Question about Honeywell ER150B Air Conditioner
Ac is on but its not pumping out any cold air
    Guru:
  • Honeywell Master
  • 587 Answers
Compressor is probably not running.
The Main reasons that this will happen
1 - A bad run capacitor (silver or metal capacitor)
It’s either shorted, grounded or open.
If it’s shorted a lot of times it will bulge out, (sometimes slightly)
2 - A bad start kit ( plastic capacitor and Relay connected to it )
The capacitor is either shorted or open
The relay either has an open coil between terminals #1 and #5
Or the relay is stuck.
Any time you change the capacitor or relay you should change
the other, especially if they are over a year old.
3 - A loose, burnt or disconnected wire
4 - Wired wrong
5 Compressor is open (windings burnt open)
6 Low on charge not getting enough cooling back to compressor, (Feel top of compressor to see if it’s hot it shouldn‘t be)
7 Some compressors have a black plastic overload under the compressor cap which could be bad.
Posted on Aug 25, 2009
My ac not blowing cold air
Not blowing cold air would be either the belt could be slipping,or broken .Most likely the pump clutch has failed.also check the aircon relay depending on what car this is the relay would be in the fuse section under bonnet/hood
Good Luck:)
Oct 15, 2016 | AC Cars & Trucks
Our AC keeps cutting out. It runs for a few minutes then stops. have to switch off and restart. Any idea why? Have emptied water and cleaned filter recently
Look for:
  1. the ac needs air flow thru the indoor and outdoor radiators
  2. the outdoor radiator coil should get warm/hot and produce warm air.
  3. indoor radiator coil needs should get cold and produce cold air.
The ac needs the fan motor(s) working and compressor running and pumping. Compressor skinny copper line hot and thick line cold.
Jul 21, 2015 | DeLonghi Heating & Cooling
Replaced AC with converter kit and ac still does not blow cold air.
could be fuse or relay causing pump not to kick on...also could be clutch on pump has failed...somethings you might check...
Aug 18, 2012 | 1992 Honda Accord
AC unit outside blowing out cold air, vents
Sounds like compressor not running. may be a bad capacitor, could also be low on freon.
Aug 30, 2009 | Goodman CLJ30AR32 Air Conditioner
1998 gmc sonoma air conditioner - not cold
Check the magnetic clutch is engaged on front of a/c pump, have the motor running, a/c on and fan on high, if the centre hub is static the pump in not switched on, this can happen when the gas pressure gets low.
Aug 05, 2009 | 1998 GMC Sonoma
When on AC the air blows hot, when on heat the air blows room temprature
This is a wiring issue or you have a heat pump and the reversing valve is stuck.
Jun 03, 2009 | Honeywell Electronic Programmable...
Center vents cold side vents hot please help bthibs
hello,good day,seems your recirculating pump need tobe check,ty
May 15, 2009 | 1996 Mercedes-Benz C-Class
AC button blinking
hi mercedes,
here is another thread that is almost similar to your problem, i just paste it here with my reply...
posted by Ron0293 on Sep 27, 2008 Report abuse
1985 toyota Camery in hot weather the car AC quits and will not engage the pump. After it cools the pump will come on again. When this happens the AC button in the car blinks. i know this is a vacuum and/or temperature sensor but i don't know which one it is. The manual I have does not say anything about it. Other wise the AC works just fine. Ron Comment by Ron0293, posted on Sep 27, 2008When I first turn it on the AC is working fine, blowing cold air all the time, the clutch pump is in gauged...when the problem occurs the clutch disingauges and then no cold air.. Comment by Ron0293, posted on Sep 27, 2008When I first turn it on the AC is working fine, blowing cold air all the time, the clutch pump is in gauged...when the problem occurs the clutch disingauges and then no cold air.. It is a sensor somewhere telling the pump to turn off. Comment by Ron0293, posted on Sep 28, 2008there is nothing wrong with the whole AC system when the compressor is pumping! no holes, no leaks, no heater problems or fan problems. The compressor keeps cutting out when the temperature starts to climb. I believe the system has a motor vacuum load/temp. sensor that cuts the AC out when the motor temp. rises from extra load. IE: like going up a long hill. I just don';t know where the sensor is located and the clutch wiring from the compressor is impossible to follow, as it is buried in a wire harrness. Comment by Ron0293, posted on Sep 29, 2008 There are two fans located at the rear of the radiator. They don't seem to be running when the AC pump cuts out. There is a sensor switch on the dryer. when the pump is acting up if i disconnect the sensor wiring the fans start running on high. There is also another sensor on the pump and when i disconnect it the fans start running on high. replacing the wiring returns the fans to off.
There is also a sensor, seems to be internal on the pump and when I disconnect it nothing happens. if(typeof LIB_LOADED == 'undefined'){document.write(''); } Add a Comment
Oct 01, 2008 | 2002 Toyota Camry
Please help me with my air conditioning for my 1995 jetta
HI, giving the compressor 12v directly is not the way to go as you are bypassing the entire fail safe cercuit. it seem to me that your ac gas is low(can be checked via ac pressure gauges) wich means you have a system leak sumwhere. as soon as your hi/low pressure switch(depending on system) detect inferior pressure to the spesified pressure ,the ac compressor voltage is cut in order to protect the pump from seizure.
Or perhaps your evaporator(small radiator like unit behind dash) can get freezed up caused by either too mutch system gas(check pressure) or poor opperation of the expantion valve. the evaporator then has a sensor(themometer) wich measures evap. temp and if the value drops below spec (usially round about7degrees) the ac compressor will be cut once again(fail safe)
Maybe your ac compressor overheats due to inferior system oil/oil capasity, also note that only some systems incorperate the function of measuring ac pump temp. then again temp to high= fail safe=no12v to ac pump.
Good luck.
gk
Jul 14, 2008 | 1995 Volkswagen Jetta
24000 btu split ac unit... celiera brand... BIG PROBLEM
is this air inside or out that is cold and cloudy?
Feb 19, 2008 | Fujitsu 24R1 Air Conditioner
Honeywell ER150B Air Conditioner Logo
121 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
