SOURCE: my final spin cycle is not working on any wash
TIMER!!! Last cam in your timer has a loose set screw or is broken. Don't try to fix it, it won't last. Buy a timer.
SOURCE: My washer is not cycling by itself-it stays on wash for hours?
i had the same issue and i found that it was the lid lock switch. if this is broke it will not switch cycles; i tested mine by pushing down while the cycle was running you will hear a click sound that the lock is in place and the machine will run properly. i also found the switch is only around 40$ instead of the 200 for the timer. good luck.
SOURCE: washer will wash. won't go into spin cycle. settin
something in pump or pump bad now easy to do with speical tools
SOURCE: crosley front load washer one year old. doored
your drain pump or hoses are blocked with foreign material,either coins,hairpins,detergent residue from earlier washings,remove the front lower access panel if provided to access the drain hoses and pump and also check the drain itself,some washers have the access door in the back side of the machine,if the stand pipe in the house is slow to drain it can back up and cause back pressure and the machine will sense this and stop also
