The heat works but the fan doesn't
More then likely it's the blower motor control processor , a electronic control module . Taking to a qualified technician an having it diagnosed would be your best bet. Has no relay ,no resistor block .
GMC Yukon HVAC Blower Motor Won Turn On
HVAC Blower Motor Circuit
Then you either have a blown blower motor relay or the blower motor itself is toast.
SOURCE: 2005 Pontiac Vibe heater fan working on high only
My 2005 Vibe did the same thing it was the heater resistor. It is located to on the firewall behind the glove box on the lower left side of the blower assembly. Two 5.5mm screws hold it in place (1/4 inch socket works too). I used a socket attached to a socket swivel to replace mine in under 10 minutes. Heater now works as good as new. I purchase mine online for $30 from rockauto.
SOURCE: Heat/AC Blower fan speed only works on High
hello, this sounds like a bad blower motor resistor!! its cheap and easy to change..if you need more info on locations let me know,, good luck.....marty
SOURCE: fan switch on 2005 Buick rendevous
ASE mechanic:
blower motor regulators go bad because of the switching between low and high speeds. some times these are under the dash and require tiny hands and lots of patience.
Alot of people have the same problem with the fan switch and blown bulbs. There really is no fix for this. Jeep really screwed up when designing the heater control assembly. The cheapest solution is to buy another unit off Ebay. Can always go to the dealer but be ready to PAY for there mistakes.
SOURCE: Heater/AC Fan does not work in our 1998 Buick Century
Fan will be under dash on passengers side , Removing glove box might be needed, Gm also uses a blower resister ro control fan speeds. First check your fuse and then check and make sure your getting 12 volts to the terminal at the blower, You could have a blown fuse, a bad switch, or a bad resister , if your getting voltage to blower motor then most likely it will be the motor. These are not to difficult to change. I hope this helps, please be aware I can only guess at what the problem is from my past experience.
