Question about Optics
I am looking for a bolt spring and pin for a marlin 150M I can be contacted at 337-794-2436
2 Suggested Answers
  • 47153 Answers
SOURCE: looking for parts for a marlin 22 model 80
Fixya does not sell these parts.
Posted on Oct 08, 2016
Marlin 1893 octagon barrel smokeless steel. 32 win special. Serial number 438257. Looking for year of gun and value??
http://oldguns.net/sn_php/marlinlookup.php
It is a newer gun. See the comments in the link above
Answer to your Questions on "How old is my gun" - Marlin Firearms ...
https://marlin-collectors.com > ... > General Gun Questions and Answers
Feb 17, 2009 - Model 1893: 1893 to 1921 or 22. PAT'D OCT. 11,1887. APRIL2.1889. AUG. 1, 1893 25-36, 30-30, 32-40 32HPS, 38-55. Some early 1893's did not have the two piece firing pin. Serial numbers are located under the receiver just behind the forearm. Factory records ceased in 1906. Original serial numbering ... Marlin Serial Numbers 1916 to 1921 Era
20 Nov 2011
1893 serial no confusion?
23 Sep 2011
Model 1893 25-36 Serial Number Question
15 Nov 2010
Marlin 1893, 30-30, When Made?
1 Aug 2008
More results from marlin-collectors.com
Help dating a Model 1893 30-30 - Marlin Owners
www.marlinowners.com > ... > Marlin Collectors Nov 18, 2011 - But if the tang is marked Model 1893 not Marlin Model 93 in two lines and the serial number in located on the bottom of the trigger-plate near the fore-arm then it is thought that your rifle might be made from after 1916 up to around 1921.These rifles will show up with the letter prefixes. A,B,C,and D.There is no ... Model 1893 serial number confusion
4 Jul 2015
Model 93 with odd serial number
19 Nov 2012
Marlin Model 1893 serial number question
28 Oct 2012
1893 date of manufacture
22 Dec 2008
More results from www.marlinowners.com
Mar 13, 2018 | Optics
Looking for a bolt with extractor & firing pin for Marlin model 39 Lever action
Fixya does not sell replacement bolts and extractor pins.
Jul 26, 2017 | Optics
WHERE CAN I FIND THE BREECH BOLT WITH FIRING PIN AND SPRING? FOR A 22 MARLIN 25MN
Contact a local gunsmith for this. This site doesn't sell parts or have anyway to find them.
Feb 16, 2017 | The Optics
Need a complete Bolt Replacement for a XT-22WMR
you may want to contact Marlin at https://support.marlinfirearms.com/XT_22/Schematic_and_Parts_Listand they may well be able to assist you
Dec 04, 2016 | Marlin 70767 XT-22RC Bolt 22LR 22" 71...
Marlin model 70
Unfortunately, Ramline stopped making the model 70 mag due to the Clinton Gun Ban of 1994.
They're out there, but you have to look for them.
Either used, or NOS (New Old Stock)
Try Ebay
http://www.gunauction.com/buy/10779099/magazine-clips/ramline-banana-mag-for-marlin-papoose-or-model-70
http://www.firearmstalk.com/forums/f53/ramline-marlin-m-70-papoose-25rd-22lr-mag-38598/
Feb 19, 2014 | Optics
Bolt stuck in closed position after cleaning XL7 30 06
If you had the bolt sleeve or cocking piece out of alignment, it will jam. You should call 1-800-544-8892
to see what they have to say about it
Feb 22, 2013 | Marlin Model XL7 Rifle XLTL3006, 30-06...
Diagram of a model 70 bolt- how to take the bolt apart to change firing pin
Compress the spring. Remove the C Clip. Remove the spring. Remove the firing pin & cocking piece from the shroud. Drive out the retaining pin in the cocking piece. Unscrew the pin. Reinstall in reverse order.
Oct 26, 2012 | Winchester Optics
My model 742 lever action missfires every 3 or 4 rounds.dimple on spent cartraige is much deeper than missfired shells
This may be an indication of a broken firing pin, dirt in the firing pin channel, or an over oiled firing pin/channel. All will exhibit this behavior. A through cleaning is called for, with dis-assembly to follow for parts inspection.
I have also experienced this behavior from a weak hammer spring.
Oct 10, 2010 | Mossberg Marlin Rifle 992m,989,mossberg...
94 landcruiser brakes
Rear DRUM instructions are first If you would Like Pictures and all They Must Be Emailed as TOO LARGE For FixYa's Format im at aol.com
Just use my Knickname@ and let me know where to send.
  1. Raise and support rear of vehicle, then remove wheel and tire assembly.
  2. Remove brake drum. If brake drum cannot be removed easily, insert a suitable screwdriver through hole in backing plate, then push adjuster lever away from adjuster and back of adjustment tension.
  3. Remove tension spring, using a suitable tool, then remove rear shoe hold-down spring and pin. Remove rear brake shoe and anchor spring, Fig. 7.
