Question about Saeco VIA Venezia
My wife left the coffee machine on for four days and its now dead. I opened it up to see if anything burnt out, but it looks ok. I'm sure we're not the first to do this. Is there a solution ? a part we can replace ?
  • enda_mahoney Aug 09, 2009
    I didn't understand the answer, I checked inside but couldn't see what to do, but the answer did encourage me to go to a Saeco repair specialist and they agreed it as the thermo. They fixed it for $80 whish is a heck of a lot cheaper than a new machine.
    President:
  • 1,618 Answers
Check the thermostats on top of the boiler.
Posted on Jul 30, 2009
  • Ernest R
    Ernest R Aug 10, 2009
    Using an ohmsmeter, disconnect one (or both) of the leads on the thermostat ( small cylinder sitting on the top or side of boiler with 2 electrical connections on it) and check for resistance. Check items 12, 16, and 17.
  • Ernest R
    Ernest R Aug 14, 2009
    If you use the volt meter it will be the only way to check the thermostats, put the red probe on one side and the black probe on the other (MAKE SURE THE POWER CORD IS DISCONNECTED FROM THE SOURCE) and the electrical connectors on the thermostats at least one has to be disconnected. The meter if set to Ohms will give a reading of 000 or something similar as long as it is not reading "1" if it is then the thermostat is damaged.
Hi Es, I have the same problem, are you able to go into a little more detail? What should I actually be looking for on the thermostats? Is there also a fuse that could have blown?
Posted on Aug 08, 2009
Hi, I have the same machine with the same problem - well, it wasn't left on for 4 days, it just isn't turning on. Are you able to be a little more detailed? What should I look for? Is there a fuse in the unit that can blow?
Cheers,
Anthony
Miele coffee maker will not turn on. Not responsive to power button or opening/closing door (which in pior use brought it out of sleep and powered up). Please help. Thanks
same thing happened to mine - it is exactly 5 years old (just out of warranty) - The problem was the power button. It gets crudded up and doesn't make a connection. When pressing the button moved less and less as crud built up but it still worked every day - and one day - nada, it just stopped powering on. (my wife just told me she got it to switch on a few days ago... - so I think we have isolated the problem), it is the crud under the power button. You can try and squirt contact cleaner on it. It was totally dead - nothing - and it is the crud buildup... Whew!
Nov 04, 2016 | Miele Coffee Makers & Espresso Machines
DCC-1150 Coffee Maker does not have power
Talked to Cuisinart tech support and they told me to unplug and leave it for 2 hours... that resets it to the factory defaults.
It looks like a thermal fuse might have blown inside your appliance.
If a thermal fuse has failed, there is probably another problem inside.
If the appliance is 4 months old, still cover under manufacturers warranty, Call the Cuisinart customer service to ask them where to find an authorized service center.
Hope this works for you.
Mar 12, 2008 | Cuisinart DCC-1200 Coffee Maker
Where is the ground coffee shoot?
Open the door and you will see four bins top right is the bean container - bottom right is the water container - bottom left is the waste container - top left is and empty storage bin - remove the top left bin and you will see a flap door - lift the door up and insert your ground coffee.
Jul 18, 2014 | Miele CVA 4066 Stainless Steel
I have no power at all, its dead... and fuse is good!?Checked socket, cable tomachine is fine but machine does not work at all, no light, no anything!!
Hi
On some Classics there is a reset button on the left side of the boiler. Its the red button between the 2 wires on the thermostat. Your sure the fuse on top of the boiler is good?
Aug 16, 2011 | Gaggia Classic Espresso Machine
Does not heat up or do anything when turned on
Inside is a heating element, most likely burnt out. Because that type of machine is self contained unit it is time to throw it out, mr coffee machines are dime a dozen these days. Can pick up another at wall mart for about 30 bucks. Not worth even attempting to fix or take apart a self contained factory machine . Sorry there is no good news, simple fix on that type of machine, unless you have warranty on it.
Jun 06, 2011 | Mr. Coffee Classic 12-Cup Coffeemaker -...
My wife purchased a Cook Essentials Pressure Cooker, Model CEPC800 from QVC approximately three and a half years ago. We've used it about twenty times. On our last attempt, the unit was programmed to cook...
You can call the company and they will give you a refund. I am looking for a liner for the 8 quart pressure cooker, if you decide to seel the liner could you please email me at inkedbody@hotmail.com? I have been looking for one for over a year...with no luck.
Nov 03, 2010 | Cook's Essentials Cooks Essentials Arome...
My machine won't do anything when it's turned on. It blows the fuse in the kitchen every time. I looked in the back and nothing appears to be grossly burnt or destroyed. Any suggestions? I'm a mess without...
It is possible that the boiler over heated and blew the element, disconnect one of the legs and turn machine on, if it trips breaker, then replace element.
Sep 08, 2010 | Saeco Classico Espresso Machine
Steam still coming through brew group even when pump not ON
I posted response and solution to similar issue see post below and comments :
YOU NEED TO LET MACHINE COOL OFF AFTER YOU TURN IT OFF OUCH!!
You can release pressure placing a cup under steam wand open slowly and partially while machine is OFF and let hiss out slowly. Then open cup slowly if you have to force it open DON'T. That PUCK sound can make you afraid of your machine can't it. I wont admit I haven't done that four or five times.
posted by bronwenmair on Jul 08, 2008 Report abuse
We have a Saeco Classico that worked very well when we first got the machine. Now the coffee is bitter and there is no crema in the shot at all. We tried changing grinds and tamping, nothing seems to work. Can you help? Thanks so much. We miss our morning coffee :-)
Jan 20, 2009 | Saeco Classico Espresso Machine
Saeco Incanto not grinding
Hi Chris,
The leaking is your steam valve that has to be replaced, you can see this if you open the door and look up in the right corner there you will see water drip.
If not then you have a pipe or boiler leak.
How old is your machine?
How often do you descale the machine?
When you try to make a cup of coffee, starts the grinder for two seconds or is it dead?
Hope this will help you.
Jul 19, 2008 | Coffee Makers & Espresso Machines
My Machine leakes water
Most likely your boiler gasket has a leak
here can you download all diagrams you need to figure out what is wrong with your machine
SAECO
May 23, 2008 | Saeco Vienna De Luxe Espresso Machine
Saeco VIA Venezia Logo
290 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
