I do have iq300 machine and facing E-17 error. E17 error appear while Machine on cloths drying out specially on Mix/Hygiene Mode
  • 183 Answers
SOURCE: Error message F04
FO4 indicates a pump fault.
Posted on Sep 01, 2007
SOURCE: Solis Palazzo - stuck in descale mode?
Are you refilling the tank during this process? You need to let in run dry, and then the buttons flash. Then, refill the tank with clean water, and let the tank run dry again.
Posted on Feb 12, 2008
SOURCE: why wont my machine start drying?
I called Whirlpool on 08706008989. The machine can only dry half a load of washing at a time. At the end of the washing cycle, the Programme dial should be at either the sun or half sun symbol. Remove half the washing, set the drying time via the drying time dial and press the 1/2 Load Dryer button - Voila dry clothes!
Posted on Jul 14, 2008
  • 138 Answers
SOURCE: Machine Error 17 Brother
I am assuming that you error listed above is actually a "Machine Error 71" not a 17 as their is no such 17 error. The error 71 is a problem with the Polygon Mirror (laser scanner). The scanner is going to require replacement. The part is available at Seattle Platen, Dale 1-800-221-2388.
Hope that helps you.
Posted on Aug 30, 2008
SOURCE: F20 error code no water coming into kenmore he3t washer
The following provided by fixya has the solution to error F20.
Click here for detailing on F20 Error
Good luck and please do rate my answer.
Posted on Jan 17, 2009
How to fix error E17 code on eziset 9.5 kg top loader
Supply problem.
Check to see if water hose is plugged and test water pressure.Check water valve supply shut off.
See if filter is plugged.
Run full cycle w/no clothes in washer. Add 1 cup of vinegar,no soap.
May 03, 2014 | Washing Machines
Thor washer/dryer combo not drying properly. What is capacity of machine?
Whilst 'combos' will 'wash' a full load of clothes, they are not so good at 'drying' a full load. Since there must be a 'tumbling space' inside of the drum, into which the clothes can fall during the drying cycle.
In a 'nutshell' one 'wash load' equals 'two drying loads',
That's the price you pay for having a space saving 'combo' machine instead of having a 'washing AND a drying machine.
Add to that the fact that most 'combos' are 'condenser driers', as opposed to 'free flow outlet driers',
The consequence is that it takes far longer to 'wash and dry' a load of clothes in a 'combi' as oppose to two separate machines
Aug 21, 2013 | Washing Machines
Washing machine Siemens iq300 has error CL in display (status) & can't be used
This means that the door is not being closed. It might be a bad door switch.
Mar 27, 2013 | Washing Machines
What does E17 mean
hello there and welcome to fixya
the f-17 error code is activated by the water supply side meaning that the water fill solinoid may have failed or is not fully opening
thus the machine is sensing that there is not enough water pressure
so first check to ensure that the water inlet hose is not kinked and that the strainers at the ends of the hose is not clogged next reinstall the water hoses and ensure that the valve is fully turned on and getting good water pressure
now unplug the machine for at least 30 min to allow the computer to reset itself then plug it back in and retry and if the error code does appear again then you know that you may have a bad inlet solinoid fill valve ok
Please post me any wuestions that you may have
best regards mike
Feb 18, 2013 | Washing Machines
Stop halfway hygiene wash 90degree
Do you have power to the unit? Does the display light up?
Nov 28, 2012 | Washing Machines
How to open the door of the siemens iQ300 washing machine
This problem has nothing to do with water in the machine. My IQ300 regularly refuses to open on the drying cycle! You have to open the small round compartment beneath the door and pull down on the black plastic strap to the right - you may need a utensil to pry it out. What a rubbish machine.
May 29, 2011 | Siemens WIQ1633 Front Load Washer
Washing Machines Logo
168 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
