Question about Dishwashers
Dirty water is standing in the bottom of washer when finished what to do?
  • 11,896 Answers
Check the drain for clogs and also the drain screen. Flush washer with new water. You can use a bucket of water and the drain cycle
Posted on Jul 29, 2009
How to diagnose the problem
check the outlet pipe to see that the water can flow easily, not bent. It looks like that the dishwasher is unable to drain the water through the hose.
anna poorani
Jun 30, 2014 | Samsung DMT800RHS Dishwasher
I have a ADG450 about 7 years old, the problem is there is dirty water left at the bottom of the dishwasher after finishing the cycle and the dishes look as if they have had the final rinse in the dirty...
check the pipe leading from the dishwasher to the outlet, maybe under sink. this needs to be raise up as water will flow back into washer. Had this problem myself, felt foolish when the repair man just tied it up and left. !
Jan 03, 2011 | Whirlpool ADG450 Slim-Line Built-in...
Won't finish cycle, water still in tub, code nd
check the following to address this issue.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
Jun 19, 2009 | Maytag Neptune MAH5500B Front Load Washer
Soapy water standing in bottom not rinsing soap off dishes
It sounds as if it is not draining. Try to trace the drain line under the sink. Usually it goes into a disposall. The port where it connects to the disposall may be clogged. Another thought. If you had the disposall replaced recently they may not have taken the knock out plug out which would give the drain water no where to go.
Apr 09, 2009 | GE Tritonr XL GSD6260JCC Dishwasher
Dishes are dirty when finished water still in bottom of machine
you have a drian and /or pump and motor you didnt give the brand . It would help. call 704-819-6557 for free tech support and parts.
Mar 14, 2009 | Dishwashers
Standing water in washer after cycle
take off the bottom front panel and clean the coin trap it will be up front just unscrew it have some towels handy
Dec 20, 2008 | Whirlpool GHW9400 Front Load Washer
Miele dishwasher troubleshooting
either your heater is broken or spray arms are clogged.
May 26, 2008 | Dishwashers
No water is coming out of the spout in the dishwasher
I am experiencing the same problem on my kenmore dishwasher (model: 665.1702). there appears to not be enough water spraying out of the washers as the soap is still in the dispenser at the end of the wash and the dishes are dirty. I've tried removing the bottom washer but can't figure out how to remove it. Did either of you find a resolution?
Dec 02, 2007 | Kenmore 24 in. 17669 Free-standing...
Water in bottom of dishwasher
Hi You have a drain problem, Your house drain may be restricted the dish washer pumps out with more pressure then the water just falling down your sink.I would snake it or have a plumber clean out that drain...let me know if this helps krazytech
Aug 24, 2007 | Bosch 24 in. SGS43C12 Classixx...
Prgramme not starting or finishing
The "mushroom" bottom is just a lever that operate a switch. It seems that a part of the switch's mechanism is broken or release.
Jul 22, 2007 | Bosch 24 in. SGS43C12 Classixx...
Dishwashers Logo
Top Dishwashers Experts
