Question about Tablets & eReaders
My tablet keeps shutting down when I turn it on even when fully charged and is no longer connecting to my WIFI. Only used it a couple months.
  • Ronald Ryan
    Ronald Ryan Dec 07, 2017
    Hi Sherrie Ash, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
SOURCE: new battery will not charge, shuts down
have you tried connecting it up, leave it for say 8 hours and don't use, try it then?
Posted on Feb 01, 2010
  • 35 Answers
SOURCE: I purchased this tablet a couple of months ago
Do you see the networks on you tablet? Ask at the campground where the wifi antennas are and go close. Somewhere in the settings for wifi you should be able to activate wifi if it isnt and then select wifi connection. They might have a login.
Good Luck.
Sorry im not that good with Android.
Posted on Jul 05, 2011
SOURCE: Micro Cruz Tablet Wont hold charge
Well, I think you should change the battery of your tablet PC. You must have charged the tablet for more than enough time several times. so the battery is damaged. or, the battery must be used for a long time!!!!!!
Posted on Jun 27, 2012
SOURCE: my tablet is froze it wont shut down it wont powder off
Get a toothpick and hit the reset button on the back or side
Posted on Oct 07, 2012
SOURCE: my mid tablet will not charge
your charger probably died. go out and by a new one and see if that fixes your issue.
Posted on Apr 02, 2013
My son's tablet is less than 4 months old and it keeps shutting off even when fully charged. It is a 9 inch nextbook and was purchased at Walmart.
Hold the volume UP botton down when it is OFF, then while holding that button down press and hold the power on button and keep both pressed for about 10 seconds. Then release.
Feb 23, 2017 | Nextbook Tablets & eReaders
Tablet keeps turning off while in use. Fully charged
Go into your settings and take it out of sleep or auto shut down mode.press the helpful button
Android Tablets Power Off and Sleep Options
Jan 26, 2016 | Visual Land Connect 9" Android Tablet...
My Tablet keeps shutting down, uses Battery quickly, won;t even find wireless, when it stays on long enough.
You neglected to provide the age of the tablet. If it's a couple years or older your battery might be on the way out. They don't last forever and some of them aren't of the best quality to begin with. Charge it all night long. In the morning when you turn it on if it still doesn't work right be sure to check the battery level with the A/C adapter unplugged. The level indicators are based on the voltage. If the voltage doesn't come up to spec, it might show less than 100% charge even when charged overnight.
The wi-fi problem could be battery related, too, as wi-fi is a radio transceiver that sends as well as receives signals. Wi-fi doesn't work so well if the transmitter produces a weak or intermittent signal.
Mar 08, 2015 | Ematic 7" Touch Screen Tablet
How to get my cromo inc tablet to power on after i factory reset it
Odd, but try this: Some tablets do not fully shut down, even though the screen goes blank. Hold down the power button for 30 seconds, wait 15 seconds, and then try again to power up (hold power button for 3-5 seconds). Wait patiently for the power up, as power after factory reset may take longer than a 'typical' start-up. Good luck!
Jul 18, 2014 | Chromo Inc Chromo AAAAAAAA White 4gb 7"...
How do I fix my tablet that won't fully charge?
Your tablet may need its battery calibrating. To do this run your tablet until it turns itself off, this will ensure that there is no charge left in the battery. Then leave it on charge until the battery is full. Normal battery use on modern devices like tablets and phones should be between 25-75%, with a calibration once every 3-6 months to ensure a good battery lifespan. If this solution does not work you may need to replace the battery.
Jul 07, 2014 | Visual Land Connect 9" Android Tablet...
Battery charing very slow, can't open tablet - won't turn on when button is pushed
The battery on the Asus does take a very long time to charge (over 12 hours before you use it the first time, then 8 hours or more each time). It takes even longer if you charge it from the USB port in a computer rather than connect it to its dedicated charger, or if you use it while it's charging. If you've already charged it for 8-12 hours, try turning it on by pressing the power button *and holding it down* for a couple of seconds before releasing it. Then, when using the tablet, try keeping it hooked up to the charger when possible, or at least recharge it overnight.
You can check on battery charge by tapping "Settings" at the bottom of the Home screen, then tap "Battery" in the Device category. The % charge will be at the top of the screen. I enjoy my Asus tablet, and it's good for several hours at a time between charges, but you do have to keep it charged up. Good luck!
Dec 18, 2013 | ASUS Transformer Book T100
Asus transformer T100T battery takes hours to charge & tablet won't turn on
So, greyhen2, we meet again. Here's the answer I gave to your other posting of this same question:
Dec 18, 2013 | ASUS Eee Pad Transformer TF101A1 Tablet...
Android tablet problems
Try going to system settings and select 'About Tablet' then checking you are fully charged and in good wifi signal select 'system updates' Update to any new version it finds.
Make sure it is fully charged with the screen brightness down (so it will last for hours, just in case). The last thing you want is a power down during an update...
Jun 05, 2013 | XO Vision Ematic eGlide 7Inch Touch Screen...
Tablets & eReaders Logo
47 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
