Question about Porter Cable 332K Quicksand Random Orbit Sander W/ Case
Sander suddenly stopped orbiting. It now only spins at high speed, causing burning and grabbing
    President:
  • 1,996 Answers
There's a belt in there that may have broken or slipped off its track. That's just about all that can go wrong, unless a bearing seizes. You can see an exploded parts view with part numbers here, and download an instruction manual with some photos here that will help you to sort it out.
If you click on the parts numbers (in the list) you'll be able to check availability and/or order them...There's also a link to service centers if you're not comfortable doing the repair yourself.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Jul 29, 2009
My hitachi sv13ya done? My sander turn on spins but as soon as i try to sand it stops spinning. It has no torque. Is it done or can it be fixed
There is a ball bearing bearing on position 29 that is dirty replace it or remove and clean it open the sealings with a very little thin screwdriver solvent it out and re grease it and close the sealings again.
Hitachi SV13YA 5 Variable Speed Random Orbit Finishing Sander Parts
Sep 23, 2015 | Sander Tools & Hardware - Others
What is happening to my Dewalt DW421 spinning fast, but no random orbiting motion.
Probably need to replace bearing 6202. I took mine apart, dissambled the retainer and used PB Blaster on the bearing. It seems to be a short term fix. At least it's not operating at hyper speed anymore. Long term, I probably need to replace the bearing and maybe a new lower retainer if I can't press the bearing out.
May 25, 2013 | Dewalt DW421 5'' orbital sander
Porter cable model 333 will not orbit and spins at a very high speed. I do not have a manual.
there is a belt from the motor to the pad that has apparently broken. Go to dewaltservicenet.com and you can download both the parts breakdown and the operators manual. If I have helped you would you please vote accordingly and thank you
Sep 06, 2011 | Porter Cable 332K Quicksand Random Orbit...
Orbital sander doesnt orbit!
Never start the Sander without first placing it against the surface to be sanded. In free air the Sander will not osolate.
Jun 12, 2009 | Makita BO5010 5" Random Orbit Sander
3725Bosch 5" random orbit sander, loss of power!!
The 3725 had an overlap winding problem in the armature allowing no full power under load, I replaced mine three times before getting a good one, best 5" on the market tho.
Jun 07, 2009 | Bosch 3725 Devs, 5" Random Orbit Sander,...
Porter Cable Random Orbital Sander rotates but does not "orbit"
Just solved my problem with Porter Cable 333 orbital sander which just groaned. I thought the worst. I carefully took it apart on the garage floor and immediately suspected it needed lubrication as the motor turned hard. I used my flexible long plastic tube lubrication and put some on the bottom bearing shaft the best I could. I worked it around and around. I began to feel it turning easier. I applied more oil and kept moving and it became completely free. I put a drop on the top bearing even though it was loose. I put it all back together and it works like new. Lesson: do not look for the worst when a tool quits. Suspect the culprit to be lack of lubrication!!!
May 20, 2009 | Porter Cable 332K Quicksand Random Orbit...
Putting Sanding paper on makita sander
A makita power planer is just what it says, a planer. It has blades that spin at high speed and remove a thin layer of wood with each pass. The orbital sanding sheets go on another tool called an orbital sander. Write back if you find the sander and can not figure out how the sheets go on it.
May 02, 2009 | Makita 9404 4'' x 24'' Belt Sander
ORBITAL sander screeching (NOT belt sander!)
No, sounds like a bad bearing. But depending on who made it parts may be available. Don't know if it helps but I use a co. called GRAINGER, they are pretty helpfull. good luck.
Apr 26, 2009 | Tools & Hardware - Others
Makita 5" Random Orbit Sander
The armature windings have an overlay problem in the wiring causing this and there is no soluation except to replace the armature which is not cost efective unless you are still under Warrantee and get a free replacement, it will burn up at some point. If you bought it within the last month take it back and get a new one, over one month, pack it back up in the original box and send it to address in the owners manual for repair or replacement service addresses.
Feb 19, 2009 | Makita 5" Random Orbit Sander
Disc pad stops
It could either be that the brushes partially burned I would check to make sure your brushes are in good shape and take it out of the helpers pay ;)
Nov 06, 2008 | Porter Cable 332K Quicksand Random Orbit...
Porter Cable 332K Quicksand Random Orbit Sander W/ Case  Logo
238 people viewed this question
Top Porter Cable Tools & Hardware - Others Experts
John Trevino
T bone 1963
Are you a Porter Cable Tool and Hardware - Other Expert? Answer questions, earn points and help others
