Question about Panasonic TH-50PH9UK 50 in. Plasma Television
Panasonic TH-50PH9UK screen keeps going blank after 10 minutes
My panasonic TH-50PH9UK has a problem. After 5-10 minutes of being turned on and working fine, the screen goes black, essentially turning itself off, although the power light remains on. This problem continues to occur every time I turn the tv on, although it will not work for at least 10 minutes after turning off the tv each time. Does this sound like something easily repaired, and if so, any ideas how much, as I don't think it is under warranrty any longer.
SOURCE: Panasonic 32" HDTV keeps turning off
Check or have a repair tech check connectors AP1 and AP2. Vibration rattles the power supply board (a crappy design, as the board is almost "floating") and causes the wires in the connectors to break, and may make intermittent contact. Heat may also cause intemittent contact. A very common flaw.
Posted on May 06, 2008
  • 1779 Answers
SOURCE: TH-42PX80U JUST TURNED ITSELF OFF
The 7 blinks indicates that a failure has happened within the Y main and the upper and lower y drive panels. I recommend you taking it in to a Service center for and evaluation.
Posted on May 23, 2009
  • 8457 Answers
SOURCE: TH-50PZ80U POWER INDICATOR LIGHT KEEPS BLINKING
Power board it dead,take the tv aparts.Check for Capacitors parts for puff up or burst open.Know how to solders?replaced these capacitors in the power board.Or replaced the whole power board.Tries Shopjimmy.com,Ebay.com.
Posted on Jan 19, 2010
SOURCE: I HAVE A PANASONIC PLASMA TV TH-50PZ80U MODEL #.
With this symptom, it is impossible to tell what the exact "Cause" of this symptom is. The LED's do not tell us what is wrong, sometimes it may indicate the "Area" in your case it is the X board. BUT thats NOT where the "Fault is" thats just the part that is affected. These days unlike the "Old" analogue days it just isn't realistically possible to fix anything but the most basic of problems with todays sophisticated units. This is quite apart from the Safety aspect, any unit that can cause a firs or have an explosion, or both, is NOT to be treated lightly, and and the repairer, of the unit is legally responsible, another thing to think about. Also, one must have tools, a Multimeter, a soldering iron, a deslodering iron, an oscilloscope, a signal tracer, tools, and most important of all, a Service Manual, without which, there is no way to even begin to understand and fix it, and more importantly Program it, AFTER it has been fixed. As these days a TV, is a PC, a Tuner, and an HDTV Monitor, and more, all in one. in the "old" days TV"s were more, rudimentary, and built to last for 20 years, and a "Parts" supply was set aside. They usually used to fail for only a few reasons, and they while still difficult, were less difficult to repair. Electrical knowledge was transferable, and they could be and would respond to, This-is-the-symptom-This-us-the-Fix, But that no longer applies, as now, it can be a Fault on I squared Bus, or "Sensor" failure, or it simple may have "Crashed" just like a PC, It could be a Diode go bad, and that will stop the whole thing. You see, in the day, the sets were Very "Fault Tolerant" because they were Analouge, and a faulty, component, or more sometimes, the set would always diplay something usually, and when they didn't it was one of anly a few things, sure there are always the horrid ones, and there are pleanty of those, but all in all it was quite easy. But with Digital Electronics, it either goes, or it doesnt, there are usualy few half measures. I mean thats the definition of logic either going or not. So it can take very little to completely paralyse a set, and generally give the only sysmptom, it can, by not working, usually No picture, or the like. So you, see the list is endless almost for any given SYMPTOM, as that is what is being seen, not the cause, as I keep going on about. Also any fault, usually involves the Power Supply, it is either the cause, the cause of the damage, or it is damaged. or ALL of them. Then after you have done the electronic repairs, you then must program the set to work, and align, and set up in general, any one of those settings missed or done wrong, back to square one. So, it is nearly always my professional opinion that one should always get a "Quote" form the manufacturers recommended service center, I cannot stress how important that last point is. It is even worth the cost of shipping. you see an authorised service agent, will have trained staff, trained on their brand, also they have first hand access to parts, original parts. This will actually save you money and ensure you can actually get it back fixed. Of course asking for a "Quote" also gives on the option of repair or replace. Often my clients,do not go through with repair, unless it is moderate, but in some of the more costly jobs they see it, as do i, that a replacement, with a warranty, is a better option. As an aside here, one could then tear the TV down, and sell the Known Good bits. You'd be surprised who needs parts, i myself often must by from third party sources to effect a repair. So money could be recouped, somewhat,and help out someone else. Anyway thats my 10c worth.
