Question about Science & Laboratory
I just had a main serer trap clog up for the 3rd this year. It was clogged with some soft, white goop like lumpy CRISCO or gelatin. It easily by hand.
At first I thought it was cooking grease, but I put some in a metal can and heated it on the stove - it didn't melt. Of course, both tenants in this rental property deny putting anything strange down the drain or toilet. Any ideas on what this stuff could be? Any way/place I could have it tested to find out what it is? CLIVE - thanks for the response - but I'm in NYC so the water is not hard
    Top Expert:
  • 23,746 Answers
You will have to have it tested for a definitive answer.
Posted on Dec 06, 2017
Testimonial: "yes....I realize that....but I've looked around the internet for someplace that could/would analyze it and couldn't find one. Do you know of one?"
  • JonSnell Electronic
    JonSnell Electronic Dec 06, 2017
    In the UK the Department of Health have Labs and can test things but no idea of cost.
MicrowaveSvc
  • 9086 Answers
SOURCE: Microwave does not heat food placed in the center of the turntable. Leaves a cold spot in the middle of the food.
This is normal. That's why I always recommend to my customers that the food be placed slightly off-center on the turntable. An analogy I refer to is stirring paint: If you stir paint with a stick by simply rotating the stick in the center of the can, it's far less effective than pulling the stick around an imaginary circle halfway bewteen the center and the edge.
Posted on Sep 15, 2006
MicrowaveSvc
  • 9086 Answers
SOURCE: Dacor DMD2420S
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
This can be caused by slamming the door or by habitually opening the door while it's cooking without hitting the Stop pad first.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Feb 09, 2008
SpotBert
  • 231 Answers
SOURCE: microwave doesn't heat up
There are three solutions (source) =>
http://www.partselect.com/repair.aspx?appliance=microwave&part=no-heat
Power Diode
A diode is an electronic component that readily passes current in one direction only and blocks the flow of current in the opposing direction. If your microwave's diode has become defective, your microwave will not heat and you will hear a buzzing noise. Test the diode to determine if this is the cause of your problem. Replace it if it is defective.
High Voltage Capacitor
A capacitor is an electrical device which stores electricity. A defective capacitor may be why your microwave is not heating but you are hearing a buzzing or humming noise. The capacitor will have to be tested to determine if this is the cause of your problem. A defective capacitor will have to be replaced before your microwave will work again. Make sure you discharge the capacitor before you test it, though.
Magnetron
A defective magnetron is the third possible cause of why your microwave is not heating, but you can hear a buzzing noise. Test your microwave's magnetron. Replace it if it is defective.
Posted on Dec 31, 2008
SOURCE: My Microwave does not heat up or cook...
the microwave oven has been working, but all of a sudden it does not heat up.
Posted on May 02, 2009
  • 5 Answers
SOURCE: Microwave shorted out when metal grease filter contacted inside
It might be that the internal power fuse of the MW may have blown. You may have to just replace that fuse if possible. Other wise the electronics (most likely a circuit board) may have been blown.
Posted on Oct 17, 2009
Tip
Ethanol blend gasoline causes issues with older vehicles.
I've answered many questions recently about older vehicles (pre-2005) having fuel system issues. As a car collector, I have encountered fuel system issues myself, almost all of which stem from the use of ethanol blend fuels, such as E10.
Whereas vehicles manufactured in the past ten years are specifically designed to accommodate a broad variety of fuels (especially "Flex Fuel" vehicles), ethanol poses a special problem to older vehicles.
  • Many vehicles manufactured more than a decade ago use fuel tanks that will rust in the presence of moisture. Ethanol fuels, when allowed to sit for extended periods in conditions where heat and humidity are high, catalyze moisture to condense at the top of the gas tank, eventually collecting on the sides and bottom of the gas tank when the temperature again falls, causing rust spots to develop throughout the tank.
  • Most engine computer controls that are over a decade old are not equipped to deal with the peculiar sensor readings caused by ethanol blend fuels, causing the fuel mixture to be made richer than necessary, and retarding the timing to avoid pinging. This notably lowers performance and fuel economy.
  • Carbureted engines with older carburetors may experience a gelatinous buildup in the float bowl, which may eventually clog the metering jets. This gelatine-like buildup is residue from water combining with other contaminants in the fuel system, and isn't permanently harmful, but can cause misfiring and loss of performance.