    1. On Land Cruiser models, remove front hold-down spring using a suitable tool, then disconnect the parking brake cable from the parking brake bellcrank, Fig. 7.
    2. On Pickup, 4Runner, 4WD T100 and 4WD Tacoma models, remove front shoe hold-down spring and pin, using a suitable tool, then disconnect No. 1 parking brake cable from No. 3 parking brake bellcrank.
    3. On 2WD T100 models, proceed as follows:
      1. Remove E-ring, then automatic adjusting lever and C-washer, then parking brake lever. Disconnect brake line from wheel cylinder using a suitable container to catch fluid.
      2. Remove wheel cylinder. Remove following parts from wheel cylinder: two boots, two pistons, two pistons cups and spring.
    1. On models except 2WD T100, remove front brake with strut, then disconnect parking brake cable from front shoe. Remove parking brake cable No. 2.
    2. Remove adjusting lever spring, then the adjuster from front shoe.
    Inspection
    1. Measure brake drum inside diameter. Inside diameter should be 11.61 inches,
      1. Measure brake shoe lining thickness, Fig. 3. Minimum thickness should be .04 inch on models except on T100 models and .039 inch on T100 models.
      2. Inspect brake lining and drum for proper contact and replace drum or shoes as necessary.
      3. Inspect wheel cylinder for corrosion or damage.
      4. Inspect backing plate for wear or damage.
      5. Inspect bellcrank components for bending, wear or damage.
      6. Apply a suitable lubricant to backing plate contact areas.
      Installation
      1. On 2WD T100 models, proceed as follows:
        1. Apply lithium soap base glycol grease to piston cups, pistons and boots.
        2. Assemble and install wheel cylinder.
        3. Connect brake line to cylinder.
      1. Apply high temperature grease to following parts:
      1. Apply a suitable lubricant to adjuster bolt threads and end.
      2. Assemble adjuster to lever, then install adjuster lever spring.
      3. On Land Cruiser models, install parking brake lever cable to parking brake shoe, then attach cable to bellcrank.
      4. On Pickup, 4Runner, 4WD T100 and 4WD Tacoma models, install No. 1 parking brake cable to parking brake lever shoe, then attach the other side of cable to No. 3 bellcrank.
      5. Position front shoe in place with end of shoe inserted into piston, then install shoe hold-down spring and pin using a suitable tool.
      6. Assemble anchor spring to front and rear shoe, then install rear shoe with end inserted in piston.
      7. Install rear shoe hold-down spring and pin, then the tension spring.
      8. If necessary, adjust bellcrank as follows:
        1. Lightly pull bellcrank in direction "A", Fig. 8, until there is no slack in part "B".
            1. Rotate adjusting bolt until dimension "C" is .016-.031 inch.
            2. Lock adjusting bolt with locknut, when connect parking brake cable to bellcrank.
            3. Install tension spring.
          1. Ensure proper parking brake travel.
          2. Pull adjusting lever cable upward, then release and ensure adjusting bolt rotates. If bolt does not rotate, check for improper installation of rear brakes.
          3. Adjust strut to shortest possible length, then install drum.
          4. Pull parking brake lever fully upward. Repeat process several times.
            1. Remove drum, then check for proper clearance, Fig. 4. Clearance should be .024 inch. If clearance is not as specified, check parking brake system.
            2. Install brake drum, then bleed and refill brake system.
            3. Install wheel and tire assembly, then lower vehicle.
FRONT ROTORS & PADS
  1. Remove caliper.
  2. Remove cap and snap ring, Fig. 10, then remove cone washers with tapered punch.
  3. Insert suitable length bolts into flange bolt holes, then tighten bolts evenly and remove flanges.
  4. Remove free wheel hub cover and snap ring, then remove nut, spring washer and cone washer with suitable tapered punch.
  5. Remove free wheel hub body and gasket.
  6. Remove locknut, lock washer and adjusting nut.
  7. Remove axle hub and brake disc as an assembly.
  8. Remove oil seal and inner bearing from hub.
  9. Reverse procedure to install. Torque adjusting nut to 43 ft. lbs., then back off nut. Torque nut to 18 ft. lbs. Using spring scale attached to hub bolt, check that preload is 1.4-12.6. Install lockwasher and locknut, if equipped. Torque locknut to 35 ft. lbs., and recheck preload. Secure lockwasher by bending one tab inward and one tab outward.
  1. Raise and support front of vehicle, then remove tire and wheel assembly.
  2. Remove clip and hole pins, Fig. 9.
  3. Remove anti-rattle spring and shim(s) if equipped, then remove brake pads.
  4. Lubricate caliper housing with suitable brake grease at pad contact points.
  5. Reverse procedure to install.
Jan 28, 2009 | 1994 Toyota Land Cruiser
Optics Logo
26 people viewed this question
Top Optics Experts
Marvin
Marvin
james laughton
james laughton
ray gallant
Are you an Optic Expert? Answer questions, earn points and help others
