Question about Able Watches
Need to connect and be able to watch - Able Watches
I need a pin that connects the watch to the silver bracelet, where can I find one?
Best bet is a local jewelry store, bur often Walgreens and CVS will stock these.
Jun 08, 2015 | Watches
My watch broke and the main link piece that connects the band to the watch is missing how do i replace that piece to my watch my arm feels bare without my watch.
Hello collay1,
I understand what you mean.. You can just go to any watch repair center and they should have a spare part of what you need. Many people have had that kind of problem.
Nov 08, 2011 | Wittnauer Crystal 10L02 Watch for Women
How do you remove links from a casio watch strap S-1183DV on watch WV-59DU ?
You will need to hold the watch firmly in your hand, with the side pointing up. Make sure that you can grip it firmly. If you have trouble holding onto the watch, place it on a stable surface. Make sure that the side is facing toward the ceiling and locate a connecting pin. There will be a connecting pin on each link of the watch band. Select a link, and hold the eyeleteer over the connecting pin for that link. Carefully place the eyeleteer onto the connecting pin. Push gently but firmly until the connecting pin slides partially out the other side. Occasionally, the pin will be difficult to push through the slot. If this is the case, gently tap it though with a standard hammer. Using a pair of pliers, pull on the connecting pin carefully until it slides out. Keep a firm grip on the watch band so that the links do not come apart before you are ready for them to. Separate the Casio watch band. Repeat this process with additional links until the watch band is as small as you would like it to be. Reconnect the band by tapping or pushing a connecting pin into the band where it is disconnected.
Aug 06, 2011 | Casio Watches
How do you get a new watch band connected to the watch?
mcdevito75 Here, You"ll need a tool called a spring bar remover tool available on ebay, but by the time you get the tool you can have a small watch repair shop in your area replace the band and for about the same money as the tool.
Feb 05, 2011 | Kenneth Cole KC3289 Wrist Watch
How to restart watch after changing battery
You will likely need to get back into the watch and connect the battery to the "AC" in the watch with a pair of tweezers. Connecting these once or twice for a few seconds should reset the watch and allow you to set it.
Oct 16, 2009 | Casio OC500 Oceanus watch
10L02 Wittnauer watch~need band screws that connect link to link
If you can get to a watchmaker or even one of those watck "kiosks" where they mostly replace batteries or even a jeweller they may have what you need.
Jul 18, 2009 | Watches
Connect metal strap to watch
If it brok at the hinge where the strap connects to the watch itself, then you might just need to replace the clip that slides in. Its a little metal tube with a spring in it. You should be able to find them at any retail shop. If all else fails, take it to a shop or jeweler.
Mar 11, 2009 | Swiss Army Wenger Sportedge Bracelet Watch
Watch strap adjust
Not all watch bands are adjustable. If yours is, you will see the links are connected with tiny pins. Any store that sells watches will have the tool to remove links. Some watches require a special tool, those need to be adjusted at a store that sells that brand.
Nov 06, 2008 | Watches
ABX-66
On most casio watch you can see AC (all clear) point , youy need to resset clock connecting this point with + on battery about 5 sec.
I have same problem but on my watch I do not see AC point. :)
regards
ststefan
Aug 14, 2008 | Casio Twincept Databank ABX238BV Wrist...
Watches Logo
21 people viewed this question
Top Able Watches Experts
NOEL
NOEL
john h
Tom Chichester
Are you an Able Watch Expert? Answer questions, earn points and help others
