Question about Dell Inspiron 6000 Notebook
No boot sector on internal hard drive. No bootable
This message appears after turning machine on:
No boot sector on internal hard drive. No bootable devices--strike f1 to retry boot, f2 for setup utility.
  • 2 more comments
  • Lynn Bradley Jul 29, 2009
    First Try Unsuccessful: hit F10 after turn on.
    Also tried Function F10 At turn on NO JOY.
    Also tried Holding F10 down and turning on NO JOY.
    Any other suggestions?
    What will I lose by hitting F11 and doing a Full Factory Reboot?
    Have tried with no success the F10 on startup.
    Am not sure what I'll lose if I do F11 the full factory reboot. Until I can recover all data, I'm not willing to do the F11 reboot.
    On startup > Dell Screen > Windows XP Screen >
    "No Boot Sector on Internal Hard Drive" message.
  • Lynn Bradley Jul 30, 2009
    Yes.
    Gonna try it out.
    Sounds most promising.
  • 336 Answers
A boot sector is a sector of a hard disk that contains booting programs stored in the other part of the hard disk. You boot sector might have been deleted or corrupted and you can't logon until you repair or recover the boot sector. To do this you must have your OS cd. Boot from OS cd the follow below steps...
Windows Vista
1. Insert the installation disc.
2. Restart your computer
3. If prompted, press any key to start Windows from the installation disc.
4. Choose your language settings, and then click Next.
5. Click Repair your computer.
6. Select the operating system you want to repair, and then click Next.
7.
On the System Recovery Options menu, click Startup Repair. Startup Repair might prompt you to make choices as it tries to fix the problem, and if necessary, it might restart your computer as it makes repairs.
Boot from you hard disk then you're done!
Regards,
Jeep Brainy
Posted on Jul 29, 2009
  • 305 Answers
Try F10, when you turn on,
  • jim galbraith
    jim galbraith Jul 29, 2009
    the only other thing i can think of is a full factory settings re-boot........hit F11 on start up
  • jim galbraith
    this takes the pc back to original factory settings, its like starting up all over again from new........but as it will not boot up just now, then you have lost everything already....i know this may sound drastic, but i had the same problem, i tried 3 computer programmers, who had my laptop for a total of 4 weeks....this is what they all ended up suggesting... and this is the very laptop i am using now.....im not saying this works for every pc, but it was recommended to me, and it worked, but if your unsure, then think hard about a full re-boot
2 Suggested Answers
  • 916 Answers
SOURCE: Won't turn on
No bootable device usually means that your hard drive has failed. It is either not connected properly to the computer or the drive needs to be replaced.
Posted on Oct 27, 2009
Computer does not boot:
Press [F2] when you see the message, and see if it will enter the BIOS. See if it detects your Hard Drive....it does not appear to.
you may have a bad hard drive or a corrupted boot sector. Take to a repair shop and they can test the hard drive for you.
Sep 04, 2012 | Acer Aspire One Netbook
I need some help pleas my harddisc keeps blinkin whats wrong its not workin
There are several types of damage to your hard drive
1.
When the computer is turned on, audible sounds, from hard drive. See the video and
This means, your hard drive optical is damage (heavy damage on the hard drive)
2. Hard drive not detect.
When the computer is turned on, a message appears "Disk boot failure, insert system disk ...." - see the abdulkarimap.jpg
Solution :
Hard drive ATA
move the jumper from Master to Slave, or the other.
Move the serial cable, from ATA1 to ATA2. Or replace the serial cable
Hard drive SATA
Use a jumper, on the hard drive SATA
Move the SATA cable, from SATA1 to SATA2. Or replace the SATA cable
3. Hard drive bad sector. To fix hard drive bad sector,
use the software HDD Regenerator Bootable CD. Create, HDD Regenerator Bootable CD, restart the computer and boot from Cd Room. To repair hard drive bad sector, see the video .
Sep 23, 2011 | Computers & Internet
My toshiba satellite A215-S5837 when trying to bootup gives error message cannot boot do you want to start from last good boot. I say yes it still does not boot just goes so far and then I get clicking...
once you get a bad sector it usually spreads like a virus through your hard drive. the best thing to do is to buy a new hard drive, install it and do a clean install of windows. you can buy or borrow a hard drive enclosure and rescue your documents from your old drive but isolating the bad sector doesn't work, especially if your drive is making a noise
Jan 13, 2011 | Toshiba Satellite A215-S5837 Notebook
Won't turn on
Oct 27, 2009 | Dell Inspiron 1521 Laptop
''No boot sector on internal hard drive'' message on INSPIRON 6000
It does sound like the hard drive has died but the only sure fire way to check that is to remove it and try it from a proper PC using a cheap 2.5" enclosure.
If a normal PC can read it then it is more likely to be the hard drive controller on the motherboard which can be an expensive repair.
You can always get another drive if yours is pooched and you are not limited to the same size, You could get a larger one
You will however need an operating system.
Aug 14, 2009 | Computers & Internet
"no boot sector on internal hard drive"
i think you need to re-install your Operating System again since you got a new HDD wich is tottaly empty i assume so try to install your OS on the new HDD
let me know if it helped
greetings
Jan 02, 2009 | Dell Inspiron 6000 Notebook
I have emachine t5010 not booting. I receive error message
This means the system can't read from your hard drive. This might be due to a loose data or power cable connection. You can open the computer and make sure all the connections are firmly seated. It might also be a power supply problem. The hard drive may have failed. Or the drive may been wiped clean (or at least had its boot sector destroyed) as the result of a virus. A problem on the system board might have developed. Troubleshooting would involve booting from a CD to run diagnostic software, substituting known good parts, or both.
Dec 19, 2008 | E-Machines T5010 PC Desktop
I cant identify the prolem
It looks like you may have a boot sector virus. A boot sector virus is one that infects the first sector, i.e. the boot sector, of a floppy disk or hard drive. Boot sector viruses can also infect the MBR. All disks and hard drives are divided into small sectors. The first sector is called the boot sector and contains the Master Boot Record (MBR). The MBR contains the information concerning the location of partitions on the drive and reading of the bootable operating system partition.
When disinfecting a boot sector virus, the system should always be booted from a known clean system disk. On a DOS-based PC, a bootable system disk can be created on a clean system running the exact same version of DOS as the infected PC. From a DOS prompt, type:
    SYS C:\ A:\
and press enter. This will copy the system files from the local hard drive (C:\) to the floppy drive (A:\).
If the disk has not been formatted, the use of FORMAT /S will format the disk and transfer the necessary system files. On Windows 3.1x systems, the disk should be created as described above for DOS-based PC's. On Windows 95/98/NT systems, click Start | Settings | Control Panel | Add/Remove Programs and choose the Startup Disk tab. Then click on "Create Disk". Windows 2000 users should insert the Windows 2000 CD-ROM into the CD-ROM drive, click Start | Run and type the name of the drive followed by bootdisk\makeboot a: and then click OK. For example:
    d:\bootdisk\makeboot a:
Follow the screen prompts to finish creating the bootable system disk. In all cases, after the creation of the bootable system disk, the disk should be write protected to avoid infection.
Once the OS loads, run your anti-virus software and it should clean the virus.
Should this not help, I'm afraid the only other alternative would be to reformat the HDD and reinstall XP again from a bootable disc.
Hope that helps..
May 07, 2008 | Computers & Internet
Dell Inspiron 6000 Notebook Logo
489 people viewed this question
Alun Cox
