Question about Garmin GPS
My garmin 51lm won't turn on - Garmin GPS
Garmin won't switch off
Open unit disconnect battery and speaker wait 3-4 min Re connect battery while opened .This should reset and clear any faults. ..reassemble
Feb 06, 2013 | Garmin Edge 705 Handheld GPS Receiver
My garmin nuvi 1300 won't turn on
The Garmin Nuvi gps probably has halted to to either a software or hardware flaw. Sadly about the only way to bring it back may be to reset it to the factory defaults. Depending on your model, this might lose all your saved data.
Aug 24, 2012 | Garmin Nuvi 1300 GPS Receiver
My Garmin nuvi 295W won't turn on at all.?
Did you get the battery reinstalled correctly? The battery and a question mark means there's a battery problem.
Garmin Nuvi Gps
Aug 19, 2012 | Garmin Nuvi 295W 3.5 in. Car GPS Receiver
My garmin rino hcx won't upload satelites
Try performing a factory reset.
Be sure to save your favorites, routes, and waypoints before doing the reset as these will be deleted.
The factory reset is done with unit OFF.
Press and hold PAGE button and ENTER button and while holding the buttons turn ON the unit.
Reset is complete.
Dec 21, 2011 | Garmin Rino 530HCx 2.1 in. Handheld GPS...
When i turn the garmin on, it only says garmin on it and it won't go any further
Try doing a soft reset on the nuvi. If there is a reset button on the bottom, press and hold it until the nuvi powers back on. If it does not have the reset button on the bottom, slide and hold the power switch to the left for at least 10 seconds.
You could also try running the Garmin WebUpdater.
Download and Install WebUpdater.
If the problem cannot be resolved, it may be necessary to return the unit to Garmin to claim for warranty.
Sep 13, 2011 | Garmin nuvi 260W GPS Receiver
Garmin won't turn on
Try connecting it to your car adapter and holding the power button for about ten seconds till it starts.
Thanks for using FixYa
Jul 06, 2011 | Garmin GPS
My garmin turns on just fine but it won't allow me to push any buttons. How to I fix this?
There it should be a lock switch on top of the unit that prevents you from touching buttons by accident.
May 18, 2011 | Garmin Nuvi 680 GPS Receiver
My Garmin Colorado won't go past load maps....I tried new batteries and still no difference....please help before I throw it against the wall
I had an Oregon 200 and i had the same problem. It ended up the brightness was turn all the way off and then i locked it.
May 07, 2011 | Garmin Colorado 400t
My streetpilot c330 won"t shut off.
IT'S CALLED A FROZEN SCREEN...
2 OPTIONS
ONE, RESET IT !!! (See resetting instructions below)
TWO, let the battery die out!
Waking up your c330...
If you left your Garmin c330 on running the battery will have 1% life left. If you turn c330 back on again, it will flash screen for 3 seconds then die, even charging it at this point will not wake it back up. TO BRING IT BACK TO LIFE... plug in the power home or car into Garmin c330. There is a tab in the front Garmin gray frame of your screen. You must take like your fingernails and under the logo "GARMIN" pull the whole gray plastic frame off. Underneath the plastic frame to the right hand side. There is a "RESET" button. Make sure power is plugged in while hitting reset. Your battery should come back to life. Cheers
Mar 12, 2009 | Garmin StreetPilot C330 GPS Receiver
GPS Logo
27 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
