Question about Honeywell Electronic Programmable Heat/Cool Thermostat - CT3300A100 Heater
Nothing working, unknown errors
I'm not sure my model number because i can't find it as escribed by the search function (why this company can't simply list the model # in an obvious place is beyond me). I see some mechanically printed numbers along with 'Made In Taiwain' that read T7300F2184, this isn't listed as a model number anywhere though..
Anyways, the AC isn't working (or anything really), but its 85°F and i'm sweating just typing. I set all the programs to begin at 1 or noon and put temp to 65°F but it doesn't do anyhing (It's been 5 days now). If I press temp occupied button it says 'override', if I press the continuous unoccupied button it says 'hold' . Sometimes it won't let me change the Fan option but other times I can only cycle between on and auto (I swear there used to be an 'off'). The fan seems to be on very midly in a back room but it's not cold air (and it might even be hot, I can't tell cause its so damned hot in here).
If I select a system setting it doesn't do whatever function it's told and sometimes it shows the little snowflake icon and sometimes it says wait indefinitely.
  • Honeywell Master
  • 1,870 Answers
Sounds like the tstat, obviously, isn't responding. A sure check is to bypass the tstat. Turn power off to airhandler and remove cover. Remove red, green and yellow wires and wire nut/ twist together. Turn machine on and see what you get. If inside and outside turns on...bad tstat OR just not setup properly. EVEN THE PROFESSIONALS READ THE INSTRUCTIONS THESE DAYS!!
Posted on Mar 04, 2017
machtcl1
  • 61 Answers
SOURCE: heater comes on at 5:10 am prior to the programmed setting
Access the installer setup menu (You will need the installation manual from the t'stat to do this) and turn off the "intelligent recovery" feature. This feature turns the equipment on in order to bring the conditioned area up to temp at the set time. Or you could set the "wake time" to 6:50!!!
Posted on Dec 16, 2008
  • 70 Answers
SOURCE: Thermostat seems to be working, furnace does not always turn on
Joss sounds like the anticipator setting on thermostat i would replace it with a digital it will be more actturat . The furnace has to go over temp setting to turn off
Posted on Jan 18, 2009
  • 70 Answers
SOURCE: Furnace not cycling properly
sounds like the flame sensor needs to be replace. You can try cleaning it with steel wool. This will get you by for a little while.
Posted on Jan 20, 2009
clyde2j2
  • 137 Answers
SOURCE: Honeywell programmable Thermostat won't hold time or program
Most thermostats use a six volt transformer for a power source, similar to a door bell, you can tell if yours does by looking at the wires that are attached to the thermostat.
The wires will be thin with just a single strand if you have these wires then you have a transformer, try and find the transformer (good luck) test it with a voltmeter if it fails the test that's it, if not, call the man. Probably it though.
Posted on Feb 15, 2009
  • 27 Answers
SOURCE: The fan on my central heating system keeps running
IN MOST PROGRAMMABLE STATS THERE IS A FACTORY DEFAULT PROGRAM.IT COULD BE
RUNNING IN THAT MODE.FIRST,CHANGE THE BATTERIES IN THE STAT.ALSO,THEY HAVE A
RESET BUTTON ON THE CIRCUIT BOARD.TRY THAT.AND,BY THE WAY,YOU ARE NOT SAVING
ANY MONEY BY DOING A TEMP SETBACK.THE HEAT SYSTEM WILL USE JUST AS MUCH
FUEL EVERYDAY TO RECOVER THE LOST HEAT DURING THE SETBACK PERIOD.ALSO,THE STAT COULD JUST BE BAD.
Posted on Mar 07, 2009
Como puedo program mi control universal a mi television Philips Es un control TS-CR411?
If your remote is universal, it should have a CODE SEARCH (or equivalent) feature that lets you search through all the codes stored in it to find one that can manage some or all functions of your Philips TV. If a search through all codes stored in the remote fails, you may have to try a different universal remote. All universal remotes do not have all possible codes.
Lo siento yo no escribe en Espanol!
Jan 28, 2016 | Televison & Video
My water heater error code 1 model ee3250rd055v what does this mean
Water heater is not 100% identified.
Unknown if this is gas or electric heater.
