Question about Suunto Watches
How do I fix a err12 message on a Suunto Ambit 2
Suunto Core watch - my watch is locked in the compass mode. How to I get it unlocked
RTFM
Suunto Core User Guide
ns.suunto.com/Manuals/Core/Userguides/Suunto_Core_Userguide_EN.pdf
This User Guide explains the Suunto Core features, how they work, and how ... nearest watch store to get the needed adjustments correctly done for you.
How to Set Up a New Suunto Core - YouTube
? 6:49
https://www.youtube.com/watch?v=_zywJcNNowU Jun 13, 2015 - Uploaded by Wearable4U
Great tutorial, clear and precise (beats reading the manual) many thanks ;-) ... Hi there. Just bought a suunto core ...
SUUNTO CORE USER MANUAL Pdf Download. - ManualsLib
https://www.manualslib.com > Brands > Suunto Manuals > Watch > CORE View and Download Suunto Core user manual online. Suunto Core: User Guide. Core Watch pdf manual download.
SUUNTO CORE QUICK MANUAL Pdf Download. - ManualsLib
https://www.manualslib.com > Brands > Suunto Manuals > Watch > CORE View and Download Suunto Core quick manual online. Suunto Core: Quick Start. Core Watch pdf manual download.
[PDF]Quick Guide - Trekkinn
www.trekkinn.com/images/pdf/especificaciones/eng_suunto_spec_10086.pdf Suunto Core brings together an altimeter, barometer and an electronic compass ... Please refer to the User Guide for detailed information on setting these. Suunto Core watch Google Search
Jun 17, 2017 | Suunto Watches
How can I order Suunto T6c Fusion watch strap to be delivered to Thailand? Or sent to America with a billing address in Thailand.
Thats easy. Follow this link and choose THAILAND from drop down menu. There you will find 5 addresses for SUUNTO dealers in your country. http://www.suunto.com/en/Support/Repair-Services/Service-Center-Locator/ If you are happy with this, please rate me and write testimonial.
Feb 25, 2011 | Suunto T6c Heart Rate Monitor and Fitness...
The ascent reading seems to be very inaccurate and the battery shows low after only a couple rides after installing a new battery. Anyone have a solution for the acent issue?
You need to send the watch into Suunto for service. The watch is obviously having an issue if it will not hold charge with a new battery and the Altimeter is not working correctly.
The Altimeters are Barometric pressure related and occasionally something goes wrong.
My experience is that Suunto is very good about fixing and/ or replacing when this issue arises.
Jan 24, 2011 | Suunto T6c Heart Rate Monitor and Fitness...
I have a suunto stinger dive watch after i changed the battery the ACW stays on the screen .
open watch again and press tiny reset 'button' with a pin. That's how I fixed the same problem
Jan 11, 2011 | Suunto Replacement Strap - Stinger...
I'm trying to reset the altimeter and sea pressure but the watch. I've followed the instructions but the watch more often that not reverts back to default settings or does not respond to the calibrations...
http://www.suunto.com/en/Products/Outdoor_Sports_Instruments/Suunto-Vector/Suunto-Vector-black/#Manuals
If you continue to have problems with your watch, and the instructions in the user manual don't resolve your problem, you may have to return the watch to Suunto.
Your watch must be registered with them, you'll need the serial number of the watch, which is located on the back case. You'll have to get an RMA from Suunto in order to send it back to them.
Here's their warranty info: http://www.suunto.com/en-us/Support/Warranty-information/
Oct 11, 2009 | Suunto Vector Wristwatch
Changing metric to Imperial on Suunto Vector
It's in the manual. I did it on mine.
Dec 25, 2008 | Suunto Vector Wristwatch
Watches Logo
Top Suunto Watches Experts
Arturs Kalnins
Arturs Kalnins
Andrew Taylor
Andrew Taylor
Are you a Suunto Watch Expert? Answer questions, earn points and help others