Posted on Apr 02, 2010
tvhelp-Dave
  • 178 Answers
SOURCE: TH-42PZ80U Panasonic Plasma, red light flashes 10 times
Panasonic said "A" board,
A board SOS Detect (Explanation)
10 Blinks SOS: The voltage regulators IC5400 and IC5401 in the A board generate SUB9V and SUB5V. The 9V and 5V from these ICs are monitored by IC1100. Any abnormality on the SUB9V or SUB5V lines, triggers the shutdown circuit and the MPU shuts down the unit. The power LED blinks 10 times.
But need to measure the connection SC2, if it short, it will be the SC board.
The knowledge obtain from: Real case of repair by myself.
Information from Panasonic training manual.
Posted on May 10, 2010
Problem with plasma display on Panasonic TH-50PH9UK television
there is an x-buffer and a y-buffer. by disconnecting these and noticing if the picture changes you will be able to identify if it is on of these boards or if it is the screen itself. Youtube also has a lot of helpful videos. hope this helps
Jan 21, 2015 | Panasonic TH-50PH9UK 50 in. Plasma...
MY TV THYE LIGHT FLAS 10 TIMES AFTER ON
if you want to fix it ur self, open it and tell me when ur ready ..
www.tvrepair.localdomain.me
Jan 13, 2014 | Panasonic TH-50PH9UK 50 in. Plasma...
Everything is red on my panasonic th-50ph9uk.
I have a Panasonic plasma 55 inch and the screen went green and pink is this fixable
Apr 07, 2013 | Panasonic TH-50PH9UK 50 in. Plasma...
I have a Panasonic TH-50PH9. The green ligth is on but I have nothing on the screen. When I push any botton on the remote, the green light blinks. No menu. nothing. Any ideas would be appreciated
Hi, First of all check your cable connections on the back make sure they are properly connected and in the right place.
Secondly make sure the settings in the menu are set to TV, DVD etc... what you want to watch.
Thirdly read you MANUAL for more info.
Jun 04, 2011 | Panasonic TH-50PH9UK 50 in. Plasma...
My Panasonic TH-50PZ7OOU will not turn on. The red light on the lower left is on, but the screen is completely dark. pressing power button on both TV and Remote control gets no response.
Try to power it up with the remote control. When you hear the relay's click, see how many times the red light flashes. This will tell us what the fault is.
Apr 22, 2011 | Panasonic TH-50PH9UK 50 in. Plasma...
My 50" panasonic tv screen goes completely green I turn off tv and restart and the picture is still great, but it is doing this more frequently
my 50' panasonic some channels are in another lanuage then some channels have no volume the people mouth are moving but no words then some channels are good.
Oct 03, 2010 | Panasonic TH-50PH9UK 50 in. Plasma...
Screen keeps turning green
My Panasonic Plasma television started doing a green screen also. When it does it to me, is when I use the Last button or the Fav button. This is with Charter Communication. If I go back and forth, to various stations, then one station will turn green. So by trial and error, I found that when I clicked on a station, the screen would turn green. I had to push the Guide button, then the guide would come up, then push the Exit button, to get rid of the Guide, and then it would be on the station you wanted. If that does not work, then I have to just turn the TV off and turn it back on. It is rather annoying, however, as long as I can get rid of it, I can deal with it, instead of always turning the TV off. I don't know if this happens with all TV's or just Plasmas. If it does, I will not get another Plasma, if it happens with all TV's, maybe it is the remote, or the cable company. I just don't know.
May 16, 2009 | Panasonic TH-50PH9UK 50 in. Plasma...
Viera TH-65PZ850U
Without investigation it is impossible to know what failed. There are a number of boards in that set where there is fairly high current used. It is possible that some components have failed.
The Panasonic service rep would service the set by swapping out the failed modules. If the set is an older model the modules may no longer be available. You can take the set in for an estimate to see if the parts are available, and to see if the set is worth to service.
Jerry G.
Jan 17, 2009 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Panasonic TH-50PH9UK 50 in. Plasma Television Logo
87 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
