SOURCE: error code Sharp AR-M 257
The F2-04 error code you are getting is that you are using the wrong toner.It may be form sharp,but it toner chips is different.Only the chips swapping at the toner back can help you.
SOURCE: Sharp AR-5127 H2-00 code reset
Sharp Fuser
H2-0 Fusing unit
temperature error
H4-0 The fusing unit doesn't heat up.
***ALWAYS DISCONNECT POWER WHEN WORKING
ON MACHINE***
You have to reset fuser errors with simulation 14.
Push P * C * then 14 then Start (the button you use to make copies)
and it should reset the code. If not then replace the fuser.
SM
5-1 should turn the lamp on. If lamp blinks on and off it is the
thermistor, if it does not it is the lamp, but check the contacts on
the lamp/fuser -- they have been known to erode.
Also check thermal fuse, if defective
replace.
SOURCE: sharp ar 407
Hello sir;There have a procedure to reset;
1, press "program", "interupt", "clear", "interupt"
2, enter 14, then press start,then enter 0, press start again. then press clear.
SOURCE: sharp ar-m205 error code E7 11
U HAVE TO UPGRADE THE FIRM WARE BY ENTERING SIMULATION 49-1 THE VALUE IS d THEN UPDATE THE FIRM WARE IF U HAVE IT
SOURCE: ERROR CODE U2-40: SHARP AR 5127
ERROR CODE U2-4 COULD BE RELATED TO THE MEMORY BATTERY BEING DEAD ON TEH MAIN BOSRD IF IT IS AN OLD MACHINE SO YOU COULD CHECK THSI OR REPLACE AND TRY WITH NEW
