Question about Amana NDG2330AW Gas Dryer
Dryer leaking - Amana NDG2330AW Gas Dryer
  • robertkenned Jul 29, 2009
    water-condensation dripping from back of dryer
  • Joseph Vernice
    Joseph Vernice May 11, 2010
    Please clarify. What is leaking? Hot air, natural gas, propane? Exhaust?
  • Amana Master
  • 8,220 Answers
Bubble test!
Posted on Jul 30, 2009
Leaking yellow fluid
Dog or cat peed on it. Or liquid is coming from washer. There is no liquid in a dryer to leak out.
Sep 11, 2014 | Whirlpool Dryers
I have a 2000 Dodge Durango with the 4.7, the problem is, the dryer leaks from where the a/c hoses connect, I have replaced the dryer, pulled vaccum for an hour, held vac for 45 minutes, recharged the...
are you sure the dryer is still leaking? i have seen many slow leaks from the seals on the compressor itself you may also have a leak from the evaporator in the dash i have had success using stop leak for the a/c system if you use stop leak make sure to run the a/c system for 30 to 45 minutes after putting it in
Aug 11, 2013 | 2000 Dodge Durango
Leaking oil underneath clothes dryer
My mom has a Kenmore dryer that is less than a year old. It leaks oil under front side. What can I do to fix it.
Jun 29, 2012 | Kenmore Dryers
Water under and around dryer. Clothes dry but water on floor. The wash not leaking. I the vent and line are not clogged. What is causing the water under dry?
Unless the clothes are dripping, soaking, wet when they're put in the dryer (and it would take them a loooong time to dry if that were the case) there's bound to be a leak of some kind coming from somewhere other than the dryer. Do you have a lavatory or toilet on the other side of the wall behind the dryer? They dryer has no water of its own to leak.
Dec 27, 2011 | GE DBXR463EDWW Electric Dryer
My dryer is leaking water from the bottom of dryer
Check the vent coming out of the back of the dryer. Somewhere in the vent there is a blockage. If you clear the blockage you may solve the problem.
Jan 07, 2010 | Abbaka White Knight 44AW Electric Dryer
Home Inspector detected gas leak coming from inside Dryer
The main valve in the burner may be leaking a little--if so, the valve assembly will need to be replaced. Did the repairman detect any gas as the home inspector did? Make sure the machine is level and does not rock in any direction that might fracture or loosen the incoming gas line. Have the gas supply company check for leak.
Aug 28, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Zanussi TC 7114 W Condenser dryer leaking water
Maybe it's the water collector's upper side which leaks...
Apr 15, 2009 | Zanussi TC7114W Electric Dryer
Hoove HM6316M Dryer not drying
Where was the water leaking from ?
Has it leaked onto the dryer electrical connections ?
You need to check if there is a circuit board behind the fascia panel.
please let me know these answers
good luck
Jan 25, 2009 | Hoover HW6 160M Front Load Washer / Dryer
Dryer leaks when operating.
yep...condensation,,,cold air is coming back down the exhaust vent,,while hot moist are is trying to get out..onthejob,,no flap out side on vent...
Jan 03, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Leaking tumble dryer
Well this sure is an interesting problem. First of all a dryer certainly should not be leaking anything. I would suggest that the "leak" is actually condensation from the exhaust not getting to the outside which would tell me that the dryer exhaust duct is plugged. This could also cause the electrical problem you mentioned. Turn on the dryer then go outside to where the dryer exhaust comes out of the house and see if there is warm moist air coming out. If not, disconnect the exhaust duct from the rear of the dryer and see if there is air blowing out of the dryer. If there is, then you know that the duct is plugged some where between the dryer and the outlet. Clear the obstruction and/or replace the duct and try the dryer again. Please remember to disconnect the power prior to removing any access panels on an appliance. Good luck, and let me know how things work.
Nov 30, 2008 | Dryers
Amana NDG2330AW Gas Dryer Logo
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you an Amana Dryer Expert? Answer questions, earn points and help others
