My defy 1300 twinmaid washing machine spin dryer does not want to spin
  • 1462 Answers
SOURCE: hoover 1300 spin 5+5 washer dryer
you don't say which cycle it will start on. however, could be cold valve open circuit which also means no rinse or cold inlet hose kinked etc. can you give more info?
Posted on Apr 10, 2007
SOURCE: washing machine trouble
i've tried this but nothing fell out or stuck. tried on tumble dry and still doesnt spin on this. when hand spin it the wheel turns quite freely.
Posted on Dec 30, 2007
  • 1314 Answers
SOURCE: HOOVER LOGIC 1300
you need to access your drain pump and check it for an obstruction but when you pull the hose off keep in mind it might have a lot of water in it i usually use a shop vac and pull all the water out through the drain hose before removing the hose or opening the pump sorry i cant be more specific but ive never cleaned the pump on a hoover
Posted on Mar 23, 2008
  • 135 Answers
SOURCE: our hoover ultra care 1300 large load washing machine spin fault
The most common cause of machines stopping mid cycle is not draining. Your machine should have a filter behind the kick plate at the bottom.
If this is not the case please post back for further assistance.
Posted on Jan 22, 2009
blueextc3221
  • 15935 Answers
SOURCE: My washing machine Defy 1300 can't wash, u load
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 15, 2010
My defy twinmaid 1300 machine worked suddenly smell luje burn and swirch off now machine dont wanna go in
Nees to be taken apart and see what caused the burnt smell and look for a blown fuse.
Mar 02, 2018 | Washing Machines
Defy Laundromaid Electrologic 1300 wiring diagram
Contact Defy directly and request the wiring diagram.
Feb 26, 2018 | Washing Machines
Defy twinmaid 800 spinner rotate very slow
Wiring diagram for a defy Twinmaid 800 washing machiine?
howtomendit.com > Household Appliances, Washing Machines Free repair help - wiring diagram defy twinmaid 800 washing machiine. ... machine spins very very slow sometimes and sometimes it doesn't spin help please.
Jul 24, 2015 | Washing Machines
How do i fix the spinners knob of the defy 1000 twinmaid washing machine
Write your answer...i have a twinmaid 1000 defy.The problem is the spinner.When i turn the timer on,it makes the sound but it does not spin.What could be the problem?
Jan 10, 2015 | Washing Machines
Defy Laundromaid electrogenic 1300 drum doesn't
Possible blockage in the waste pipe stopping it from draining quickly enough or lack of water pressure getting in.
Sep 27, 2014 | Washing Machines
How can i remove the spinner drum from a defy twinmaid 920 (twin tub)? please help?
1)You have to tip the machine on it's back and remove all the screws from the bottom grey cover.
2)There are 4 screws securing the drain plug at the back. Remove these as well. Gently pry off the bottom of the machine.
3)The spin motor sits on four spring mounts. Undo the 4 screws from the top of the mounting plate.The motor shaft is not screwed to the drum. Slide the motor out of the drum shaft.
4) Once free, there are 2 X 10 mm bolts that lock in 2 grub screws on the shaft. Loosen these an remove the grub screws and remove this coupling off the drum shaft.
The drum is now free to come out the top of the machine.
Hope this helps
Jun 16, 2012 | Washing Machines
I have Defy Laundromaid 1300. I was getting an E9 message.
Hi, I get an OD (wording) on my machine after washing-dosnt rinse or spin... what can that be???
DEFY LANNDROMAID 1300M!!!
Sep 21, 2010 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
