Question about General Filters 1137 Humidifier
Fuel filtrer. i'm trying to find where it is located on 1991
Fuel filter. i'm trying to find where it is located on 1991 nissan 300zx nonturbo to replace
    Problem Solver:
  • 4 Answers
Fuel travels from the gas tank in the rear via the pump located in the tank. The fuel line travels under the driver's side of the car up into the engine bay, then enters the fuel filter, which is located on top of the driver's front fender in the engine bay. It's about the size of the bottom of a beer can and then the fuel heads on into the injection system on the engine.
'robzzz' (www.twinturbo.net)
Posted on Sep 21, 2009
I have a miniature personal humidifier that I purchased from Avon several years ago. I'm needing to replace the filter in it. Where can I find those filters?
Nothing comes up on the Avon website concerning a humidifier, so most likely it has been discontinued. Couple of things you can try.
First try contacting Avon to see if they can provide any guidance. https://www.avon.com/contact-us
Most likely you will not get any usable answers from their customer service, so,
Second, I would try locating an appliance repair shop in your area. It's possible that this unit was manufactured for Avon by a manufacturer still in business and the filters are still available under their name.
If not, it's still possible to buy filter material and "make" a filter that will work (after all, it's just foam, cut into a specific thickness, density, length and width). This is were a local appliance repairman could be valuable. They can be very creative. Good luck,
Apr 28, 2016 | Humidifiers
Cant find filter
Maybe this picture can tell you the location of fuel filter ,hope help.
Feb 04, 2014 | Robitussin Cool Moisture 1 Gal. Humidifier
No water flow
if you hear the solenoid click then you may have a clogged orifice or prefilter. these are both located near the solenoid. the orifice is usually in the feed tube and the filter is in the inlet of the solenoid. Try the orifice first to see if it is clogged. If that is clear the try loosening the compression nut before the solenoid to see if you have water coming to the humidifier some times if a needle valve was used they get bad also. I would recommend changing the needle valve out and putting in a proper side stop valve. Most municipalities do not allow needle valves per there codes.
Oct 31, 2013 | Aprilaire 600 Humidifier
I have a Cool Mist V3500 humidifier. The fan
TRY POURING IN SOME WHITE DISTILLED VINEGAR AND RUNNING IT. THE VINEGAR LOOSEN UP ANY SCALE AND JUNK. AFTER RUNNING UNIT FOR AWHILE, DRAIN OUT ANY REMAINING LIQUID AND ADD DISTILLED WATER OR FILTERED WATER. RUN UNIT AGAIN. THEN DRAIN OUT ANY LIQUID. NOW THE UNIT SHOULD WORK AS NORMAL. IN THE FUTURE, TRY USING DISTILLED WATER OR FILTERED WATER.
Dec 13, 2009 | Vicks Cool Mist V3500 Humidifier
Changed filter for Aprilaire 600, but water doesnt flow now, how correct?
YOU SHOULD HAVE BETWEEN .250 TO.375 INCH WATER LINE ENTERING YOU'R HUMIDIFIER .THIS WILL TERMINATE AT A FLOAT VALVE.THIS IS MUCH LIKE THE VALVE IN YOU'R TOLIET.TRY PUSHING THE ARM DOWN,THIS SHOULD LET WATER INTO THE HUMIDIFIER,AS PULLING UP SHOULD SHUT IT OFF.IF THIS DOE'S NOT WORK THEN THERE (SHOULD BE A VALVE BETWEEN THE HUMIDIFIER & THE SOURCE)MOST LIKLY LOCATED NEAR YOU'R HOT WATER HEATER.MAKE SURE THIS VALVE IS ON!!! IF I'M RIGHT YOU MAY HAVE JAMED THE FLOAT IN THE OFF POSITION WHILE REPLACING THE FILTER HOPE THIS WAS SOME HELP>
Nov 06, 2008 | Aprilaire 600 Humidifier
Cleaning the filter
Here is the link for your manual:
http://www.hunterfanhq.com/hiw-prod/orderinv/frames/ps_frame.htm
How to clean your filter:
The PermaWick™ Filter should be cleaned in a vinegar and water solution to remove any mineral buildup. Place in a solution of one (1) gallon of water and eight (8) ounces of undiluted white vinegar. Allow the filter to soak for 20 minutes.
After soaking, rinse it several times with clean water. Place the PermaWick™ Filter in a location where it can drip dry while you clean the other parts of your humidifier.
They say the frequency that you will have to clean your filter depends on yoru quality of water. The harder the water you have the more you will have to clean it.
Good Luck.
Mar 12, 2008 | Hunter 33202 Humidifier
Install HE220 HoneyWell , humidity not increasing in the house.
You can try installing the water line to your hot water if it is installed on cold line for more humidification. You should make sure your humidistat is up line 6" @least from humidifier for proper humidification measurement.
Feb 26, 2008 | Honeywell HE220A1019 Whole House...
Replacing filters in a kenmore 14416 model humidifer
There are 2 filters on each side. They are simply stood up right in the tank and the Black Circular fan shields rest on top of them to keep them in place.
Feb 17, 2008 | Kenmore 14416 Humidifier
Honeywell HCM-525 owners/operation manual NEEDED PLEASE!
The filter should be located below the tank. the tank should lift off of the unit and there should be a rectangular cavity where the filter fits. You will most likely find the old filter dried up and filled with a white crust. That is salt and other minerals in the tap water that the filter catches.
Jan 01, 2008 | Honeywell HCM525 Humidifier
New filter
I have been unable to find your manual.
But, on Emerson's own site they have this posted:
If you cannot locate your model in the available download manuals, please contact customersupport@rgccanada.com
I would contact them and ask for a manual.
Good Luck.
Dec 20, 2007 | Emerson HDC12 Humidifier
General Filters 1137 Humidifier Logo
55 people viewed this question
Top General Filters Humidifiers Experts
paulcarew
jdthefixer
Steve
Are you a General Filters Humidifier Expert? Answer questions, earn points and help others
