Question about Vehicle Parts & Accessories
Clifford one way makes sound when I click AUX but when I click on f, then arrow showing clockwise, the vehicle doesn't start.
4 Suggested Answers
SOURCE: My remote start will not start my truck. I hear
That clicking could be a relay that has gone bad. They click when they are good too so if the relay is working you might want to check the wiring between the relay and the starting circuit.
Check your remote starter manufacturer for schematics and parts number for a replacement relay if necessary.
Posted on Dec 09, 2009
Strattrpt
  • 159 Answers
SOURCE: 1991 Lexus 400 - engine
This could be a problem with your starter -- if you know a bit about engines try tapping the starter with a wrench while someone turns the key (not too hard so you don't damage it if this is not the problem). If your starter motor has a "dead spot" tapping it can get it to free itself up and might help. If this DOES help, please consider changing your starter so you don't have to keep going through this problem. If tapping the starter does not help, it might just be dead altogether. If you are doing your own work, try replacing it and hopefully that should help. If you are not going to do your own work on the car, a mechanic should be able to give you a proper diagnosis and repair the issue without too much hassle.
Posted on Jun 01, 2011
josetejas
  • 300 Answers
SOURCE: I have a jvc kd-s26 with aux input, but when on
What is connected to the AUX input. Does that source has a volume control? If so, keep the source volume higher enough to output sufficient signal to the radio
Posted on Mar 10, 2012
Clifford g5 alarm how do i reset it after i was checking fuses it wont let me start the car
The car won't start because the Clifford alarm has a starter interrupt wire where the start wire runs through the alarm system module/relay. The unit then must still be active for the car not to start. If pressing the disarm/unlock button on your Clifford key FOB does not turn the system off, you will after to do it manually. You will need to locate the manual override button installed somewhere in the car that is connected to the alarm system. Turn the ignition switch to "on" or "run" and within 10 seconds press the manual override switch. That will turn the alarm system off and allow the car to be driven normally. I would then take the vehicle to an authorized Clifford or other DEI (Viper) install shop and have them diagnose your apparent problem.
Jul 31, 2014 | G5 IntelliGuard 770 P/N 919621 Car Alarm
Constant sounds coming from my truck alarm
Pull fuses until it goes away. Also pull relays you could hae a bad relay
Jan 03, 2014 | 5704x 570.x 2-Way Security and Remote...
When I try to play a cassette the cassette clicks on and turns normally. However, all it transmits to the TV is wavy lines and no picture of sound. The TV does not show the play, stop,etc. indictators when...
The TV channel should be set on Chanel 3 or Chanel 4.
Use the remote control of the TV to set it.
You can also use the AUX ports (to TV) on the VCR and connect the three wires to the AUX ports on the TV (TV input). The two audio wires are to be connected to Audio in and the Video signal to the Video input.
If you get a garbled picture you can use press the tracking button on the VCR. Usually you press the Channel Up arrow, or Channel Down arrow to adjust the picture.
Dec 22, 2013 | Goldstar Televison & Video
Aux fan not cutting in when o/heating 1989 190E 2.6Ltr. Fans operate when tested.
Your vehicle should have a viscous fan clutch for controlling the engine temp from overheating. The auxillary fans in front are used when the a/c is on. I would start by spinning the engine fan or viscous fan by hand when the vehicle is off. The fan should show resistance when you spin it. If it doesn't and it just free spins then the viscous fan clutch is bad. Let me know what happens when you spin the engine fan and also exactly how high does the engine temp get. Does it reach the red mark?
Feb 23, 2012 | Mercedes-Benz 190-Class Cars & Trucks
I need some help on my old Clifford Alarm system. I purchased my Toyota used about a year ago and I can not get the light on the dash to go off. I replaced the batteries in the key ring on both sets but it...
it is unlikely that the light is causing the battery to drain. it sounds like the system is in valet mode, if it's an older Clifford with a two button keypad somewhere (typically on the dash), turn ignition on, and press the * button twice, then press and hold the blank button.
if it's a newer Clifford system (Clifford Matrix), locate the valet button, then turn the key to ignition (ON), then off and press and release the valet button.
Mar 01, 2011 | Toyota Vehicle Parts & Accessories
Cd player on 2006 f150 makes a clicking noise and gives a cd error when i turn the vehicle on. the cd changer is empty
sounds like the unit is stuck in ship mode
or the loading gear is bad they make click click like 5 times
radio needs to be repair there is no easy fix for this
the other solution is just leave along and trasfer all your cd's to mp3 or ipod
there is factory auxiliary input for ford radios with the AUX button
http://www.oemautosound.com/pc-192-86-frd04-aux-ford-2004-and-up-input-audio-adapter-aux-button.aspx
Nov 23, 2010 | Car Audio & Video
My remote start will not start my truck. I hear clicking noise under the dash, but it won't start ? What do you think is the problem? I have an older Clifford Arrow!
Dec 09, 2009 | Vivendi Clifford Learning Activities...
Battery went dead,clifford alarm locked the engine
Assuming that all is well with the vehicle's electrical system (fuses, etc...), the following should work, as Viper/Clifford uses the "fail safe" method of starter disable, and it only works to lock out the starter when the alarm is functioning properly and in the armed state.
That system has a "starter kill" system. When the alarm is actived, the starter kill is engages, and won't let the starter get voltage from the ignition switch. First thing I'd try is connecting the car's battery while the ignition key is turned to the "on/run" position. Cycle the alarm to arm, then disarm, so that the LED is not blinking. It also may require using the manual override button/switch (with the key on) to reset the alarm. Should start after that.
If all else fails, reconnecting the starter wires back together (they are spliced and running through the alarm via a SPDT relay.
Oct 23, 2009 | Viper Vehicle Parts & Accessories
Vehicle Parts & Accessories Logo
35 people viewed this question
Top Vehicle Parts & Accessories Experts
Marvin
Marvin
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
