Question about Cameras
"Card Not Ready" This is what the frame says after I have copied everything from computer to card and works on computer. What do I do?
  • Cameras Master
  • 5,412 Answers
A) What make of frame are you using ?
b) Have you checked in the manual to see if there is an upper limit to the size of card it can accept ?
Posted on Dec 07, 2017
SOURCE: Upload images to SD card
Just to reiterate the above solution. I had the same problem, I just bought a cheap card reader- problem solved.
Posted on Dec 23, 2007
  • 3 Answers
SOURCE: LG Shine Card not Ready
did you try taking alll the pictures off the sd card and then putting it back into the phone
Posted on May 23, 2008
  • 76 Answers
SOURCE: copying pictures from computer to memory card
vista is main problem are you viewing the picture before you move them vista has problem if u open it 1st before coping moving etc etc it does what u mentiond b4 either shut the program u are using to view with down before u transfer them
Posted on Dec 02, 2008
SOURCE: Nextar N7-202 digital photo frame
I had the same problem and called Nextar Support. The gal I spoke with asked how big my SD card was and informed me that the capacity for this frame is only 2 GB. Sure enough, my card was 4 GB. I transferred the pictures to a 2 GB card and it works great! (Note to Nextar: might be nice if they put this somewhere in the paperwork BEFORE people buy an SD card.)
Posted on Dec 24, 2008
SOURCE: error ox80070052 copying to sd card
I had this problem with the jump drive I am using in my digital frame. The drive has lots of open space, but not all the pictures will download on it, and i get the Ox80070052 error message.
I fixed it by re-formatting the jump drive. I moved all the files on the jump drive to a folder on my computer. Then i re-formatted the drive using a FAT 32 configuration. instead of a FAT configuration.
After the re-format, all the pictures transfer to the jump drive with ease.
Posted on Mar 30, 2009
How do I download my photos from frame to computer
How did they get to the frame in the first place? You should be able to reverse the procedure.
If the pictures are on a memory card, you can simply put the card into a card reader on you computer and copy files. If the frame connects to the computer via USB, you should be able to copy files the same way.
If you need further details, please reply to this post, giving the make and model of your picture frame, as well as the location (memory card or internal memory) of the pictures on the frame.
Feb 03, 2012 | Cameras
How do i download pictures to tablet
Pandigital photo frames are an ideal way to display your collection of digital photos. You can view photos with or without a computer using just a memory card, but it's always a good idea to transfer the photos you'll want to view frequently to the internal memory of your frame. This is also a handy way to back up your favorite images.
  1. Transferring Photos from a Memory Card
    • Your digital photo frame's built-in software will recognize six types of memory card: CF I/II, SD, MS Pro, MMC and XD. Locate the slot on the back of the frame (to the left of the stand) that corresponds with your type of memory card. These are labeled as follows: SD/MMC/MSPro/XD, CF I/II, USB and mini USB. Insert your memory card into the appropriate slot, power on your digital frame, and it will automatically begin a slideshow using every available image on your memory card. Note that only JPEG formats under 16 megapixels are compatible.
    Transferring Photos from a PC
    • Use the USB cable that came with your frame. Connect the mini USB end to the mini USB port on the back of your frame; connect the large USB end to your computer's USB port. Double-click the "My Computer" icon on your desktop or in your Windows "Start" menu. You'll see that your computer has automatically assigned a drive to your digital frame---look for a device called "Removable Disk" followed by a letter (Removable Disk E:, for example). This is the folder that represents the internal memory of your digital photo frame; you will be dragging your photos into this folder.
      Next, open the folder in which you store your photos ("My Pictures," for example). Select the photos you want to transfer to your frame. Drag them to the drive associated with your digital photo frame---this is the "Removable Disk" drive you located within the "My Computer" folder. Every photo you selected will then be copied onto your digital frame.
      After the files are copied, disconnect your digital frame properly. If you don't, your frame's internal memory could be damaged. Look for the system tray in your desktop's lower right-hand corner. Left-click the icon that shows a gray box with a green arrow on top of it. Select "Safely Disconnect Hardware." A dialog box will appear, asking you to select the device to disconnect. Select the digital frame and click "OK." When the dialog box appears, click "Close." You'll see a message in the lower right hand portion of your desktop telling you it's safe to disconnect your frame.
