SOURCE: Keep getting message Press Enter to Align Cartridges
after each alignment you press enter key or start key not cancel key,
SOURCE: cannot print - keep getting paper jam message -
Hi
try cleaning the paper jam first
check out the following link,this should help you a great deal
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00265823&cc=us&lc=en&dlc=en&product=422000
SOURCE: What do I need to
Hello 1 Press MENU to display the MENU screen, and then press [=> or <=] to select "System Options". 2 Press [Up or Down] to select "Input Terminal Setting", and then press ENTER. 3 Press [Up or Down] to select "PC input", and then press ENTER. 4 Press [Up or Down] to select a specifi c adjustment item, and then press ENTER to set each item. 5 Press [Up or Down] or [=> or <=] to select or adjust the desired Adjusting the PC Image Auto Sync. (for Analog PC Input Mode Only) For automatically adjusting the PC image. Yes: Auto Sync. starts and "Now adjusting the image." displays. No: This function does not work. When "Auto Sync." is successful, "Completed" displays. If not, "Auto Sync." failed. "Auto Sync." may fail even if "Completed" displays. "Auto Sync." may fail if the computer image has low resolution, has unclear (black) edges, or is moved while executing "Auto Sync.". Be sure to connect the PC to the TV and switch it on before
setting, and then press ENTER.
starting "Auto Sync.".
OK.
SOURCE: How to adjust for best picture a Sharp Aquos
This sounds like a setting that can be adjusted. What I like about some of the Sharp televisions is the av mode setting (preset brightness/contrast adjustments). I am not looking at the manual for this model so I'm not sure if this is an option on this television. However with this being a high end aquos model there is free assistance available to you. You can register your television at aquos advantage and chat live with an aquos advisor at Sharp's Midwest Corporate Headquarters. The agent may advise you to call in if your television need and Industry Initialization because you have to be talked through it. I advise the chat reps initially because when you call you aren't able to speak with the Midwest Corporate Sharp reps unless your call is being escalated.
http://www.aquosadvantage.com
SOURCE: My 60" sharp AQUOS QUATTRON won't come on
Are you aware you have posted this problem in the car and truck category? Please post the problem under the correct category so the right expert will see the question.
