Question about Nokia 6630 Cellular Phone
I installed a RS-MMC 512mb memory card in my nokia 6630 but it is unable to access the card
  • Nokia Master
  • 805 Answers
1st check is ur memory card is ok. u can check it by connect pc. if card ok then format ur phone and insert ur card. but if still no result then its ur memory card slot problem or ur memory card ic has damaged.
Posted on Jul 30, 2009
Testimonial: "Thanks for your advice,turned out that the memory card was bad. riggragg"
My n72 512mb card is not reading either in phone or in pc
With regard to your N72 512mb memory card, basically, if your phone or computer is unable to read it, there is a big possibility that it was damage or broken.
Once you connected your 512mb MMC to your card reader and the computer is not recognizing it, it is already broken.
To make sure, try other memory card and if it works, obviously, your 512mb is defective.
And if you need some files to be recovered from the old 512mb memory card, there is only a small possibility that you can recover it, you can try going to some repair store that fixes memory card.
Nonetheless, if there is no important files or data on the memory card, I would suggest getting a new one since it doesn't cost that much nowadays.
Thank you,
Jack
Feb 15, 2011 | Nokia N72 Cellular Phone
My memory card is corrupted ncp mmc 512mb how it unlock
There is no other way to unlock instead of buying a new one
Feb 05, 2011 | Nokia 6630 Cellular Phone
Nokia6300 - SD card(512MB-Password protected not recognised)
If the particular mmc is not displaying in your phone and display other mmc it is not a password protected actually the mmc is damage.
Jul 07, 2010 | Nokia 6300 Cellular Phone
Does Nokia 3230 support 512Mb memory cards?
Yes it will support a 512K Reduced Size MMC card / RS-MMC
(note: RS-MMC card is not a common MicroSD card)
Hope it helps.
Dec 28, 2009 | Nokia 3200
NOKIA 3230 with RS-MMC card 512 mb.
scan the mmc with the good virus scanner
Oct 31, 2009 | Nokia 3230
My mobile cannot install .sis themes
its a t mobile phone it dont like my atnt sim card
May 16, 2009 | Nokia 6630 Handheld
How to remove write protected memory card
when i attach the card reader with system and when i store the software or any thing in memory card then msg show that(cannot copy because write protected error)
Aug 29, 2008 | Nokia 3230
Nokia N70 wont acknowledge memory card?
Note: This device uses a Reduced Size Dual Voltage
(1.8/3V) MultiMediaCard (RS-MMC). To ensure
interoperability, use only dual voltage RS-MMCs. Check
the compatibility of an RS-MMC with its manufacturer or
provider.
Use only compatible Reduced Size MultiMediaCards
(RS-MMC) with this device. Other memory cards, such as
Secure Digital (SD) cards, do not fit in the memory card
slot and are not compatible with this device. Using an
incompatible memory card may damage the memory card
as well as the device, and data stored on the incompatible
card may be corrupted.
You cannot use the memory
card if the door of the
memory card slot is open.
Format a memory card
When a memory card is reformatted, all data on the card
is permanently lost.
Some memory cards are supplied preformatted and others
require formatting. Consult your retailer to find out if you
must format the memory card before you can use it.
To format a memory card, select Options > Format mem.
card
. Select Yes to confirm. When formatting is complete,
enter a name for the memory card, and select OK.
Apr 03, 2008 | Nokia N70 Cellular Phone
Start up failed contact the retailed
If you encounter situation like below on your 6630,
1. Blank screen phone unable to reboot.
2. Phone only able to boot-up to "Nokia" word screen.
3. Install some program but not able to uninstall it after that.
4. Error messages such as "Child Installer" keeps popping-up.
5. Contact Re-tailer
Do a Full phone formatting on your 6630! as steps below,
1. Make sure you have at least 3/4 charge of battery power left.
2. Backup your contacts list and personal files to MMC memory card.
3. Switch-off your 6630 phone.
4. Press and hold 3 keys;
Green dial key, * (star key) & no. 3 key and then press the power on/off to swtich on the 6600 phone.
Remember, do not let go all of the keys and hold keys until you see a nokia logo goes to white or it will blink....
5. After a few minutes when the Full phone formatting completed, your 6630 will back to original system and factory settting.
All apps installed & not of the phones' default will be lost. If you did a backup on your mmc, you can restore it back to the C drive again.
Thank you for rating this Tip.
Feb 20, 2008 | Nokia 6630 Cellular Phone
Problems with Nokia 6681...
1. sms uusually don't get backuped,unless uploading information from your phone to a pc is supported by your phone. try to look up user's guide. 2. rebooting BB5 class phones such as 6630,6680,6681, N series usually require full reformatting. try visiting your local non-Nokia/independent service stations.
Jun 19, 2007 | Nokia 6681 Cellular Phone
Nokia 6630 Cellular Phone Logo
78 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