    Copying Photos to Your Frame's Internal Memory
    • You can use your frame's remote control to copy photos from your memory card or computer to the photo frame's internal memory. Connect your photo source (computer or memory card) and have your frame's remote control handy. Access the "Home" screen on your frame using the "Home" button on your remote control or by pressing the "Home" button on top of the frame. Next, choose "Photos" and press "Enter." You'll see all your photos in thumbnail form. Scroll through them with the up and down arrows. Press the "+" key to mark photos you want to copy (use "-" to de-select a photo). When you've selected all the photos you want to copy, press "Set Up," then "Copy Photo," "Enter," "Selected" and "Enter." A dialog box will ask you to confirm your selection; with the cursor on "Yes," press "Enter." The photos you selected will be copied to the frame's internal memory.
Dec 04, 2011 | PANDIGITAL 7270FW Tablet
How do you download pictures from phone to digital frame
Most digital frames require a memory card to display photos. The first step is to download your photos from your phone to your computer. Then you need to put the memory card you get for your photo frame into the computer if it has a built in card reader or into an external usb card reader. Next open the file that has the photos you want, and open my computer and select the memory card folder. Select the images you want and press control and c to copy them, click on the memory card folder and press control and v to paste them. Then remove the card and put it in the photo frame.
Jul 30, 2011 | Parrot 7-Inch Digital Photo Frame (Red)...
How to copy pictures in digital frame internal memory
http://www.digitaltips.org/imaging/digit... ...
The following items about digital frames are from the link above where you may find additional information.
Memory
Another important feature to consider is how many images you can store on the frame. Most have slots for loading pictures directly from a camera's memory card. Make sure it accepts the same type or types of cards that your camera(s) do, as this will make transferring images to the frame significantly simpler. Also, look for a frame with a large internal (built-in) memory if you plan on loading lots of images for slide shows, videos and so forth.
Connectivity
With all the attention your digital frame will get from friends, family and members of your own household, you'll want to keep it updated with your most recent photos. Having multiple connectivity options can make this task a lot simpler. Most frames can connect to your PC using a ubiquitous USB cable, while Blue tooth and WiFi-enabled frames let you sync wirelessly from laptops, camera phones and cameras that are WiFi enabled. Many WiFi-enabled frames can automatically sync images from PCs on your home network or from photo sharing sites on the Internet, making it simple to keep updated.
If your computer has memory card slots, you can copy from the computer to a memory card.
If there are no memory card slots on your computer, purchase a Targus card reader at Walmart for $8.88 or another brand for less at Ritz/Wolf/Kit camera. Also, they do 3½ x 5" digital prints for 6¢ each on Tuesday and Wednesday.
CAUTION To prevent memory card corruption, keep batteries charged and don't delete. Wait for lights to stop flashing then turn camera off before removing memory. For card readers, double click Safely Remove Hardware. Select then click Stop and OK.
Have just been playing with this and found that it works really well, but you should first format the memory card in the camera because it adds files to the card you will need.
Next, take a picture of something with the camera.
Place the memory card in the card reader and go to My Computer.
Open the memory card and you should see a folder on the left (DCIM) that has your picture. Do not open the MISC folder on the right.
Double Click on the DCIM folder and you should see another folder (e.g.,100HPM417) which includes the name of your camera. Double Click on that folder and you should see the picture you just took.
When you copy from the computer to a memory card, that is the folder where your computer pictures must be copied. You may only be able to copy one picture at a time from My Computer.
One last thing, the file names of your pictures must not have any additional letters or those pictures will not be seen by the camera. Also, the file name format must match the file name of the picture you took e.g., HPIM1903. Rename files to the format of your camera photos.
If you have trouble with this, it may be easier to right click on Start and then left click Explore. Find and select the pictures you want to copy and then near the top left, click the X next to Folders to see a place to select Copy files. You can then select the memory card folder e.g.,100HPM417, that you clicked to see the picture you took and click Copy. You can copy pictures easier with this method.
