Question about LG Washing Machines
Have a LG fuzzy logic 8.5kg top loader washing machine which doesn't drain the water when it comes to the rinse.
Cleared the filter but did fix it. Makes a vibrating sound and doesn't continue with the end of washing process
  • Alan Matzke
    Alan Matzke Jan 11, 2018
    Hi Chris McCarthy, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? need model # please.
2 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: LG Top Loader Fuzzy Logic 5.5. The water
No you just need to get the drain hose up higher...the water is siphoning out and is either caused by the end of the drain hose still in water and not having an air gap or the hose is not going up higher then the top of your washer...
Lifting the hose up should give you an air gap and get the hose high enough to stop the siphoning...
heatman101
Posted on Apr 28, 2010
Testimonial: "I am extremely impressed that this won't cost a call out service fee. . . and looking like a bimbo. thanks, heatman!"
I have a top lg fuzzy logic washing mechine, it stops at rinse position , display lights , gear are all working. whats the fault please ?
this usually happens when the water pump or the hoses are clogged and it cannot drain, it stops there and does nothing
Feb 10, 2015 | LG Washing Machines
I have a LG 15.0kg top loading fuzzy logic washing machine. Machine does not empty water out. What could the problem be?
i have a lg fuzzy logic 15.0kg and on fuzzy mode , it continue to supply water and do not wash clothes
please can anyone help me what can i do .
Oct 26, 2012 | LG Washing Machines
I have a LG top loader Fuzzy logic 6.5kg model WF-T655th spin cylce not working, the light is flashing. I have a load in the machine, how do I emppty the water out of it. Have misplace the manual.
I have a LG washing machine WTF655TH, it has stopped working, its full of water, but when you push the one button, it trips, how do i get it working again
Jan 16, 2012 | LG Washing Machines
LG 8kg Fuzzy logic top loader and it will wash and fill the water but the water wont stop when it wash, rinse or spin it, the water also come out even there is no power to the machine.
Assuming the water is coming in even when unit is unplugged from wall. You should to replace the water inlet valves where the hoses connect to the machine. You need to unplug the power and remove the top, disconnect the hoses unhook the wire harness plugs, unscrew the hose valve hex nut and remove valve. Install the new one in reverse order.
May 16, 2011 | Washing Machines
Hi i have an LG 5kg Fuzzy logic top loader and it will wash and fill the water but wont rinse or spin it does not beep or anything it just stops and the time displays stays on the same numbers and i can...
Need to check during the wash cycle that the power goes to the motor during the rinse or spin cycle. Try and see if you can manually go to the spin cycle without the fuzzy logic. If so the program controller unit is a suspect as the microprocessor internal memory is faulty and executes the program with error or no output.
Jan 21, 2011 | Washing Machines
heatman101
Apr 27, 2010 | LG WFT1071TP Top Load Washer
I have an LG Fuzzy Logic top loader. it keeps draining water out
If it's really as you described, when draining at the same time filling up, then it's a problem in the main control board. You'll need some electronics knowledge to repair it, or just replace the main board
Aug 07, 2009 | Washing Machines
I have a Brand LG Top loader washing machine (Fuzzy Logic WF-T9235TP), it continue draining the water even if I am starting to wash
You probably have the drain hose too far down the standpipe and it is siphoning out. Check that first. If that doesn't work, look up Catriver, sounds like that cat knows his stuff. Tenbears.
Dec 20, 2008 | LG WFT1071TP Top Load Washer
Water can't drain out properly
hi
i think all the fuzzy logic machines have an electric pump so it is maybe not running to pump the water out or i have had problems with the electronics that run the pump
cheers grantsreps
Sep 29, 2008 | LG Washing Machines
Washing Machines Logo
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Oloyede Monsuru
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
