Question about Kenmore 22422 Top Load Washer
Kenmore washer no spin
Top load elite washer won't spin with a load in it. It will try without clothes, but slows down to a stop.
Coupling broke
Posted on Dec 08, 2007
My Kenmore Elite Oasis washer unbalanced signal seems to be very sensitive. Only after several tries of readjusting the load to get it really even that the washer will spin without stopping. I made sure...
If the washer throws an UL error code with out any clothes in the washer then the issue must be concerned with the mechanical alignment inside the machine or a bad CCU.
The most common problem which can cause this is some sort of mechanical hinderance which does not allow the basket to move freely.
The suspension system which holds the basket in its place might be faulty and causing the unbalancing. In this model i think there are plastic ring at the bottom of the basket . Even if they are worn out or moved out of position it may cause the UL error code you are facing
Nov 09, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Does the washer drain the water quickly?? Are there any error codes?? Usually the drain pump sump is clogged and not draining, thereby not letting the unit advance to spin.
Nov 23, 2007 | Kenmore Elite HE4 Electric Dryer
Clothes still wet after cycle is over
Be sure drain hose is not kinked and no higher than the top of washer to drain pipe. Remove clothes as soon as it stops spinning
Jun 23, 2010 | Kenmore 23822 Top Load Washer
My Kenmore Elite washer spins to slow cauisng the
If this is occurring mostly on heavier loads your clutch may be slipping. If you take a flathead screwdriver and push down the lid switch so the washer will spin with the lid up, grab the inside of the drum. If you can easily stop the drum its most likely a bad clutch. If you tip the washer back and see oil underneath then its probably your transmission leaking oil onto the the clutch causing it to slip (in which case you need transmission and clutch assy). If you see oil I would probably not bother calling a tech it would be a pretty expensive repair.
IF the problem is with the clutch only it may be worth repairing but to replace the clutch you will have to remove the pump, motor, transmission, and the clutch mounts on top. The other less common possibility could be a bad drive block under the inner tub. hope this helps. _MJ_
Jan 28, 2010 | Kenmore 15864/15862 Top Load Washer
My kenmore elite oasis keeps stopping on spin and flashing ul it is a top loader king size capacity
UL = uneven load.
Re-distribute clothes and re-try.
If still no-go... the load balance sensor is likely to blame.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 23, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore elite top load washer
error code with this? f11 or f22 are control board related commucation errors.
Jun 02, 2008 | Kenmore Elite 45986 Front Load Washer
Series 70 kenmore elite washing machine
If it goes through the complete cycle o.k. except for the slow spin then the motor itself needs to be checked.
Mar 20, 2008 | Kenmore 24622 Top Load Washer
Kenmore 22422 Top Load Washer Logo
87 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
