Question about Yamaha CDC-585 5-Disc CD Changer
Cd player stuck
My cd player is stuck in the open position. I hear it trying to close but,
won't budge. I have tried all the obvious things off/on, no cd's loose, powe off etc. Button when pushed indicates " open ' slightly adjusts but, won't close.
I have tried GENTLY to shut it manually but, don't want to force it same time when I push open close button. It was working fine until now. Help!
  • 1,175 Answers
Re: cd player stuck
It will have to have the coverr taken off and the drawer belt replaced.
Find a stereo repair place.
Posted on Jan 12, 2009
0 characters
3 Points
CD-72 Marantz CD Player disc tray is stuck in the shut position.
You might have to open the player and see why. remember to unplug till you need to see if you can get it to work or not.
Sep 06, 2012 | CD Players
Seeburg jukebox ay160 won't select record
(1) Make sure that the credit unit is not stuck and that all of the contacts open and close correctly while manually operating the solenoids. Lubricate it if the wheel does not turn freely. (2) Make sure that there are credits on the machine. (3) If it still wont select check fuses or (4) try pressing the letter and the number simultaneously, some "free play" set ups will work this way.
Jun 09, 2012 | CD Players
Cd tray won't stay open--when you press the "open" button, it opens but then closes again immediately.
It has a misaligned loading mechanism. I have dealt with this kind of problem before. What is happening is that before the tray have a chance to open all the way it gets stuck and gets pulled back in.
May 24, 2011 | Marantz CD5001 CD Player
Door to load cd's wont open or close without help.
hello i have had the same problem with my 5 cd changer,i way i solved this was to turn the player top slide down then do this care fully ,shake it gently and see if a cd came out of it, groove sit in the player.if you hear a rattle than there is a stray cd in the device. you have got to shake the cd to the front of the cd dawer to take it out with a thin ruler or a butter knife but be care ful with the knife preess on the open button wale trying to slide the butter knife between the stuck cd and the inside of the cd sit cation be care.
Apr 25, 2009 | CD Players
Fisher CD-RW1000 2-Disc CD-dvd stuck in player
hmmmm.... try to take off the cover of your dvd player and observe it.(if you try my advice, try it in your own risk and with caution) then check the tray maybe there is something got stuck in there and also check the gears, if nothing, a belt just came off. check the motor too, I guess It has 2 switches too. clean them up. and then try to power up.
(keep you fingers away at the power supply section)
Jan 29, 2008 | Fisher CD-RW1000 2-Disc CD Recorder
Yamaha CDC-585 5-Disc CD Changer Logo
402 people viewed this question
Top Yamaha CD Players Experts
Ben Armstrong
Are you a Yamaha CD Player Expert? Answer questions, earn points and help others
