Question about Ricoh Office Equipment & Supplies
My Ricoh copier print and the out come has black dirt at the top of the paper but the front comes clear. Need help please
  • 95 Answers
SOURCE: Ricoh Aficio AP3800C Printing Problem
If the marks are along the same line and look like dots the black photoconductor needs to be repalced.
Posted on Mar 31, 2009
Ickoajnc
  • 183 Answers
SOURCE: Ricoh 1232c copier error code sc 517
The error is about the fusing unit for to reset the code you must enter into the service menu and reset the SC code 517
For to enter the service menu you should do the follow steps :
1.Enter the service menu by pressing the follow keys in order: yellow key[clear modes] then press "107" number one after other and then press and hold the red key [clear/stop]
2.Hold it down until service mode do not appear if not appear after 10 seconds try again.
After you will be in service mode press the follow numbers :5810 and then will apear on the screen "SC reset" set the value from "0" to "1".
Then turn off and after 5 seconds turn it on the machine.
Please replay if this do not help and write the SC code good because i cannot find the code SC517
Posted on Jul 15, 2009
  • 161 Answers
SOURCE: Error code SC 548 on Ricoh Aficio 1022 copier. Need to reset m/c
sc 548- service call - fusing unit not set properly
the fusing unit connector may be loose.
u can reset the error by entering the service mode (careful -do not change anything )
to enter the service mode press [all clear](yellow button) ,[1],[0],[7],[clear](orange button)and keep the button pressed for about 5 sec.
go in copier options , then mode 5, then option 810
and execute(or 1 & ok)
(careful -do not change anything else)
Posted on Jan 16, 2010
pineworks
  • 4041 Answers
SOURCE: Printer willl print color but does not print black and white
Hi There You can try/
Summary
Usage of compatible ink and leave the printer idle too long may cause printhead clogging
What should you do if you get this problem. Relax; you may recover the printhead by unclogging it. Follow these steps to unclog the printhead
1. Right click in the printer driver name
2. Select Properties menu
3. Click Maintenance tab
4. Click on cleaning sign for regular cleaning. Perform this up to 3 times.
5. If this does not work, perform Deep Cleaning
And if that not work
Some times it needs a good clean up but this is up to you if you want to do this,
But after you done this prime the printer so it gets the inks back in the heads, it may take a little time for the inks to work.
Ok.
There is fluid cleaner for this but I can never find any in the shops the only ones I seen is when they sell them in Tesco but they come in with the ink refill bottles so I just use worm water by it self on a cloth and dabbing on the heads to clean them, it will not harm the heads but not to much water.
Some heads are on the inks them self but some have them inside the printer so I not know your printer so if the heads are inside you need to get them out you may find that some heads will just clip out put some need to be unscrewed so you got to know how they come out so be careful and not push to hard on them, if the heads are on the ink then it is a easy job to clean them,
It worth a try it worked for me more than ones.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Posted on Apr 28, 2010
  • 44 Answers
SOURCE: Ricoh copy machine 3025 paper jams every time we try to print
If the sheet of paper is damaged there may be a blockage in the paper path. If the path is cleared and it still damages the paper then the feed rollers could be worn. Question for you, when the paper gets damaged does it fan up like an accordian? if so there is an issue in the fuser section. Hop this helps
Posted on Sep 30, 2011
When i print A3 on Ricoh 3035 it prints a black shade on the side of the paper ,& there is no problem for A4 , please help me
Pls tell in which way you are using A4 papers. Landscape or Portrait.? More help contact me on anuruddha07@gmail.com
May 25, 2013 | Ricoh Aficio 3045, 3035 Kit
Ricoh 3245c paper jamming in fuser any help please
Check to see if;
1. the exit sensor in working properly
2. There is a piece of paper stuck inside blocking the paper path
3. Hot roller strippers are in good condition.
Nov 24, 2011 | Ricoh Office Equipment & Supplies
While printing a black line appeared in the sheet and also paper scratched
It is possible that the paper is getting caught up while in print.
Please rotate rollers manualy and clean after removeing the top panel and the drive link.
Usea good swab to clean out the rollers , any dirt or lodged paper in the movement track.
check if the rollers are damaged or the movement is irregular.
Use good lighting to check , clean properly and see for change if so repeat till the fault clears.
Need not open out rollers unless you detect some changes in the arrangements
Aug 28, 2010 | Canon LASER SHOT LBP-2900 Printer
MY PRINTER STOPPED PRINTING AND GIVES A ERROR MESSAGE THAT THERE IS A MISFEED. I CAN NOT SEE THE PAPER FROM THE FRONT OR TOP ARE THERE ANY OTHER SOURCES THAT I CAN CHECK TO CLEAR THE MISFEED, IF THERE IS...
You need to consult your manual for all the paper paths that you may have missed.
Check all paths and go out and buy paper path cleaner, follow the instructions on the package and completely clean out the paper paths.
This should loosen or remove the stuck paper and get the printer printing again.
Please write back results (good or bad)
Mar 16, 2010 | Ricoh Aficio SP C231N All-In-One Laser...
When i copy o print a document, it comes out with tonner and black dust stains, how can i clean it? Ricoh Aficio MP 1600
a) If possible remove the drum unit and see if there is a paper stuck in the drum unit.
To remove the drum unit first open the front and right door. Then remove the toner holder(green lock).
Then pull the drum unit out from the front of the machine(press the lock).
b) How many prints(copies) has the drum made ?
The life is 60000.If it has crossed its life replace it along with the developer.
Feb 16, 2010 | Ricoh Aficio MP 1600 Black and White...
Make sure the paper that is in the drawer matches the orientation and size indicated on thje Op Panel Display, If NOT, MAKE IT MATCH.
Mar 31, 2009 | Ricoh Aficio 3025P Black and White Copier
Paper Jam
There is a small clear plastic sheet that is suppose to be in front of the black friction pad in the paper tray. if that sheet is under the pad instead of in front of it you will get this error.
Mar 24, 2009 | Ricoh Aficio SP C410DN Laser Printer
Ricoh AP3800C "Output tray full"
Check the little black piece of plastic that senses the printed page exiting the machine. Our sensor was stuck and I was getting the same message (an similar Ricoh product). When I gently reset the black piece to center, moving freely, printing worked again. I think the sensor got jammed up when we were trying to remove a bad paper misfeed.
Ricoh manuals very confusing on this error message. They refer to standard tray, tray one, etc. without being clear whether it's a paper feed tray or the so-called "standard OUTPUT tray." The output is not really a tray, it's just the depression where your sheet lands after printing. I wrenched on the paper feed trays and their settings for an hour before I figured out they meant OUTPUT.
Feb 27, 2009 | Ricoh Aficio AP3800C Laser Printer
Ricoh aficio 3025 copies out of alignment
Check the paper size dials (green dials) of the paper trays that are set to match the orientation of the paper loaded in the tray.
On the touch panel display, select Auto paper select icon and retry.
If the dials are correct and the problem still there, please then try to print the counter printout from the User tools (yellow) button or send a print from your computer.
If still with the copies being cut off, please check for toner spillage between the toner unit and Photoconductor unit.
Open the front cover, pull out these units and clean toner spill.
Clean also the laser shield glass. There is a small cover below the toner supply unit, unscrew 1 screw. Pull out the small glass very careful and straight ahead, pay attention not to break it.
Retry copying and printing.
Good luck and please rate me, thanks.
Jan 21, 2009 | Ricoh Aficio 3025P Black and White Copier
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
