Question about Refrigerators
Flooding when freezer defrosts
I have an Amana Temp Assure side-by side fridge. When the freezer defrosts, instead of the water ending up in the tray under the fridge section (the right side), it ends up at the bottom of the freezer. So this water will refreeze, then melt, and then cause a minor flood.
Thanks!
    New Friend:
  • 63 Answers
Make sure the refrigerator is level and the drain tube is not clogged. This is the most common cause of water pooling.
Posted on Jul 29, 2009
Amana refrigerator A4TXNWFWWO1 >top freezer, bottom fridge it's only 10 months old refrigerator won't get colder than 55 degrees freezer is working
There is something plugging the drain line in the freezer which carries water from the defrost cycle to your evap drain tray in the bottom of your fridge. The water has built up and froze plugging the flow of air from freezer to fridge.... find the line and unplug it and let fridge sit and thaw overnight and then some more.
Jul 19, 2011 | Amana A4TXNWFWW Top Freezer Refrigerator
I have an Amana Temp Assure refrigerator (model# on panel BB20 or BRF20) The fridge is not cooling. The freezer appears to be working but here is extra frost in the freezer - mostly on the right side. If I...
I would check the evaporator fan and make sure that is is turning to blow the cold air from the freezer section to the refrigerator section. With bottom mount freezer, that fan is very important since cold air drops.
If the fan is operational then you need to check out the defrost circuit (defrost heater, defrost thermostant, defrost timer) and make sure that is operating. If you take off the back panel (interior) of the freezer, and see a lot of ice build up then you will need to defrost the unit (a hair dryer will speed up the process) and then troubleshoot the defrost circuit and order the parts you will need to fix it. Once defrosted, the unit should work for a several days to a couple of weeks before the ice buildup affects the unit again, which will give you time to receive the parts you need.
NOTE: When you defrost the unit make sure you are ready to deal with all the water. Either spongs and a bucket or a wet/dry vacuum.
Jul 14, 2011 | Refrigerators
I just moved into an apartment that has a side by side amana 22 refrigerator in it. The freezer section is fine everything is frozen and the tempeture is where it should be. The fridge side however, is...
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 07, 2010 | Amana Refrigerators
Light on but not cooliong or freezing. If you put your hand right up to the temp assure in the center of the fridge, you can feel very little air coming out and it's not really cold.
heatman101
Sep 04, 2010 | Amana ARB224RCB Bottom Freezer...
I have an Amana fridge with bottom freezer that keeps freezing up. I replaced the defrost timer and that fixed it for about two weeks and now it's freezing up again. I think the defrost timer has broke...
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
Oct 16, 2009 | Amana 22.6 cu. ft. Side-By-Side...
My Amana (DRS2662A) fridge and freezer not cooling.
Part 1541 is your timerhttp://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=DRS2662AC&productCategoryId=0165000&brandId=1268&modelName=SIDE-BY-SIDE-REFRIGERATOR&diagramPageId=00012&componentDescription=MACHINE%20COMPARTMENT&documentId=M0503273&backToLink=Return%20to%20part%20list
Sep 21, 2009 | Amana 22.6 cu. ft. Side-By-Side...
I have an Amanda side by side, the fridge temp
Look in the freezer side for a ice buildup on the back wall.
Ice= defrost parts issue.
Check the fan in the freezer. Is it running?
Not running? Could be a defrost thermostat issue or a bad fan motor.
Mar 03, 2009 | Amana ASB 2623 Side by Side Refrigerator
Freezer is not making ice and the temp seems to be dropping.
You may have a defrost issue,Please check and see if it has an accumulation of ice build up in the back and post back.
Jan 10, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Amana XRSS287BB side by side fridge freezer (3 years old)
you may try hard restart by shuting the fridge off and unplugging it from the wall . plug in back in and after 5 min turn it back on . close both doors and wait one hour . check the temp. if the unit still will not respond calll the local woranty amana repairman only. hope this helps you
Jul 01, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Refrigerators Logo
122 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
