mode resolder vertical out ic , -15 v supply line from the fly back and system control .
Jan 15, 2009 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony KF-60WE610 Screen and Sound On/Off
All symptoms in your TV shows that you need to replace its Lamp as it has been consumed its life hours and TV requires new lamp. Lamp can be obtained from Sony Website. Price is $200, Hope this info will help you to enjoy your Sony TV in coming days.
Aug 17, 2008 | Sony Grand WEGA KF60WE610 60" Rear...
Same problem: picture goes out
Sounds like you need to replace the lamp. The owners manual should show you how to replace the lamp. You can order the lamp through Sony on their website. Good Luck
Jan 24, 2008 | Sony KDF-E55A20 55 in. LCD Television
HV Sound no Picture
Sounds as though there is an intermitant, heat-related problem with the HV transformer. You can order this at a tv parts shop or from Sony (probably more expensive) the part number should be on the part or on a schematic. If not, the parts dealer can look it up from the model number.
Good luck! :)
Dec 27, 2007 | Sony KV-36XBR400 36" TV
Sony KV-32S45 32" TV Logo
276 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