Click this link for other camera tips and complete instructions on cleaning camera and battery electrical contacts. ...
http://www.google.com/base/a/4210404/D13...
Thanks.
Mar 11, 2011 | Cameras
How do you install photos from a jump drive on the Coby DP700? I have tried everything and it's not working. The insturctions given are no help at all.
You can move them to another card (i recomend a cheap usb stick) just move from the camera card to a folder in your computer and then copy them to the usb drive/stick and plug it in the picture frame
* Please rate this solution with Thumbs up and comment to help us improve providing support
Dec 02, 2010 | Coby DP-772 Digital Picture Frame
How do you add new photos to the digital picture frame?
Most digital photo frames come with an SD (memory) card that you can plug into a computer and copy the photo's you want from the computer to the memory card. Once done you pop the card back in the frame and your done.
Please be aware that the SD card maybe of limited capacity so you might not be able to get all the photo's you want on it unless you purchase a larger capacity card.
Regards.
May 26, 2010 | Coby DIGITAL FRAME COBY DP102 RTL
I just received my new lg cf360 in the mail, inserted my micro sd card and it does not work, says "card not ready!" I previously had the sd in my blackberry pearl and it worked fine.
I ended up figuring it out myself. I inserted my sd card in my pc, copied everything into a folder, went in my computer & right clicked my sd card, (labeled blackberry) formatted it. Reinstalled my stuff from the folder I copied, and inserted it in my new phone. Voila!
Only problem now, my ringtones do not work, says file too big. & The phone tends to occasionally have a brain fart and lock up or erase my info. This is a cheap crappy phone.......
Sep 03, 2009 | LG CF360 Cell Phone
Kodak Easyshare 10" Frame - Photos won't save to frame
If you are not able to find your connecting cable. and i am assuming your need is to transfer the data to comp. Well what you can do is you can take out the memory card and fix it into the card reader (you will get a card reader vey cheap anywhere.). and connect it to your comp. Now your card will work as a flash drive and you can transfer data easily then... Hope this helps you out.. :)
Feb 20, 2009 | Kodak EasyShare EX1011 Digital Picture...
I can't transfer pictures from my computer to my digital frame. When I connect my usb cable to my computer from my digital frame , the frame displays "Connected to computer. Use PC interface to copy files....
You can start copying pictures to SV811 digital picture frame if you get the message “Use PC interface to copy files.” Here are the steps:
Copy pictures, videos, and music between your frame and computer, using your computer's normal file copying tools:
1. Connect the USB cable from the frame to your computer
2. On your computer, open My Computer or Windows Explorer.
The picture frame appears as removable drives—one drive for each connected picture source in the frame, in this order: internal memory, memory cards, and USB devices.
3. Navigate to the pictures you want to copy. Then drag and drop them to the new location.
4. Unplug the USB cable to view your copied pictures.
Copying pictures from EasyShare software:
1. Install EasyShare software (free download at www.kodak.com/go/sw )
2. Connect the USB cable.
3. On your computer, open EasyShare software. Select the pictures in My Collection and drag them into the Picture tray.
4. In the menu bar, select File and then Copy to the Kodak Drive letter.
5. Select the frame source to which you are copying.
6. Select Best for Digital Picture Frame to reduce the resolution of the pictures you are copying. Full resolution is unnecessary and quickly fills up the frame's memory.
7. Click Copy. Pictures are copied to your frame.
8. Unplug the USB cable and press “Home” icon to navigate to your copied pictures.
Dec 26, 2008 | Kodak EasyShare SV811 (8858946) Digital...
I just purchased a frame and wondered the same thing. My computer has a slot for an SD card once inserted the computer shows the SD file. Then go into where you store the pictures highlight the picture one at a time in the picture file my program says copy to file click on it and shows the SD file as F file click copyit then downloads to the card. Done put SD card in frame worked perfectly.
Dec 18, 2007 | Nikon Coolpix 3200 Digital Camera
Cameras Logo
48 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
