Question about The Watches
I need to be able to continue to watch the shows I was watching. S
Watch digital section has shut down while smaller part works
there are two batteries in the watch one for digital movement and one for analog it probably needs new battery
Mar 09, 2013 | Diesel Watch DZ7231
My Waltham watch has a foreign day listed before the numerical date. It wasn't there for the first 3 years I had my watch. I am an RN, and when pulling my gloves off one day, it accidentally pulled out...
some watches (like yours) can show two days and it would seem that you accidentally re-set the day when you took off your gloves.
Try pulling out the winder to the mid position (1st click) and then turn the winder slowly (anticlockwise?) to re-set the day. It should show the english day next and then the foreign date then english again and so on. Leave it set at the english day you want and it should continue in that manner.
Mar 06, 2011 | Watches
My prs200 watch stops now and then... replaced the battery but still continues to have this problem
Even the best watches need servicing time after time. Obviously there is no battery fault, but something related to mechanics or electronics in your watch. Get advice from watch repairer.
Nov 22, 2010 | Tissot PRS 200 Wrist Watch
Hi. my fossil automatic watch stopped working. any advice?
Have you left it off for a few days? If an automatic watch is not worn, it will stop after 2-3 days.
You can get it started again by gently swinging it from side to side for a few minutes. For continuous working it needs continuous wearing.
Oct 22, 2010 | Fossil Watches
Is it good to change watch movement to a battery ?Watch was overwound.
There is no such things as over winding a watch. If it is not an automatic watch then the watch will wind until it stops. If the watch does not run then something else is wrong.
If the watch is an automatic then about 30 winds will fully wind the watch. But, you can continue to wind the watch forever. It will never stop winding. Again, if it does not run after being wound there is something else wrong.
To fix your watch you need to have a qualified watchmaker repair it for you.
Hope this helps,
Ken
www.yellowstonewatch.com
Apr 08, 2010 | Kenneth Cole KC1104 Wrist Watch
The digital display shows the correct time but the hands do not.
hi there when you replace batteries in wave ceptors all hands have to be set to the home position (straight up at 12 oclock), as the instructions vary wildly from watch to watch you will have to download the manual from www.casio.co.uk you will need to put in the module number (found on the back plate of the watch), this will be in PDF format, you can download adobe reader for free from www.adobe.com to read PDF files. good luck
Aug 20, 2009 | Casio WVA105HDA Wave Ceptor watch
Buttons on casio pro trek watch stopped working -time still shows
Sounds like the solar back up cell needs to be replaced. You can get it repaired for rather cheap less that $30(US). You can contact www.casiosalesandservice.com to have it serviced. 877.659.0761
Jun 25, 2009 | Casio Protrek Triple Sensor Tough Solar...
The stop watch second and minute do not reset to 12 . Dallas
To reset the stop watch unscrew the stem and pull it out 1 click. Then press the buttom to the top of the stem and it will move the minute stop watch 1 minute continue to press to get it set to 12. Do the same with the bottom button to get the second hand stop watch to 12.
Sep 01, 2008 | Tag Heuer Formula 1 CAC1111.BA0850 Wrist...
Problem with the time setting
The only info which continually flashes is a dart and the letters chg
Feb 02, 2007 | Casio G-Shock G510D-1AV Wrist Watch
Watches Logo
20 people viewed this question
Top The Watches Experts
John mullen
D. E. Hev
 En Sukkert
En Sukkert
Level 1 Expert
Are you a The Watch Expert? Answer questions, earn points and help others