Problem posted under Whirlpool water heaters typically made by American water heater company.
Call Whirlpool 877-817-6750.
They will ask for model number and serial number located on label on side of tank.
Call is answered in USA by trained person who can answer specifics about that model, including warranty, age, regular maintenance, error codes, and possible solution for that specific model and serial number.
I have found these folks to be helpful.
Whirlpool manuals do not show that specific model:
http://www.whirlpoolwaterheaters.com/support/manuals.aspx
If you have the energy smart electric water heater with electronic control board, then error code explanation shows on the control board. Error 1 or a single flash, is start-up failure and requires tank to be full of water. Read page 10 of manual. Make sure water heater is full of water and water is coming full stream out of tub spout before turning on power. Also disconnect power from unit, make sure water heater is full, and then reconnect power to see if unit resets.
http://waterheatertimer.org/Whirlpool-Energy-Smart-electric.html
http://www.whirlpoolwaterheaters.com/downloads/6510306.pdf
Sep 12, 2011 | Whirlpool Water Heaters
Logik lbd 2000 region free hack code
Hello
Go to a website such as http://www.dvdhacks.co.uk/ to find DVD hack codes. The players will often be listed by the company name first and model number second. If you can't locate your DVD player on the website, type the model number and the company into a search engine to see if any other sites have the hack there.
Now, you simply follow the steps on the website
Oct 02, 2010 | Televison & Video
Every time I on my PC it appears in screen unknown bios error. error code 8302 press f1 to resume
You need to flash your bios before it becomes totally corrupted. You are losing small bits of information that your motherboard needs to continue functioning.
I have what i believe is the proper page for your bios, but your exact model doesn't show up when I search the site, so the best solution for your problem is the MSI live bios update located at the bottom of this webpage:
http://www.msi.com/index.php?func=downloaddetail&type=bios&maincat_no=1&prod_no=1150
Simply install that and allow it to automatically fix your bios for you.
Aug 05, 2010 | MSI P4M900M-L Motherboard
Phone takes forever to load up and always says unknown number when recieving calls
Welcome to Blackberry!
Unknown calls would be due to the carrier not the phone. loading times is a blackberry worse nightmare is why I switch to Iphone anyways the only solution for a unknown call is to have the caller have is number displayed. Tmobile is the worse company in God's creation for this unknown call issue and has absolutly nothing to do with your phone. If you do not like the load times I think you need to look into a btter phone. Welcome to blackberry!
Aug 10, 2009 | RIM BlackBerry Storm 9530 Smartphone
NO SOUND DRIVER FOR PACKARD BELL EASYNOTE ON XP
Hello i know how it is to search for drivers. It is a pain in the neck!!! now because you do not have your computers model number and because i do not have access to your computer to see it for myself i cannot really do much. However I can reffer you to a very powerful tool known as Unknown Device Identifier, this software will find every piece of hardware attached to your PC it looks exactly like windows Device manager. all you simply have to do is run the software and look down the list untill you see a device labeled as unknown then to the left of this Unknown device you will see a + sighn, simply click this and detailed information about your unknown device will then appear just beneath it. simply read the detailed information and it may even be able to give you your driver model number so then you can just google it and download your drivers. Here is the link to the Unknown Device Identifyer.>
http://www.zhangduo.com/udi.html
read the page before you download it if you want to because it has detailed information on exactily how it works and what it does i also belive that in the new version it may be able do download the driver for you. anyway I hope this is some help to you Good luck but im really shure that the unknown device identifyer can help you out.
Jun 18, 2009 | Computers & Internet
Typing wrong letters and numbers
make sure the ribbon and corr. tape are on the other side of the metal fingers in front of the cardholder, and nothing is interfering with the free rotation of the printwheel. you can check this by turning the mach. off and carefully turning the printwheel by hand. also look for any bent petals on the printwheel. if none of this works, you will need a repair shop or a new machine.
Nov 17, 2008 | Brother GX-6750 Typewriter
Get unknown disk error in dvd cloner
I have a xbr413 and all of a sudden I am now getting unknown disk when I insert the dvd. It has been working fine prior. Any suggestions?
Feb 15, 2008 | Televison & Video
Heating & Cooling Logo
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
