If you wish to get some details; visit the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ Unlock procedure and to override the password lock and to set the device region free procedure of many popular brand TVs and other devices are given. Search the site by type in this key phrase "How to unlock television"; in the search box at the top left of the display window, to get gathered related posts.
SOURCE: HELP ME PLEASE............
You need to be more specific with the model number. Most Sansui TVs have model numbers like "SAN2701" plus a version letter like "Version A"
Additionally, procedures for removing the Child Lock, Panel Lock and TV Lock are in the users manual.
In some models, for the V-Chip, the original code is 000000, if you want to clear the code, please press the keys VOL + and VOL - on the front panel at the same time.The password of the TV's V-Chip Set up or Movie V-Chip Set up may be changed at any time. Press UP or DOWN to input the password,then press to select OK or Cancel. Press menu to confirm your input.
Hope this be of initial help/idea. Pls post back as to the exact model and version of your Sansui TV, how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
SOURCE: sanyo tv kit 360 ch fit in my old tv & lock channel kindly solve problem to unlock tv channel
i am imran
and i have also buy sanyo tv kit 360 ch fit in my old bpl 20"tv and i know for unlock tv channel.
try this this code definetly is solve your problem.
1st go to the locked channel.
and then press menu>system>child lock
and then press and hold down tv/av key and press swap key.
and see locked channel is unlock.
i have coming soon post for service code menu in short coming days.
please reply me to [email protected]
SOURCE: Unlock child proof lock on Sansui TV
you can try it by pressing the power button and the tv/av button at the same time, that worked for me ,My tv is about 8 years old
SOURCE: Lock code for Onida Black Dlx channel tunner menu
My Tv is locked and cannot start. it asks for password.
how to open it?
Press the
"Menu" button to set the lock code for your JVC TV. A padlock icon
will appear on the menu display.
Press "Zero"
to access the lock code function then use the left and right arrows to select
the four-digit number for your code. Use the up and down arrows to move to the
next area of the display.
Select the up or down
arrow to finish your lock code then use the left or right arrow to save your
lock code settings and exit the menu. You can return to this display if you
forget your four-digit lock code and set another code.
Write your four-digit
lock code down and keep it in a safe, private area.
Select the locked TV
channel you desire to watch or want to unlock. A message will appear on the
display requesting you to enter your lock code to unlock the channel.
Unlock your JVC TV by
entering your lock code on the 10-key pad. The message "Invalid Lock
Code!" will appear on the screen if you enter the wrong lock code.
OR
Select "TV"
from the menu then select "V-Chip" from the drop-down list on the
screen. "Please Input Password" will appear on the screen.
Enter your four-digit
password by selecting numbers on the 10-pad that appears on the V-Chip menu
display or your remote control. Create a new password if you forget it by
unplugging your TV power cord from the outlet then reconnect the power cord.
This procedure resets your password to "0000." Enter four numbers for
your new password using the keypad on the screen or your remote and select the
arrow to advance to the next number. Press "OK" on your remote or
select "OK" on the screen to set your new password.
Unlock a TV rating or TV
channel by selecting "MPAA" or "TVPG" from the V-Chip menu.
Use the up or down arrows to select the locked rating then select
"OK" on the display or press the "OK" button on your remote
control to unlock it. The MPAA represents the U.S. Motion Picture Association
of America rating system, such as "NC-17," meaning not intended for
viewers 17 years or younger.
Press the
Press "Zero"
Press the
Press "Zero"
Unlock your JVC TV by entering your lock code on the 10-key pad. The message "Invalid Lock Code!" will appear on the screen if you enter the wrong lock code.
Press the "Menu" button to set the lock code for your JVC TV. A padlock icon will appear on the menu display.
Press "Zero" to access the lock code function then use the left and right arrows to select the four-digit number for your code. Use the up and down arrows to move to the next area of the display.
Select the up or down arrow to finish your lock code then use the left or right arrow to save your lock code settings and exit the menu. You can return to this display if you forget your four-digit lock code and set another code.
Write your four-digit lock code down and keep it in a safe, private area.
Select the locked TV channel you desire to watch or want to unlock. A message will appear on the display requesting you to enter your lock code to unlock the channel.
[2]
Select "TV" from the menu then select "V-Chip" from the drop-down list on the screen. "Please Input Password" will appear on the screen.
Enter your four-digit password by selecting numbers on the 10-pad that appears on the V-Chip menu display or your remote control. Create a new password if you forget it by unplugging your TV power cord from the outlet then reconnect the power cord. This procedure resets your password to "0000." Enter four numbers for your new password using the keypad on the screen or your remote and select the arrow to advance to the next number. Press "OK" on your remote or select "OK" on the screen to set your new password.
Unlock a TV rating or TV channel by selecting "MPAA" or "TVPG" from the V-Chip menu. Use the up or down arrows to select the locked rating then select "OK" on the display or press the "OK" button on your remote control to unlock it. The MPAA represents the U.S. Motion Picture Association of America rating system, such as "NC-17," meaning not intended for viewers 17 years or younger. TVPG provides you
