Question about Kenwood Car Audio & Video
On a kac-x650d does the power light stay on or flash
  • 655 Answers
Hello mpredday,
The Kenwood Excelon KAC-X650D power light is ON during normal operation. It blinks blue to indicate BMS selection, yellow for low voltage, purple for DC voltage on the outputs, red for overheating, and green for a shorted or grounded speaker wire.
Hope this helps.
Posted on Jul 30, 2009
My Kenwood kac9152D turns on but why dose the red light on the top keep flashing?
The manual only says the power indicator burns when the power is on.
I can't find anything about it also should flash. The only thing I can think of, it has detected an error, like a blown amp or a low impedance on a speaker terminal.
Here is the manual:
http://images.kenwood.eu/files/prod/29/5/KAC-9152D_9102D_8152D_8102D_(EN).pdf
Jan 17, 2015 | Kenwood KAC-9152D Car Audio Amplifier
Can i run just 2 subs on this 1200 watt kenwood 5-4-3 and if so what way will i get the most power, i mean do i bridge it or pute the speaker wires in other ports
you can run 2 subs given that you dont go over 2 ohms of resistance and that the subs are rated at 1000 watt max each around 4 or 500 watt rms. if your not sure about ohms dont bridge it and get single voice coil subs. this amp is capable of about 700watts constant power 1200 max spike if the voltage stays at 12 or higher.
Feb 05, 2010 | Kenwood KAC-X650D Car Audio Amplifier
My amp indicator is blinking blue and my sony xplod sub is not workin thru the amp but works wen i connect it in my other car how do i fix it so my light stops blinking, and my sub works again
yes you have a internal fault of the amp. the circuit that puts it into safe mode is bad and that is a very small chip on the board know as a op amp. needs to be repaired.
Jan 03, 2010 | Kenwood KAC-X650D Car Audio Amplifier
Kac-7202 flashing power light
ALL THAT IS A WASTE OF TIME AND YOU MAY HAVE CAUSE MORE DAMAGE TO THE AMP,THOSE AMP WILL FLASH WHEN THERE IS NOT ENOUGH POWER SOURCE EITHER GROUND,OR LOW VOLTAGE REMOTE OR TWELVE VOLT SOURCE CHECK ALL THOSE AND MAKE SURE YOUR HAVE RIGHT SIZE SPEAKERS THAT CAN HANDLE THE LOAD FROM AMP
Aug 07, 2009 | Kenwood KAC-7202 Car Audio Amplifier
Amp overheated
Yes, try replacing the fuses first. If that doesn't work, then I'm sorry to say that you most likely fried your amp.
Jun 06, 2009 | Kenwood KAC-X650D Car Audio Amplifier
One amp dies.. then revives
I'm no expert, but the two most obious problems that come to mind would be the power supply or amp over heating.  Test your battery and alternator..
Oct 28, 2007 | Kenwood KAC-X650D Car Audio Amplifier
AMP FOR SUB SHUTS OFF SOMETIMES
your system is not connected right take it all out and put it all bk in
Oct 27, 2007 | Kenwood KAC-X650D Car Audio Amplifier
Kenwood kac 859 amp
hi, note that if you are not using the proper gauge b+ and gnd cable with this amp then the current available at the amp wont be sufficint to keep amp on. also try using this amp while vehicle is idling. if this doesnt work then disconnect all spks from amp and check if red lite stops flashing. if it doesnt stop flashing then amp has internal fault. if lite stays on brite then proceed to check each spk load impedance, then reconnect each spk individually. the minute red lite starts flashing it will give you a clue that the channel or spk load is faulty. cheers
Jul 27, 2007 | Kenwood KAC-859 Car Audio Amplifier
Car Audio & Video Logo
146 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
