Question about Cozy Heating & Cooling
Cozy wall heater. pilot stays on heater will go on once in a while by moving thermostat up. will run for about a minute then won't react to thermostat when i try to get it going again.
    Habit-Forming:
  • 100 Answers
Shut the power off. Pull the thermostat off the wall and jumper the two wires, meaning put them together. Turn the power back on and if the heater works fine its in the thermostat
Posted on Dec 08, 2017
hotuna
  • 288 Answers
SOURCE: cozy wall heater lights fine then goes out after 3 or 4 minutes
Make sure all the wire connections are good and tight. Next lift off the cover and look for a little thermal disc mounted up by top of the heat exchanger. Most have a re-set button but not all. If you have this ,by-pass it ,see if that solves the problem, if so it may be defective, or doing its job and you have a venting problem. If you don't have this and have changed the thermocouple (was it a copper tube with a fitting that screwed into the gas valve, or did it have 2 wires, that is a pilot generator, kind of same thing) make sure the probe is set correct, with the pilot flame heating the top 1/3rd of the probe. The only thing left is the gas valve.
Posted on Dec 25, 2007
  • 3335 Answers
SOURCE: cozy gravity one sided wall heater...pilot won't
how by extending the duct work will it make the gas valve work ?
if the pilotkeeps going out clean pilot jet , or if the power unit has gone in the gas valve then you would have to change the valve , don't get the flue bit ?
Posted on Feb 24, 2009
shastalaker7
  • 1515 Answers
SOURCE: Cozy Heater not igniting and heating
Sounds like to me that the pilot ignition is not lighting pilot lite. You have to be careful when jumping out the stat that you jump the right wires.It must be an automatic Ignitor, or push button.I would change the module out. That should take care of the problem. Look at the schematics so you know what to look for. Please let me know, Sincerely, Shastalaker7
Posted on Nov 07, 2009
shastalaker7
  • 1515 Answers
SOURCE: pilot stays lit, but apliance will not turn on
Hi, I just helped a gentleman go through to solve problems on 11 of these wall heaters he had lined up in a row, so this should not take to long. It is a good sign that the pilot is lite and stays lite. If the burner is not firing up on a call from the thermostat, if you will follow my steps you can fix this. You may need to get back to me after I have you check a couple of things. First, go to the T-stat and remove cover. Then with a small bladed screw driver, lossen screws to remove the T-stat its self. This will leave the sub-base and you will see the 2 wire connections. Should be a red and white wire. Could be different colors but this is standard colors. What we are doing is, by passing the thermostat completely to see if it is faulty. Find a piece of electrical wire or even a piece of speaker wire will work as long as it is split down the middle to make one wire. Why, is because we are going to jump from one terminal to the other. The wire must be bare on each end, the insulation removed. Dont worry as this is a milivolt unit and there for you will be in no danger of shock what so ever, trust me. Take the wire and touch and hold it to one of the terminals that have a wire to it. Now take the other end and touch it to the other wired terminal. The heater should fire right up. If so, the T-stat is faulty and you need a heat only milivolt thermostat you can get at Home Depot or any hardware store. If it does not come on, follow the 2 thermostat wires down to where they connect to the main gas valve and do the same there. Jump them out like you did. If it fires up then, the problem is with the 2 wires in the wall, and you will need to pull new wire through from the stat to valve. I don't think this is the problem though. Make sure if your gas valve has the knob type on it, it is turned to the on position and not pilot. You may have an open high limit switch located at the upper part of the heater. It is a round disc with the same wire connected to one side and comes out the other. If the heater were to over heat for some reason, this would open its contact and shut the system down. A safety switch. Do the checks I have asked of you and this should solve the problem or show you what is wrong. If not contact me and we will go from there. Let me no one way or another please. Good Luck.
Sincerely,
Shastalaker7
PS You can do this, I have confidence in you!!