  • Use of ethanol blend gasoline in older cars can cause permanent harm to components of the fuel system, including the fuel pressure regulator and the fuel injectors.
SUGGESTED SOLUTIONS:
  • Change your fuel filter regularly, and be certain that your fuel pickup strainer does not become clogged with rust particles. (If your variable speed fuel pump is constantly operating at high speed, this is a good indication that your pickup strainer is clogged);
  • If your fuel has been sitting in the tank for more than one year without being used or added to, GET RID OF IT and replace it with fresh fuel. NOTE: If you buy a car that shows evidence of sitting idle for an extended period, even on a used car lot, expect to replace the fuel, first thing.
  • Use a FUEL INJECTOR CLEANER additive with every two or three fill-ups. Use with every fill-up if your vehicle sits for longer than a month at a time.
  • Use a FUEL SYSTEM WATER REMOVER (sometimes called "FUEL SYSTEM MOISTURE REMOVER") at least four times per year. (WARNING: This may cause the above-described gelatinous slime to develop if you have water in your fuel system. Fear not, if you have a fuel-injected engine, the gelatinous gunk will pass through the system eventually, to be burned in the cylinders or ultimately expelled from the exhaust);
  • IF POSSIBLE, USE NON-ETHANOL FUEL IN ALL OLDER VEHICLES. It costs more and, in some areas, is not available. In this case, the introduction of a METHANOL-BASED fuel additive may help, and fuel system water remover additives are essential.
on May 13, 2015 | Cars & Trucks
Tip
How to improve air compressor dew point?
Have you found the water on your compressor air discharge?
If this happen, I'll tell you that you have bad dew point of air. This is because either your compressor has no moisture trap built in or moisture trap is not work properly. To prevent this condition I suggess you to install another water / moisture trap ( J-trap ) on your compressor discharge pipe together with mechanical auto drain and manual drain valve on bottom your new trap. This will give alot improvement of air quality goes to the load. Many brand you can found on market like CKD, SMC etc.
No electricity required for this equipment. It has clear glass, so you can know whether it is clog up or still work properly. If it is clog up , you can clean all parts inside easily by washing it with soft detergent soap.
It is so easy and effective.
on Aug 05, 2010 | Air Tools & Compressors
Plumbing question. I just had a main serer trap clog up for the 2nd time in 6 months. It was clogged with some soft, white goop like lumpy CRISCO or gelatin. I cleared it easily by hand.
My first thought was coconut oil/butter. Many millennials and younger are slathering on coconut butter after shower clogging plumbing in the US, but i should melt. When oils combine with soap they can produce a tough log that does not easily respond to lye type drain cleaners. Ask the tenants if they use coconut butter in the bath. Oils and fats can also combine with calcium in hard water to form a nasty, hard to dissolve "soap". Any chance they are pouring fats/oils/bacon grease down the grinder or dains? Als see https://usatoday30.usatoday.com/money/industries/environment/2011-04-27-clogged-sewers_n.htm
Sep 23, 2017 | Plumbing
Drain inside house from a c is over flowing.central air
I am a certified HVAC Technician. I have worked in the field since 1996. I have seen this hundreds of times, if not a thousand times, in the past. Every central air conditioning and heat pump system comes with TWO drain pans, The MAIN drain pan is located within the AIR HANDLER (blower) UNIT, while the EMERGENCY DRAIN PAN is extremely LARGE and sits under the ENTIRE AIR HANDLER (blower) UNIT. The ONLY time water will be INSIDE an EMERGENCY DRAIN PAN is when the MAIN DRAIN PAN condensate drain line is CLOGGED, causing the MAIN DRAIN PAN to overflow. What causes the drains pans OR the drain lines to become clogged is slime and scale from the condensate water as well as debris from within the attic that may have either been blown by the air or may have simply have fallen into the emergency drain pan; or some insects from the out of doors have traveled up into the PVC Drain line and built a nest on the downward side of the P-trap. The P-trap is designed to prevent critters from entering your home through the PVC drain lines. Most CLOGS occur at the P-TRAP location.
The BEST thing to do is:
1. Locate the WHITE PVC drain pipe outside your house and ensure there is NO water draining from it.
2. Locate the same WHITE PVC drain pipe inside your house. You should notice a "TEE" where two WHITE PVC drain pipes merge into ONE WHITE PVC drain pipe.
