SOURCE: downlaoding pictures onto Pandigital frame
My picture frame shuts down after viewing 5 or 6 slides. I shut it off and restart it and get back to the same place and it shuts down again.
SOURCE: Unable to operate remote of Pandigital picture frame
remove the memory card and see if the remote works wit hthe built in memory pics. if it doesnt pic up your card you will just have to try another card. The frames dont read cards larger than 1 Gb very well either - reguardless of how many pics are on the card.
SOURCE: PANDIGITAL DIGITAL PHOTO FRAME SNOW GLOBE
Once you have the box connected with the usb cable to the computer, you have to tilt it towards connect to pc. You might have to do this a couple of times the picture on the display should change to a usb cable. Now if you go to my computer you will see where it says pan digital. Here is where you can add the pictures. I just did add pictures. If you want the pictures in a certain order you will have to name them otherwise there are displayed in alphabetical order. I found this after I loaded everything and wanted them in a specific order. Right now I am trying to add sound. I see that there is a speaker but not sure how to add sound.
SOURCE: Need PANDIGITAL PanDigital 8.0" Digital
I don't like pasting information, but this is the link to the manual.
http://akamaipix.crutchfield.com/Manuals/692/692PAN902B.PDF
Don't forget to rate my solution, and thanks for coming to FixYa.
Rob
SOURCE: how do you load pictures on a pandigital picture
The following link will provide you with all of the information you need to operate the photo frame. There is plenty of information including operation, specifications, mounting instructions, etc. There is simply too much information to type into this little square box. LOL I hope this helps and good luck.
If the link does not work, just copy and paste it into your browser.
http://www.imaging-resource.com/ACCS/PDGTL/PD8.HTM