Posted on Jan 19, 2010
  • 17 Answers
SOURCE: Heater turns on and off randomly. Mostly the
hi there
could have a faulty gas valve which may let in to much gas.extra load from the stove may be correcting this.
to much gas /too rich a mixture can affect internal temperatures causing thermostats to fail.
does the stove burn a nice strong bright blue flame?.
hope this helps the mystery
Posted on Dec 19, 2010
I have a Cozy W355D wall furnace. It's difficult to turn on. Replaced the thermostat, that helped some, but still have to turn it off, wait a few minutes, and turn it back on. Often still won't light.
So are you saying the pilot stays lit, but the main burner won't always fire. If this is a millivolt system you could have a weak pilot flame, not getting the pilot generator hot enough or you could have a weak pilot generator. If you are handy you can try cleaning the pilot. It may be better for a qualified service tech.
Jan 30, 2017 | Cozy Heating & Cooling
Cozy gas wall heater won't ignite, pilot light is on
There are two types of igniters, spark-type or glow heater. The glow heaters wear out and crack or break and the spark-type spark gap gets fouled or dirty. Both could have electronics problems that drive the glow heater or spark systems. The Filtrete thermostat is not the issue. While rapping the unit makes the glow igniter come back together to glow again.
Jan 14, 2014 | Cozy Heating & Cooling
The pilot will not stay lit in our Cozy Direct Vent Wall Furnace CDV335B. Problem occurs with winds. Last heating season, replaced powerpile, thermostat, ignitor, gas valve, and pilot burner. Any...
There is a wind shield for this unit, call 502-589-5380 and ask for a drawing for the wind shield and have it made out of 26 gauge sheet metal.
Nov 27, 2010 | Cozy (W352E) Heater
I have a Cozy gas heater is there any way of changing the mechanical nob thermostat to a regular wall mount one
need to change the gas valve and add a pilot generator and stat wire and a wall stat. If your unit is natural gas part numbers are gas valve 84085// pilot gen. 70098.
Nov 07, 2010 | Cozy (W352E) Heater
Where I do I light the pilot light on my Cozy Wall Heater? I know it needs to be lit somewhere on the bottom of the unit but I cannot find the spot and my heater will not turn on. I am a senior and not...
in front of the burner it is next to a copper tube(black if it has been burned)! it angles a little towards the copper tube! u turn the knob on gas valve to pilot then hold down and light hold for one minute then turn it to the on position (u might have to push down slightly as u turn the knob) make sure u have thermostat to the lowest setting before u light the pilot so it won't turn on while u have your face too close to the heater then turn your thermostat up to desired temperature when it is on the the on position! Good Luck!!
My older Cozy cf353c counterflow wall heater gas shuts off pilot after it has run a while. I replaced the bad fan switch thermostat[ fan would not run untill changed] but not the other lemit switch . Could...
first have the heat exchanger inspected for a hole or crack, if there is an oval to round adpt. on top of unit or an elbow in vent this can cause the heat exchanger to split open and also cause what you are talking about.
Jan 14, 2010 | Cozy (W352E) Heater
Need to light pilot cozy brand gas wall heater
Is there a "Pilot" marking on the knob? Try moving the knob 1/2 way between on and off and depress the knob. If you are in the correct location, the knob should depress in about 3/8 of an inch. Once you find the location where you can depress the knob, there should be a red sparker button that you can snap to light the pilot. Depress the pilot knob and snap the button a few times. There may be a small viewing port at the pilot. It may be covered by a small metal shield held on by a thumb screw. You can remove the shield to view the flame. OK so now you can depress the pilot knob, snap the sparker, look for the flame while still holding down the pilot knob and count to 30. Slowly release the pilot knob and check to see if the pilot is still on. Once it stays lit, rotate the knob to the "ON" position.
Jan 04, 2010 | Cozy Heating & Cooling
Cozy gravity one sided wall heater...pilot won't
Feb 20, 2009 | Cozy (W352E) Heater
Cozy dual sided wall heater
There isn't much to these things, its either the pilot generator or the gas valve. Or maybe both, try the first, then the second.
Dec 19, 2007 | Cozy (W352E) Heater
Heating & Cooling Logo
54 people viewed this question
Top Cozy Heating & Cooling Experts
Paul Carew
vance jones
Mack Baxter
Are you a Cozy Heating and Cooling Expert? Answer questions, earn points and help others
