Question about Mongoose Bmx Bicycle Brake Lever Bike Part 112
How are the front brake on a rebel adjusted - Mongoose Bmx Bicycle Brake Lever Bike Part 112
  • 29 Answers
There should be a knurled barrel adjuster on the brake lever. Unscrew it some and your brakes should "tighten." When you have 'em where you want 'em, screw the lock ring (the big round thing on that barrel adjuster) back down against the brake lever, locking it in position.
If you can't get it tightened enough that way, you'll need to take slack out of the cable at the brake itself. Loosen the nut that holds the end of the cable in place and pull the cable tight, then tighten the nut back up. You can then fine tune using the barrel adjuster on the brake lever.
Posted on Aug 06, 2009
Need to know how to fix front & back brakes on a
Try adjusting the cable by either turning the barrel adjusters, or simply loosen the screw that holds the cable to the brake and move it to make it tighter. Make sure your brake pads are making good contact on the wheel rim.
Sep 06, 2014 | Cycling
How to adjust front brakes on suzuki intruder
How do you mean adjust the front brakes, these arhydraulic and dont have adjusters, when worn out replace them, dead easy.
Jul 27, 2014 | Suzuki VS 800 Intruder Motorcycles
2002 siloquette, front brakes,
There are NO adjuster screws on a 2002 Olds Silhouette front brake. Only slide pins and bracket bolts. The brake calipers are self adjusting.
Apr 26, 2014 | 2002 Oldsmobile Silhouette
Need to adjust front brake pads
There is an adjuster where cable enters brake caliper
Also you could loosen mounting bolt. Realign and tighten.
Apr 09, 2014 | Trek 3700
Adjusting 2007 aveo rear brakes
do not attempt any adjustments. replace the front brakes when they need it. if you try to adjust the proportioning valve you will lock up your back brakes and risk loosing control of your vehicle. you risk ruining the ABS system in your car which will cost you far far more to replace than a cheap set of brake pads. the front brakes do most of the stoping, that is why they wear out much faster than the back brakes. it is VERY IMPORTANT that you DO NOT attempt to adjust your brake proportioning valve.
Mar 08, 2012 | 2007 Chevrolet Aveo Sedan
I HAVE A ROAD BIKE SHIMANO 7 GEARS WHAT IS THE BEST WAY TO ADJUST THE FRONT MECH SO THAT I CAN **** TO THE BIG CHAINRING AND ALSO TO THE SMALL CHAINRING. MY SECOND QUESTION IS ABOUT THE SHIMANO MECH DISC...
Park tools has a great online bike Matanance guide. Use these links to adjust your derailer and brakes. http://www.parktool.com/blog/repair-help/front-derailleur-adjustments http://www.parktool.com/blog/repair-help/categories/brake-service-and-repair To adjust your brakes, look at the page and use the article that best gifts your brakes. Unless you have REALLY nice brakes, you have mechanical brakes.
Jul 22, 2011 | kona-mountain-bikes Kona Bicycle Co. Dew...
Adjusted chain, adjusted rear brake almost to limit back brake still seized do I remove adjuster arm off of drum and reposition arrows so they meet? and is there a special way to accomplish this?
Don't reposition the adjuster - replace the brake shoes ... they are worn beyond their useful life. That is the purpose of the arrow. Not changing the shoes will cause damage to the drum causing you the needless expense of replacing the entire wheel.
Thanks for your question @ FixYa.com
May 16, 2011 | 2004 Honda CMX 250 Rebel
Honda rebel running very rich, how to fix it?
First, make sure your air cleaner is not plugged or dirty. This will cause a rich mixture. Next make sure the choke is completely off when bike is running. Gas is not leaking past the choke plunger seal. If the mixture needs to be adjusted , it is the screw under neath the carburetor, up front by the intake manifold. Before making any adjustments, count the number of turns IN, before the air screw seats lightly. This should be the factory setting. Call a dealer and find out what the standard setting should be. Start there and make minor adjustments(1/8 turns) till you get the spark plug color you desire.
Aug 30, 2010 | 2004 Honda CMX 250 Rebel
To adjust back brakes
The best method for adjusting your rear brakes assuming that they are of drum type, is to jack up the rear axle one side at a time and remove the rubber cap on the inner brake plate.Block your front wheels forward and rear. Then with a brake adjustment tool available at most auto part stores, turn the adjuster in the "only" direction that it will turn. The vehicle must not be in park to do this, so make sure she's on level ground. Once you've done this, spin the tire of the wheel you are working on and adjust the brake until you feel a slight drag on the tire. You can also listen to hear the brake shoue touching the drum. You also might want to have someone press the brake pedal occasionallly to "center" the the shoes. Thank you, Dana
Mar 04, 2010 | 1999 Chevrolet Malibu
2009......rebel 250.....I have a ticking in the front of my bike...around the engine.What is it and how do i fix it?
Have the shop check and adjust the valve clearances. Too much clearance causes a tapping / ticking sound.
Nov 19, 2009 | 2004 Honda CMX 250 Rebel
Mongoose Bmx Bicycle Brake Lever Bike Part 112 Logo
197 people viewed this question
Top Mongoose Cycling Experts
Michial Gueffroy
Jim Goldsmith
Jim Goldsmith
Rommel Balcita
Are you a Mongoose Cycling Expert? Answer questions, earn points and help others
