Question about Toshiba LCD TFT Monitor
Can i replace my Gateway laptop tft screen with a new lcd screen?
Can i replace my Gateway MX3311b laptop's screen with a new lcd wxga screen? I used to get 1200x800 on my screen, would the new screen work on my laptop with same specs?
http://cgi.ebay.co.uk/NEW-GATEWAY-MX3311B-14-1-WXGA-GLOSSY-LCD-SCREEN_W0QQitemZ280359028222QQcmdZViewItemQQptZUK_Computing_LaptopAccess_RL?hash=item4146b345fe&_trksid=p3286.c0.m14
the gateway screen information is below
http://support.gateway.com/s//Mobile/Q106/Bishop/1013898Rcl2.shtml
    Sergeant:
  • 168 Answers
The screen resolution is a combo of:
  1. the screen's capability
  2. the video card's capability
  3. the driver's settings
If the above screen is made for this laptop (as it appears to be), then the settings you had should still be there.
Posted on Jul 29, 2009
Cracked lcd hp g6 notebook screen
if you want to replace the screen i suggest to replace the whole unit.since its hard to find lcd screen only unless in the manufacturer.then i'm sure the price is like you buy new one.
Aug 29, 2012 | HP Nx7400 Notebook Pc 15.4-inch Wxga Tft...
Are the display bands compatible?
1) Toshiba Satellite P300-13j LCD screen example,
http://www.screentekinc.com/Toshiba_Satellite_P300D-13J--17-inch--1440x900-wxgaplus-laptop-lcd-screen.shtml
Thin Film Transistor (TFT) Active Matrix LCD screen, that is WXGA, and uses one CCFL for a Backlight.
2) http://www.lcds4less.com/ToshibaLaptop__Toshiba_Satellite_P300D-12L__laptop-screens.html
Thin Film Transistor (TFT) Active Matrix LCD screen, that is WXGA, and has 1 CCFL for a Backlight.
There is a pretty good chance. The screen Inverter and LCD screen are a matched unit. I would remove the screen Inverter from the P300-12L, and use it also.
Looks like this,
http://www.lcd-inverter-shop.com/Toshiba/Toshiba-Satellite-P300D.html
If I may ask;
1) Is there obvious damage to the LCD screen?
2) If there is not obvious damage to the LCD screen, have you used an external VGA monitor with the laptop?
To see if the problem is the graphics chipset, or the video cable, or inside the Display Assembly.
A) http://www.irisvista.com/tech/laptops/Toshiba-Satellite-P305/take-apart-notebook-1.htm
B) http://www.irisvista.com/tech/laptops/Toshiba-Satellite-P105-P100/remove-lcd-screen-inverter-1.htm
Post back in a Comment.
Regards,
joecoolvette
[Primer:
An LCD screen cannot produce light by itself,
(Click on the monitor icon,
http://solutions.3m.com/wps/portal/3M/en_US/NA_Optical/Systems/BehindTheScenes/Optics101/ )
It needs an additional light source. A Backlight is the additional light source.
A Backlight can be a CCFL, (Or two of them), or a series of LED's.
LED stands for Light Emitting Diode
CCFL stands for Cold Cathode Fluorescent Lamp.
Similar to Fluorescent lighting used in homes, and businesses, but on a MUCH smaller scale.
Average thickness is 2mm. That is a little larger than 1/16th of an Inch.
Average length is almost as long, as the LCD screen is in height.
http://www.laptoprepair101.com/laptop/2007/12/09/replace-laptop-backlight-ccfl-lamp/
Observe the last 8 photos especially. This article shows you that the LCD screen is an assembly. It is composed of layers. Just like the 3M company's tutorial. Also shows general instructions for replacing a Backlight.
A screen Inverter is used to convert the power from the laptop, for the LCD screen, and Backlight.
It is a small circuit board, and is usually mounted towards the bottom of the LCD screen, and behind the Display Bezel.
A CCFL, (Or two of them), uses a screen Inverter.
LED backlighting however, may or may not use a screen Inverter.
Using LED's for backlighting is relatively new, when discussing backlighting technology.
Some of the first designs of LED backlighting does use a screen Inverter.
Newer designs do not seem to.
90 PERCENT OF THE TIME the problem can be attributed to a bad screen Inverter.
Aug 21, 2012 | Toshiba Satellite Computers & Internet
What is the difference between mx3231 mx3228?
The screens are probably interchangeable. The two laptops have the same size screens, 14-inch Widescreen Ultrabright WXGA TFT. The major difference between them is that the MX3231 has a CD writer/DVD-ROM optical drive. The MX3228 has a dual-layer DVD writer. See https://support.gateway.com/s/Mobile/Q106/MagicLC/1009130sp2.shtml and http://support.gateway.com/s/Mobile/Q106/MagicLC/1008831sp2.shtml for the specs of both of these Gateway notebooks.
I hope this helps.
Jun 03, 2012 | Computers & Internet
LCD HELP!
When you go to this WEB site foe LCD screen parts, just enter the make and model of your laptop.
LCD screens and Inverterswww.lcdparts.net
Dec 29, 2011 | HP Pavilion Computers & Internet
Fuzzy screen on Gateway FPD1975W TFT LCD Monitor
With the pixels acting up and the monitor having the same problem on any computer that its connected to. The screen itself is bad and since there are no replacement screens for that monitor, you would have to buy a new monitor or get it replaced if its under warranty.
Jun 02, 2010 | Gateway FPD1975W 19" LCD Monitor
No screen light. can use flashl ight see faint imeg. screen not illuminated? 15.4 wxga r3000 presario
Screen Lamps are dead or Lamp inverter is dead or the high voltage fuse of the inverter is blown. Try to contact some reliable repairing engineer.
Regards;
Hasan
Dec 30, 2009 | Toshiba HP Compaq 15.4-inch TFT WXGA LCD...
HP Pavillion DV4000 notebook display shading
It sounds very much like an inverter issue. The inverter sits under the lcd screen in the screen plastics. It is replaceable, but obviously there is a danger the screen may get damaged.
Nov 21, 2009 | HP Computers & Internet
Screen
Is this an inverter issue with the display? Is it worth fixing.
Yes, and yes.
If it is still under warranty have Gateway fix it.
If not
Go on Ebay and you may find the part cheap.
Dec 23, 2007 | Gateway MX3215 Notebook
Computers & Internet Logo
672 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
