You turn the lid upside down for anything and the small silver pressure pin comes out. of course it is going to get lost is someone is using the machine and doesn't know!
The pressure valve is just a height sitting on a hole and when the pressure in the cooker reaches such a pressure that it can dislodge the weight , it blows off the pressure and so the pot will not explode
of course if you tip the lid upside down , it will fall off as that is what it is supposed to do
SOURCE: Wolfgang Puck DYB250 pressure cooker
Mine was missing when I received my order also the power cord. I am sending it back to Amazon.com
SOURCE: cooks essentials replacement lids
to : DOckr9
I did not need new lids for my cooks essentials pressure cooker's, I only needed new parts. I ordered them from
Fagor, thjey carry parts fpr cooks essentials, futuro, and fagor cookers.
I need a replacement lid for Breville RC3. Anyone know where to source one?
SOURCE: Steam coming out of floating valve on handle.
No. if the steam is coming out, the vent valve is not seated on the vent and pressure won't build up. Either remove the plastic cover from the vent valve or slide it up enough so that the valve seals on the vent. If you remove the plastic cap, you will need to manually tilt the valve to "quick-vent" the cooker. Watch out for steam burns! Should work fine after that. You need to unplug the cooker and re-plug it to reset the "E4" error message.
SOURCE: my sceptre television picture is upside down, can
If you select "source" on your remote then enter 7343 it will bring up a factory menu. Go down to 'Other setting' , the setting 'scaler output' should be set to "Normal". This setting flips the display.