Follow the below steps, in the order shown:
A. FIRST, find another person to act as your second set of eyes at the end of the WHITE PVC Drain Line that is located outside of your home. That person will be looking for water or debris to EXIT the end of that WHITE PVC DRAIN LINE.
B. SECONDLY, locate the WHITE PVC "P-TRAP" inside your house. It is normally located within a couple to three feet of your indoor air handing (blower) unit.
C. THIRDLY, very gently lift the entire WHITE PVC drain line up in the air as high as you can without breaking it, and slam it down onto the rafters or attic floor or garage floor. You are attempting to dislodge the CLOG within the drain pipe WITHOUT having to actually CUT the PVC and without damaging or breaking the WHITE PVC. Depending on how old the system is, it may or may not be brittle; and it may not take much to damage or break the PVC, which will cause leaks. So, be very careful at this point.
D. Ask the person outside if anything has started to EXIT. You can ALSO usually hear water start to drain if you put your ear up to the drain line. If the person said "NO"and if you don't see the water level getting LOWER in the EMERGENCY drain pan, then REPEAT step "C" above.
E. If the person informs you that there IS water now starting to exit the WHITE PVC DRAIN PIPE, you should then wait until all water has drained from the EMERGENCY DRAIN PAN; and then pour at least 1 quart of BLEACH down that drain, from the EMERGENCY DRAIN PAN exit. The BLEACH will further clear out any SLIME which may be remaining within the "P-TRAP" and will also CLEAN OUT and DISINFECT that drain line.
If the above steps do NOT work for you, then prepare to go into the next LOGICAL phase of your attack. Please NOTE: I am limited to 10,000 characters in my response, so I'll repost additional STEPS in another RESPONSE. Good Luck!!!
Sep 05, 2012 | Goodman CLQ36AR49 Air Conditioner
A lot of lint left on the clothers after load finished. Rinsing twice more only helped a little. My machine is about 12 years old. Don't know model but it's a top-loading with mini-basket.
Have you ever cleaned the lint trap? many people do not realize that washing machines have lint traps too. It is usually located under the fabric softener cup in the agitator -- not sure on yours without model number. It has a lot of tiny holes in it that clog fairly easily. One trick to clean it is to put it down in the drum where the wash goes and run a wash cycle, but you may have to do a bit by hand as well. Hope this helps.
Feb 15, 2011 | GE Washing Machines
Dryer has heat but clothes are still wet we dryed a dog pillow that came open and the stuffing went all inside. we took the back off and the shoot for the lint trap but there was no more lint.
If your machine is running properly and you have heat as you say then you may have a clog in the main vent line from the dryer through your house.
Try running the dryer once with the vent hose disconnected. If it dries your know the clog is in the house's vent line. Unusual but it does happen if you have a lot of lint.
Check first at the immediate opening point in the wall there is often a 90 degree elbow where lint can trap.
The other place is the cover plate on the outside of your house. Some at are static and others have vents that open and close. Those too can trap lint and cause a problem.
If you know you have a clog in the house line somewhere but the opening and exit are not clogged then take a drain auger (same as used to clear a clogged toilet) and run it through. If you don't have one try your garden hose.
Good luck.
Please rate if this gives you some direction.
Mar 13, 2010 | Kenmore 62602 Electric Dryer
Disposal won't drain
sounds silly but try loading it with ice and turning it on if there is debris in it the shards of ice will help to clean it
Oct 07, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Lumpy acelleration
Use a fuel liquid fuel system cleaner for lines and injectors you have a partial blockage in the fuel system causing your car to not to receive enough fuel during hard acceleration. Raz,...
Aug 21, 2009 | 1995 Volkswagen Golf
Sebo automatic x1.1 loss of suction
Check that the dust channel from the sole plate/brush head isn't clogged. Open the trapdoor (usually orange in colour on the base) and inspect the dust channel - sometimes dog hair can get trapped between the main dust channel and the feeder. Other than that take off the main hose and see if there's a clog down there as well as the main part where the wand locks in at the back. Its reasonably easy to get a clog out from a Sebo X range model.
Jan 16, 2009 | Vacuums
Science & Laboratory Logo
116 people viewed this question
Top Science & Laboratory Experts
Gareth Cockram
Gareth Cockram
William McMath
ray gallant
Are you a Science and Laboratory Expert? Answer questions, earn points and help others
