Question about Danby Portable Air Conditioner
How to operate
What do the dials mean?
water tank?
hoses go where, outside?
  • 867 Answers
Dials with numbers is the timer, hose goes outside
Posted on Jul 29, 2009
How to fill fresh water tank on 2016 evergreen 25fs reactor.
2 ways ..there should be a hidden hose outlet to fill the 106 gallon tank on outside.. have you checked near the gray water extraction location..
other way find the underbelly tanks and trace hoses till you find it..
Sep 19, 2017 | Air Tools & Compressors
What is purpose of water pump switch in rv
You have an onboard water tank, Potable water. WHen not hooked up to a hose outside the rv, you can pump water from tank on board.
Apr 23, 2013 | Water Heaters
Black slim in hot water
SOUND LIKE YOU NEED TO DRAIN AND FLUSH YOUR WATER HEATER TANK. THERE IS A HOSE BIB AT THE BOTTOM OF THE TANK. RUN A HOSE FROM IT TO A DRAIN OR OUTSIDE. SHUT OFF THE COLD WATER INLET VALVE AND OPEN THE HOSE BIB. OPEN HOT FIXTURES IN THE HOUSE.CHECK THE DRAINING WATER FOR CLARITY. IF CLEAR OPEN THE INLET VALVE AND LET IT FLUSH(YOU MAY GET MORE DISCOLORED WATER, RUN UNTIL CLEAR). SHUT HOT WATER FIXTURES, CLOSE THE HOSE BIB AND LET TANK REFILL.
Mar 30, 2013 | Water Heaters
I want to eliminate water tanks and connect direct to outside drain ..q..where do i connect from inside tank or portable one.
Unfortunately, draining to the outside would be next impossible, as the maximum length of hose that can be used is 48". There is no pump. the unit relies entirely on gravity to drain. In addition, continuous drainage can only be used for the Dehumidifier function. It should not be used for the Cooling Mode. Water is required to keep the unit cool during operation.
Take good care of your unit, as it has been discontinued by Danby.
I hope this helps you and thanks for choosing FixYa.
Jul 27, 2011 | Danby DPAC8399 Air Conditioner
My bissell pro heat 2x does not **** up the water from either the upholstery cleaner or carpet cleaner. Any thoughts as to why? The water and heat functions work it just does not pick up
First check the motor duct gasket. The motor duct gasket is visible once the tank is removed. It is located underneath the handle on the top of the base of the machine. It has a black rubber coating around it. If there is no suction there please let us know. If your machine does have suction at the duct, continue to check the following:
- Ensure the Ready Tools Dial is set to the appropriate setting (Floor Cleaning or Hose Attachments).
- Remove the tank from the machine and ensure the tank lid is attached properly. The front window must first hook onto the lip of the bottom of the tank and then drape over the tank. Latch the bottom tank to the top tank lid. THIS LID CANNOT BE ATTACHED PROPERLY IF THE TANK IS NOT REMOVED FROM THE MACHINE.
- Make sure the Water Tank is not full on the outside of the bladder. If it is, empty the tank.
- Ensure the hose is firmly attached to the back of the machine. If not, re-insert as necessary by twisting into place.
- The machine must be in an upright, locked position and set to the Hose Attachment setting. If the handle is slightly tilted back while using, it will create a small gap at the suction inlet (where handle meets gasket, above the Bottom Tank) which will cause little or no suction.
- Check the red Tank Lint Screen for debris. If the Lint Screen is dirty, the unit will have poor suction. Clean the Lint Screen if necessary.
- If the float flap door in the tank lid is activating prematurely when you turn the machine on, this flap door should be replaced. This tank may need to be emptied.
- Check the Tank Lid and Tank for damage.
Aug 13, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
My bissell will not suction water from the carpet
Please check the following:
If you continue to experience low suction, please contact BISSELL Consumer Services at...
1-800-237-7691
Mon-Fri: 8am to 10pm ET
Sat: 9am to 8pm ET
Apr 09, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Flooded bathroom from top of unit
The T&P valve (temperature and pressure) relief valve is suppose to have a 3/4 in drain line threaded into it .This line should have ran to a trapped drain or possibly to the outside of the house. A water heater cannot over fill. To drain your water heater run a garden hose to the outside or to the lowest drain you have nearby.If its still wet be carfull not to get shocked,Attach the garden hose to the drain valve located towards the bottom of the water heater. turn the valve on. If water dosnt come out of the other end of the hose,youll have to see if you can run a peice of wire through the valve into the water heater to get it to drain. This can somtimes be a real problem . I usually leave the water on when i first connect the hose to the drain valve. This allows the water pressure to flush the sedament out of the bottom of the water heater.
Dec 04, 2009 | Water Heaters
How to drain the rheem 135 litre tank
1. turn off the electrical power first.
2. attach a garden hose to the hose bib attachement on the bottom of the water tank and run the hose outside to allow the water to drain out by gravity.
3. Turn the valve that is on the inlet of the water heater. Now that the power is off, you can drain the tank.
4. open the drain valve where the hose has been attached.
5. To release the pressure, you can open a hot water faucet in your kitchen. This will allow the water to drain out easier.
Sep 12, 2009 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
I just bought a Danby portable air conditioner (model # dpac5070). The manual tells you how to use the direct drain hose if you want to "vent" the water outside. If I don't want to direct the water...
You use the hose only for continuous draining outside of the unit into a bucket or what have you. You don't need to attach the hose at all. I actually need the hose if you want to part with yours. coatings(at)shaw.ca
Jul 04, 2009 | Danby Heating & Cooling
Danby Portable Air Conditioner Logo
183 people viewed this question
Top Danby Heating & Cooling Experts
Dan Webster
Dan Webster
Dennis Boxerman
mintvl
Level 1 Expert
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
